楼主: 黑崎一护776
[求助] 请问带压缩链的设计在write patterns的时候是直接用-parallel就够了吗?
发表于 2018-5-6 21:03:11 | 显示全部楼层
这是测试结果,发现在压缩模式下,用了-parallel之后,是列出了内部压缩电路的SCAN IN值;
不加-parallel时,列出的SCAN IN PORT上的输入值。
write_patterns pattern_Comp/DW8051_scan_Comp_para.stil.gz -format stil99 -compress gzip -replace -parallel
  1.    "pattern 0": Call "internal_load_unload" {
  2.       "internalscn_i_0"=11001100110011; "internalscn_i_1"=11001100110011;
  3.       "internalscn_i_2"=11001100110011; "internalscn_i_3"=11001100110011;
  4.       "internalscn_i_4"=11001100110011; "internalscn_i_5"=11001100110011;
  5.       "internalscn_i_6"=11001100110011; "internalscn_i_7"=11001100110011;
  6.       "internalscn_i_8"=11001100110011; "internalscn_i_9"=11001100110011;
  7.       "internalscn_i_10"=11001100110011; "internalscn_i_11"=11001100110011;
  8.       "internalscn_i_12"=11001100110011; "internalscn_i_13"=11001100110011;
  9.       "internalscn_i_14"=11001100110011; "internalscn_i_15"=11001100110011;
  10.       "internalscn_i_16"=11001100110011; "internalscn_i_17"=11001100110011;
  11.       "internalscn_i_18"=11001100110011; "internalscn_i_19"=11001100110011;
  12.       "internalscn_i_20"=11001100110011; "internalscn_i_21"=11001100110011;
  13.       "internalscn_i_22"=11001100110011; "internalscn_i_23"=11001100110011;
  14.       "internalscn_i_24"=11001100110011; "internalscn_i_25"=11001100110011;
  15.       "internalscn_i_26"=11001100110011; "internalscn_i_27"=11001100110011;
  16.       "internalscn_i_28"=11001100110011; "internalscn_i_29"=11001100110011;
  17.       "internalscn_i_30"=11001100110011; "internalscn_i_31"=11001100110011;
  18.       "internalscn_i_32"=011001100110011; "internalscn_i_33"=11001100110011;
  19.       "internalscn_i_34"=11001100110011; "internalscn_i_35"=11001100110011;
  20.       "internalscn_i_36"=11001100110011; "internalscn_i_37"=11001100110011;
  21.       "internalscn_i_38"=11001100110011; "internalscn_i_39"=11001100110011; }
  22.    Call "multiclock_capture" {
  23.       "_pi"=11001111100001001100101010011101000101100001001000011111011010110101;
  24.       "_po"=LLLLLLLLLLLLLLLLHHLHHLLHHLLHLLHHHHLLHHLLHHLLHHHHLLHHLLHHLLHLLLLLLLLLLLLLLLHLHHLLHHHHHLLHHLLHHHL; }
  25.    "pattern 1": Call "internal_load_unload" {
  26.
    复制代码
write_patterns pattern_Comp/DW8051_scan_Comp_seri.stil.gz -format stil99 -compress gzip -replace -serial
  1.    "pattern 0": Call "load_unload" {
  2.       "scan_in0"=0011001100110011; "scan_in1"=0011001100110011; }
  3.    Call "multiclock_capture" {
  4.       "_pi"=11001111100001001100101010011101000101100001001000011111011010110101;
  5.       "_po"=LLLLLLLLLLLLLLLLHHLHHLLHHLLHLLHHHHLLHHLLHHLLHHHHLLHHLLHHLLHLLLLLLLLLLLLLLLHLHHLLHHHHHLLHHLLHHHL; }
  6.    "pattern 1": Call "load_unload" {
  7.
    复制代码
 楼主| 发表于 2018-5-8 15:55:50 | 显示全部楼层
回复 11# YouHKH
   非常感谢!!!
 楼主| 发表于 2018-5-8 15:56:29 | 显示全部楼层
回复 10# ridge_gu
   谢谢!!
 楼主| 发表于 2018-5-8 16:12:39 | 显示全部楼层
回复 11# YouHKH
   大哥,能不能把非压缩模式下的serial和para也截图给我看看哈~~~不胜感激
发表于 2018-5-8 22:50:47 | 显示全部楼层
回复 14# 黑崎一护776
   不清楚你说的啥呢?
 楼主| 发表于 2018-5-12 13:23:47 | 显示全部楼层
回复 15# YouHKH
你不是在compress模式下用了-parallel和-serial给我截的图嘛。。我想你截个非压缩模式下pattern的-parallel和-serial是啥样的。。。。。。谢谢你
发表于 2018-5-18 10:16:51 | 显示全部楼层
 楼主| 发表于 2018-5-21 20:54:27 | 显示全部楼层
回复 17# DFT_Elite
   那请问,非压缩模式的pattern和压缩模式的pattern,内容一样吗?我说写出来的内容。。。。就像那个截图出来的兄弟贴出来的那个东西。如果像你所说,那么我能理解为非压缩模式和压缩模式下的pattern仅仅是stildpv仿真不一样吗?
发表于 2018-5-23 19:21:22 | 显示全部楼层
回复 18# 黑崎一护776
   压缩和非压缩的pattern不一样,首先scan chain的长度/数目都不一样,atpg会生成不一样的压缩和非压缩模式的pattern。然后关于test coverage, 你会看到压缩模式和非压缩模式的coverage有所不同。 如果你的design比较大,可以先做compression analysis,随着压缩比增大,你会发现test coverage会随之下降,pattern数量会变多。当然压缩比(compression ratio)大的好处是shift cycle会变小,单个pattern测试时间降低。所以量产芯片做compression的时候会要权衡测试时间和test coverage。
 楼主| 发表于 2018-5-24 21:26:45 | 显示全部楼层
回复 19# ridge_gu
   只能用专业这个词形容您。。。。。谢谢大佬,记下来了
GMT+8, 2025-12-30 10:11 , Processed in 0.022280 second(s), 3 queries , Gzip On, Redis On.
