查看: 2635|回复: 0
[求助] power ground connection
发表于 2017-8-11 02:47:34 | 显示全部楼层 |阅读模式
I am running floor planning in ICCafter created floorplan, then  derive_pg_connection I got this good indication:
Information: connected 8778 power ports and 8778 ground ports
connected!
but after the follow a few commands:
create_fp_placement
create_rectilinear_rings
create_power_straps
the verify_pg_nets gave me these: did I break anything?
Checking [VSS]:
        ERROR: There are 42 floating shapes
        ERROR: There are 8775 floating pins
Checking [VDD]:
        ERROR: There are 35 floating shapes
        ERROR: There are 8772 floating pins
Then after
preroute_standard_cells
verify_pg_nets reported these:
Checking [VSS]:        ERROR: There are 20 floating shapes        ERROR: There are 92 floating pinsChecking [VDD]:        ERROR: There are 18 floating shapes        ERROR: There are 90 floating pinsChecked 2 nets, 2 have Errors
Please help, I don't know if it is normal at this stage: before placement, CTS, and route
GMT+8, 2025-9-15 17:24 , Processed in 0.347391 second(s), 3 queries , Gzip On, Redis On.
