In ICC, first read in design, generated from DC:Reading ddc file '/home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/orcatop_data/ORCA_timingRun.ddc'.
Current design is 'ORCA'.
Linking design 'ORCA'
Using the following designs and libraries:
* (17 designs) /home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/orcatop_data/ORCA_timingRun.ddc, etc
cb13fs120_tsmc_max (library) /home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/db/sc_max.db
cb13special_max (library) /home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/db/special_max.db
cb13io320_tsmc_max (library) /home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/db/io_max.db
cb13_tsmc_memory_max (library) /home/dubeeloo/proj/iccdp2011.6/zroute/zroute_training.1.0/ref/db/rams_max.db
Info: Creating auto CEL.
Error: Can not create instance master 'ram32x32' in FRAM view. (MWDC-001)
How do I correct these errors? I did check the loaded libraries are consistent with DC run, though |
