查看: 2222|回复: 1
[讨论] timing check in DC
发表于 2018-1-10 02:47:04 | 显示全部楼层 |阅读模式
check_timing got:Warning: The following end-points are not constrained for maximum delay.
End point
a_d2_reg_0_/next_state
a_d2_reg_1_/next_state
does that mean I need to fix? and How?
发表于 2018-1-10 10:30:58 | 显示全部楼层
1. 搞清楚这些点具体是什么样的电路/path,是否需要约束
2. 从信息的字面意思,可以用set_max_delay来约束
GMT+8, 2025-10-8 22:50 , Processed in 0.013129 second(s), 4 queries , Gzip On, Redis On.
