查看: 11653|回复: 17
[求助] LVS Incorrect nets 错误,麻烦大神帮看一下
发表于 2018-1-6 17:30:18 | 显示全部楼层 |阅读模式
Report 在下面贴出来了,报的net错误在版图上都是一条线上的,麻烦大神帮着看一眼,谢啦~
LVS Netlist Compiler - Errors and Warnings for "/home/boshi51/digital_QRS/HCOMP/SAVE/all.cdl"
Warning: Duplicate subckt definition "POST_DRIVER_16" at line 1296 in file "/home/boshi51/digital_QRS/HCOMP/SAVE/HDIOH2ING01V1.cdl"
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         HCOMP.lvs.report
LAYOUT NAME:              /home/boshi51/newpdk/HHGRACE_PDK_BCD350GE/tech/HCOMP.sp ('HCOMP')
SOURCE NAME:              /home/boshi51/digital_QRS/HCOMP/SAVE/all.cdl ('HCOMP')
RULE FILE:                /home/boshi51/newpdk/HHGRACE_PDK_BCD350GE/tech/_be35_5.0v+40v_1p4m_calibre_lvs_v1.7_
CREATION TIME:            Sat Jan  6 17:31:02 2018
CURRENT DIRECTORY:        /home/boshi51/newpdk/HHGRACE_PDK_BCD350GE/tech
USER NAME:                boshi51
CALIBRE VERSION:          v2011.2_34.26    Wed Jul 6 05:20:56 PDT 2011
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of nets.
  Error:    Connectivity errors.
  Warning:  Unbalanced smashed mosfets were matched.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      HCOMP                         HCOMP
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD" "?VDD?" "VCC" "?VCC?"
   LVS GROUND NAME                        "GND" "?GND?" "VSS" "?VSS?"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       NO
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       YES
   LVS EXPAND UNBALANCED CELLS            YES
   LVS FLATTEN INSIDE CELL                NO
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   // LVS SPICE MULTIPLIER NAME
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE SCALE X PARAMETERS           NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            YES
   SOURCE CASE                            YES
   LVS COMPARE CASE                       NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     50
   LVS PROPERTY RESOLUTION MAXIMUM        32
   // LVS SIGNATURE MAXIMUM
   // LVS FILTER UNUSED OPTION
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // Device Type Map
   LVS DEVICE TYPE                        RESISTOR "RW" [ POS=POS NEG=NEG ]  SOURCE LAYOUT
   // Reduction
   LVS REDUCE SERIES MOS                  YES
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 YES
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           YES
   LVS REDUCE PARALLEL CAPACITORS         YES
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
   LVS REDUCE  D(ZN)  PARALLEL
   LVS REDUCE  PC  PARALLEL
   LVS REDUCE  J(NJ)  PARALLEL
   LVS REDUCTION PRIORITY                 PARALLEL
   LVS SHORT EQUIVALENT NODES             NO
   // Trace Property
   TRACE PROPERTY  q(4l)  a a 1
   TRACE PROPERTY  q(pn)  a a 1
   TRACE PROPERTY  q(vp)  a a 1
   TRACE PROPERTY  q(4n)  a a 1
   TRACE PROPERTY  q(4k)  a a 1
   TRACE PROPERTY  q(p4)  a a 1
   TRACE PROPERTY  m(sn)  w w 10
   TRACE PROPERTY  m(sn)  l l 10
   TRACE PROPERTY  m(sp)  w w 10
   TRACE PROPERTY  m(sp)  l l 10
   TRACE PROPERTY  m(mn)  w w 10
   TRACE PROPERTY  m(mn)  l l 10
   TRACE PROPERTY  md(de)  w w 10
   TRACE PROPERTY  md(de)  l l 10
   TRACE PROPERTY  m(snh)  w w 10
   TRACE PROPERTY  m(snh)  l l 10
   TRACE PROPERTY  m(sph)  w w 10
   TRACE PROPERTY  m(sph)  l l 10
   TRACE PROPERTY  m(mnh)  w w 10
   TRACE PROPERTY  m(mnh)  l l 10
   TRACE PROPERTY  md(deh)  w w 10
   TRACE PROPERTY  md(deh)  l l 10
   TRACE PROPERTY  m(2s)  w w 10
   TRACE PROPERTY  m(2s)  l l 10
   TRACE PROPERTY  m(4s)  w w 10
   TRACE PROPERTY  m(4s)  l l 10
   TRACE PROPERTY  m(h2)  w w 10
   TRACE PROPERTY  m(h2)  l l 10
   TRACE PROPERTY  m(so)  w w 10
   TRACE PROPERTY  m(so)  l l 10
   TRACE PROPERTY  ldd(i2)  w w 10
   TRACE PROPERTY  ldd(i2)  l l 10
   TRACE PROPERTY  ldd(i4)  w w 10
   TRACE PROPERTY  ldd(i4)  l l 10
   TRACE PROPERTY  lddd(dn4)  w w 10
   TRACE PROPERTY  lddd(dn4)  l l 10
   TRACE PROPERTY  ldd(xn)  w w 10
   TRACE PROPERTY  ldd(xn)  l l 10
   TRACE PROPERTY  ldd(x4)  w w 10
   TRACE PROPERTY  ldd(x4)  l l 10
   TRACE PROPERTY  ldd(ap)  w w 10
   TRACE PROPERTY  ldd(ap)  l l 10
   TRACE PROPERTY  ldd(4p)  w w 10
   TRACE PROPERTY  ldd(4p)  l l 10
   TRACE PROPERTY  ldd(ao)  w w 10
   TRACE PROPERTY  ldd(ao)  l l 10
   TRACE PROPERTY  ldd(4o)  w w 10
   TRACE PROPERTY  ldd(4o)  l l 10
   TRACE PROPERTY  ldd(sp24)  w w 10
   TRACE PROPERTY  ldd(sp24)  l l 10
   TRACE PROPERTY  ldd(sp30)  w w 10
   TRACE PROPERTY  ldd(sp30)  l l 10
   TRACE PROPERTY  ldd(sph30)  w w 10
   TRACE PROPERTY  ldd(sph30)  l l 10
   TRACE PROPERTY  ldd(sph40)  w w 10
   TRACE PROPERTY  ldd(sph40)  l l 10
   TRACE PROPERTY  ldd(snl24)  w w 10
   TRACE PROPERTY  ldd(snl24)  l l 10
   TRACE PROPERTY  ldd(snd12)  w w 10
   TRACE PROPERTY  ldd(snd12)  l l 10
   TRACE PROPERTY  ldd(snl30)  w w 10
   TRACE PROPERTY  ldd(snl30)  l l 10
   TRACE PROPERTY  ldd(snl40)  w w 10
   TRACE PROPERTY  ldd(snl40)  l l 10
   TRACE PROPERTY  ldd(snh30)  w w 10
   TRACE PROPERTY  ldd(snh30)  l l 10
   TRACE PROPERTY  ldd(snh40)  w w 10
   TRACE PROPERTY  ldd(snh40)  l l 10
   TRACE PROPERTY  mn(nn)  w w 10
   TRACE PROPERTY  mn(nn)  l l 10
   TRACE PROPERTY  mn(np)  w w 10
   TRACE PROPERTY  mn(np)  l l 10
   TRACE PROPERTY  mn(nm)  w w 10
   TRACE PROPERTY  mn(nm)  l l 10
   TRACE PROPERTY  mn(nd)  w w 10
   TRACE PROPERTY  mn(nd)  l l 10
   TRACE PROPERTY  m(op)  w w 10
   TRACE PROPERTY  m(op)  l l 10
   TRACE PROPERTY  m(s2)  w w 10
   TRACE PROPERTY  m(s2)  l l 10
   TRACE PROPERTY  m(s4)  w w 10
   TRACE PROPERTY  m(s4)  l l 10
   TRACE PROPERTY  m(vs)  w w 10
   TRACE PROPERTY  m(vs)  l l 10
   TRACE PROPERTY  ldde(e1)  w w 10
   TRACE PROPERTY  ldde(e1)  l l 10
   TRACE PROPERTY  ldde(e2)  w w 10
   TRACE PROPERTY  ldde(e2)  l l 10
   TRACE PROPERTY  ldde(e1n)  w w 10
   TRACE PROPERTY  ldde(e1n)  l l 10
   TRACE PROPERTY  ldde(e2n)  w w 10
   TRACE PROPERTY  ldde(e2n)  l l 10
   TRACE PROPERTY  ldde(ec)  w w 10
   TRACE PROPERTY  ldde(ec)  l l 10
   TRACE PROPERTY  ldde(ei)  w w 10
   TRACE PROPERTY  ldde(ei)  l l 10
   TRACE PROPERTY  ldde(ef)  w w 10
   TRACE PROPERTY  ldde(ef)  l l 10
   TRACE PROPERTY  ldde(eh)  w w 10
   TRACE PROPERTY  ldde(eh)  l l 10
   TRACE PROPERTY  j(nj)  w jft_w 10
   TRACE PROPERTY  j(nj)  l jft_l 10
   TRACE PROPERTY  d(d1)  a a 1
   TRACE PROPERTY  d(d3)  a a 1
   TRACE PROPERTY  d(d2)  a a 1
   TRACE PROPERTY  d(zn)  m m 0
   TRACE PROPERTY  c(c3)  c c 1
   TRACE PROPERTY  c(c1)  c c 1
   TRACE PROPERTY  c(c2)  c c 1
   TRACE PROPERTY  pc  c c 1
   TRACE PROPERTY  c(nc)  c c 1
   TRACE PROPERTY  r(rh)  r r 1
   TRACE PROPERTY  r(rm)  r r 1
   TRACE PROPERTY  r(no)  r r 1
   TRACE PROPERTY  r(po)  r r 1
   TRACE PROPERTY  r(rn)  r r 1
   TRACE PROPERTY  r(nr)  r r 1
   TRACE PROPERTY  r(r1)  r r 1
   TRACE PROPERTY  rw  r r 1
   TRACE PROPERTY  r(fu)  r r 1
   TRACE PROPERTY  r(r2)  r r 1
   TRACE PROPERTY  r(r3)  r r 1
   TRACE PROPERTY  r(r4)  r r 1
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
LAYOUT CELL NAME:         HCOMP
SOURCE CELL NAME:         HCOMP
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             38        38
Nets:           32938     32945    *
Instances:      82515     83421    *    M (4 pins)
Total Inst:     82515     83421
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             38        38
Nets:           27402     27409    *
Instances:      68297     68297         M (4 pins)
                  4152      4152         SM2 (4 pins)
                    48        48         SM3 (5 pins)
                     6         6         SM4 (6 pins)
                   541       541         SPM_2_1 (5 pins)
                    17        17         SPM_2_1_1 (6 pins)
                   647       647         SPM_2_2 (6 pins)
                     8         8         SPM_2_2_1 (7 pins)
                     7         7         SPM_3_1 (6 pins)
                    10        10         SPM((2+1)*2) (7 pins)
Total Inst:     73733     73733
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net 1265                                                  intadd_17_A_14_
        XU2904/o
  2    Net 440                                                   n2099
        XU3520/o
  3    Net 1249                                                  intadd_17_A_17_
        XU2897/o
  4    Net 1266                                                  intadd_17_A_15_
        XU2902/o
  5    Net X432/1269                                             n1437
        XU2722/o
  6    Net X432/901                                              n1985
        XU3406/o
  7    Net X433/810                                              intadd_17_A_16_
        XU2899/o
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:              38         38            0            0
   Nets:            27402      27409            0            0
   Instances:       32799      32799            0            0    M(sn)
                    35498      35498            0            0    M(sp)
                     4152       4152            0            0    SM2
                       48         48            0            0    SM3
                        6          6            0            0    SM4
                      541        541            0            0    SPM_2_1
                       17         17            0            0    SPM_2_1_1
                      647        647            0            0    SPM_2_2
                        8          8            0            0    SPM_2_2_1
                        7          7            0            0    SPM_3_1
                       10         10            0            0    SPM((2+1)*2)
   Total Inst:      73733      73733            0            0
o Statistics:
   1743 layout mos transistors were reduced to 394.  5 connecting nets were deleted.
     1339 mos transistors were deleted by parallel reduction.
     10 mos transistors and 5 connecting nets were deleted by split-gate reduction.
   3240 source mos transistors were reduced to 985.  5 connecting nets were deleted.
     2245 mos transistors were deleted by parallel reduction.
o Initial Correspondence Points:
   Ports:        VCC VSS HCOMP_out[15] HCOMP_out[7] HCOMP_out[5] HCOMP_out[8] HCOMP_out[12]
                 HCOMP_out[2] HCOMP_out[10] HCOMP_out[6] HCOMP_out[4] HCOMP_out[13] HCOMP_out[3]
                 HCOMP_out[11] HCOMP_out[14] HCOMP_out[9] clk_div3 HCOMP_out[0] HCOMP_out[1]
                 HCOMP_in[15] HCOMP_in[14] HCOMP_in[13] HCOMP_in[7] HCOMP_in[8] HCOMP_in[9]
                 HCOMP_in[10] HCOMP_in[11] HCOMP_in[12] HCOMP_in[1] HCOMP_in[3] HCOMP_in[2]
                 HCOMP_in[4] reset HCOMP_in[5] HCOMP_in[6] HCOMP_in[0] clk_enable clk_div2
o Matched Mosfets Which Have Been Unequally Reduced:
       X423/X1315/M3(311.270,1289.100)                           XFE_PHC131_n350/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC131_n350/MX1I6_M1I2
       X423/X1314/M3(293.070,1243.980)                           XFE_PHC594_delay_pipeline_305_/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC594_delay_pipeline_305_/MX1I6_M1I2
       X423/X1313/M3(285.270,1168.740)                           XFE_PHC658_delay_pipeline_277_/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC658_delay_pipeline_277_/MX1I6_M1I2
       X423/X1312/M3(272.270,1168.740)                           XFE_PHC644_n309/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC644_n309/MX1I6_M1I2
       X423/X1311/M3(247.570,1168.740)                           XFE_PHC615_n339/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC615_n339/MX1I6_M1I2
       X423/X1310/M3(247.570,1163.700)                           XFE_PHC493_n325/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC493_n325/MX1I6_M1I2
       X423/X1309/M3(247.570,1143.660)                           XFE_PHC477_n324/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC477_n324/MX1I6_M1I2
       X423/X1308/M3(243.670,1269.060)                           XFE_PHC479_n352/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC479_n352/MX1I6_M1I2
       X423/X1307/M3(235.870,1294.140)                           XFE_PHC593_n335/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC593_n335/MX1I6_M1I2
       X423/X1306/M3(221.570,1168.740)                           XFE_PHC485_n322/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC485_n322/MX1I6_M1I2
       X423/X1305/M3(215.070,1243.980)                           XFE_PHC272_delay_pipeline_306_/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC272_delay_pipeline_306_/MX1I6_M1I2
       X423/X1304/M3(204.670,1238.940)                           XFE_PHC588_n338/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC588_n338/MX1I6_M1I2
       X423/X1303/M3(191.670,1269.060)                           XFE_PHC596_n336/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC596_n336/MX1I6_M1I2
       X423/X1302/M3(190.370,1264.020)                           XFE_PHC598_n337/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC598_n337/MX1I6_M1I2
       X423/X1301/M3(190.370,1168.740)                           XFE_PHC433_n340/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC433_n340/MX1I6_M1I2
       X423/X1300/M3(169.570,1168.740)                           XFE_PHC264_delay_pipeline_308_/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC264_delay_pipeline_308_/MX1I6_M1I2
       X423/X1299/M3(168.270,1238.940)                           XFE_PHC599_delay_pipeline_307_/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC599_delay_pipeline_307_/MX1I6_M1I2
       X423/X1298/M3(147.470,1213.860)                           XFE_PHC620_n354/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC620_n354/MX1I6_M1I2
       X423/X1132/M3(1116.200,1163.700)                          XFE_PHC336_n460/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC336_n460/MX1I6_M1I2
       X423/X1131/M3(1098.000,1168.740)                          XFE_PHC333_n444/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC333_n444/MX1I6_M1I2
       X423/X1130/M3(1096.700,1238.940)                          XFE_PHC82_n445/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC82_n445/MX1I6_M1I2
       X423/X1129/M3(1090.200,1193.820)                          XFE_PHC80_n237/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC80_n237/MX1I6_M1I2
       X423/X1128/M3(1087.600,1213.860)                          XFE_PHC81_n461/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC81_n461/MX1I6_M1I2
       X423/X1127/M3(1082.400,1269.060)                          XFE_PHC154_n253/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC154_n253/MX1I6_M1I2
       X423/X1126/M3(938.100,1143.660)                           XFE_PHC700_n252/MX1I6_M1I2_0
       ** missing smashed mosfet **                              XFE_PHC700_n252/MX1I6_M1I2
                                         SUMMARY
Total CPU Time:      2 sec
Total Elapsed Time:  2 sec
 楼主| 发表于 2018-1-6 19:41:28 | 显示全部楼层
大神帮忙
 楼主| 发表于 2018-1-6 22:44:30 | 显示全部楼层
有人帮看下么
发表于 2018-1-7 09:21:16 | 显示全部楼层
回复 3# 13804576693
   有short或者open吗?
 楼主| 发表于 2018-1-7 10:54:56 | 显示全部楼层
回复 4# sinbad
   没有……错误都在report里了,我很不理解,为什么layout这边一个点,source那边会出现两个点……总的net数也是多七个
 楼主| 发表于 2018-1-7 11:16:46 | 显示全部楼层
再上个图吧……
发表于 2018-1-7 13:31:38 | 显示全部楼层
回复 6# 13804576693
这是short了,hight一下就看到了
 楼主| 发表于 2018-1-7 13:49:19 | 显示全部楼层
回复 7# 西山寺
是说source上那两个net 短路了么?
 楼主| 发表于 2018-1-7 13:53:06 | 显示全部楼层
我靠……我把lvs文件里后加的layout case yes和source case yes 都给注释掉了……竟然过了,大神快来给我解释一下啊……
发表于 2018-1-7 21:45:01 | 显示全部楼层
source case yes 是指netlist 要分大小寫!
當你把source case yes 註解掉,是不是同等source case no?
如果是的話,代表你有四條net大小寫不分的short在一起了,所以才會correct!
反推是Designer 把相同的net 取成了有大寫(譬如ABC),又有小寫(譬如abc)。
GMT+8, 2025-12-20 15:18 , Processed in 0.025940 second(s), 6 queries , Gzip On, Redis On.
