查看: 4666|回复: 17
[资料] "Staying Well Grounded" by Hank Zumbahlen from ADI
发表于 2018-3-6 14:12:33 | 显示全部楼层 |阅读模式
"An important topic to be discussed is grounding techniques appropriate for a mixed-signal, analog/digital environment.
Indeed, the single issue of quality grounding can—and must—influence the entire layout philosophy of a high-performance
mixed-signal PCB design."
staying_well_grounded.pdf (464.9 KB , 下载次数: 95 )
发表于 2018-3-6 16:12:50 | 显示全部楼层
thanks
发表于 2018-3-6 18:39:45 | 显示全部楼层
thanks
发表于 2018-3-7 10:40:09 | 显示全部楼层
thanks
发表于 2018-3-7 16:44:37 | 显示全部楼层
回复 1# sanbanjji
    thanks
发表于 2018-3-7 18:09:51 | 显示全部楼层
thanks for your sharing
发表于 2018-3-8 10:33:03 | 显示全部楼层
thanks
发表于 2018-3-8 13:03:36 | 显示全部楼层
thank you!
发表于 2018-3-9 08:48:52 | 显示全部楼层
不错,看看
发表于 2018-3-9 14:07:44 | 显示全部楼层
thanks for sharing
GMT+8, 2025-12-24 20:28 , Processed in 0.023878 second(s), 4 queries , Gzip On, Redis On.
