查看: 4410|回复: 16
[资料] A 30-GHz Class-F23 Oscillator in 28nm CMOS... Achieving 120 kHz 1/f Corner
发表于 2018-1-6 11:56:04 | 显示全部楼层 |阅读模式
A 30-GHz Class-F23 Oscillator in 28nm CMOS Using.pdf (1.5 MB , 下载次数: 145 )
Abstract—This paper presents a mmW frequency generation
stage aimed at minimizing phase noise via waveform shaping and
harmonic extraction while suppressing flicker noise upconversion
via proper harmonic terminations. A second-harmonic tank
resonance is assisted by a proposed embedded decoupling
capacitor inside a transformer for shortest and well controlled
common-mode current return path. Class-F operation with thirdharmonic
boosting and extraction techniques allow maintaining
high quality factor of a 10 GHz tank at the 30 GHz frequency
generation while providing implicit divide-by-3 functionality. The
proposed 27.3-31.2 GHz oscillator is implemented in 28-nm
CMOS. It achieves phase noise of -106 dBc/Hz at 1-MHz offset and
figure-of-merit (FoM) of -184 dB at 27.3GHz. Its flicker phasenoise
(𝟏 𝐟𝟑) corner of 120 kHz is an order-of-magnitude better
than currently achievable at mmW.
发表于 2018-1-6 18:20:20 | 显示全部楼层
Thanks
发表于 2018-1-6 18:51:58 | 显示全部楼层
A 30-GHz Class-F23 Oscillator in 28nm CMOS Using.pdf (1.5 MB)
发表于 2018-1-6 19:15:34 | 显示全部楼层
谢谢!down
发表于 2018-1-8 01:45:05 | 显示全部楼层
thansverymuch
发表于 2018-1-8 02:53:42 | 显示全部楼层
谢谢分享
发表于 2018-1-8 05:31:17 | 显示全部楼层
very interesting
发表于 2018-1-9 09:13:19 | 显示全部楼层
多谢分享 下载学习
发表于 2018-1-9 12:05:12 | 显示全部楼层
多谢分享 下载学习
发表于 2018-1-9 14:53:12 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-28 00:34 , Processed in 0.019705 second(s), 4 queries , Gzip On, Redis On.
