查看: 2401|回复: 0
[求助] please help for floorplanning
发表于 2017-7-30 14:15:10 | 显示全部楼层 |阅读模式
in ICC floorplanning run
After import_designs successfully,
import_designs -format verilog -top $TOP_design -cel $TOP_design {../ref/design_data/ORCA_timingRun.v}
I tried to create floorplan:
create_floorplan -control_type boundary -start_first_row -left_io2core 2.96 -bottom_io2core 2.96 -right_io2core 2.96 -top_io2core 2.96 -keep_io_place
and I got the following:
Error: There is no net in this design. Please fix this problem.  (APL-075)
Error: Planner run through unsuccessful.  (APLUI-102)
I don't understand this, the verilog netlist, ORCA_timingRun.v should have nets, should be a lot of those,  what can I fix, please help
GMT+8, 2025-9-19 08:10 , Processed in 0.906042 second(s), 4 queries , Gzip On, Redis On.
