查看: 2699|回复: 2
customsim(xa) 2010 問題
发表于 2018-3-25 15:53:55 | 显示全部楼层 |阅读模式
求助高手, 當執行 xa指令時 有如下訊息
/home/cadtools/synopsys_xa/xatool/xa201003/XA_201003/bin/xa: line 247: dirname: command not found
/home/cadtools/synopsys_xa/xatool/xa201003/XA_201003/bin/xa: line 275: dirname: command not found
/home/cadtools/synopsys_xa/xatool/xa201003/XA_201003/bin/xa: line 148: expr: command not found
/home/cadtools/synopsys_xa/xatool/xa201003/XA_201003/bin/xa: line 173: expr: command not found
/home/cadtools/synopsys_xa/xatool/xa201003/XA_201003/bin/xa: line 174: expr: command not found
找出xa 指令 error 相對應的 line為
line 247--> synopsys_install_root_bin=`dirname "$cmd"`
line 275--> SYNOPSYS_INSTALL_ROOT=`dirname "${synopsys_install_root_bin}"`
line 148--> if [ "`expr \" ${cc_arg} \" : \".*[
]${cc_bitflag}[
].*\"`" = "0" ] ; then
line 173-->    cc_cmd=`expr "$1" : '[
line 174-->    cc_name=`expr "$cc_cmd" : '\([^
換過不同的shell 啟動(/bin/csh , /bin/bash) 仍無效 請高手幫忙 感恩
发表于 2018-3-25 19:29:17 | 显示全部楼层
lib wenti
 楼主| 发表于 2018-3-25 23:29:40 | 显示全部楼层
lib wenti ??
GMT+8, 2025-10-31 23:38 , Processed in 0.017818 second(s), 5 queries , Gzip On, Redis On.
