查看: 5566|回复: 26
[求助] 求書:Overvoltage Protection of Low-Voltage Systems
发表于 2017-7-10 00:23:22 | 显示全部楼层 |阅读模式
求書:Overvoltage Protection of Low-Voltage Systems (IEE Power & Energy Series, 33)
Author(s):Peter Hasse
Product Description: This highly illustrated and practical book surveys techniques available to protect LV equipment and systems from lightning strikes and other surges. After examining the physical origins and effects of these phenomena, it concentrates on the components and applications of protective measures and systems, placed in the context of current IEC and VDE standards. This unique book provides the reader with a thorough background in almost every aspect of lightning and its impact on electrical and electronic equipment. The contents range from basic discharge processes in air through transient electromagnetic field generation and interaction with overhead lines and underground cables, to lightning protection and testing techniques. This book is of value to anyone designing, installing or commissioning equipment, which needs to be secured against lightning strikes, as well as being a sound introduction to research students working in the field.
发表于 2017-7-10 13:36:43 | 显示全部楼层
Peter Hasse Overvoltage Protection of Low Voltage Systems, Second Edition.pdf (13.85 MB , 下载次数: 416 ) 回复 1# Capricorn0115
发表于 2017-7-10 16:43:15 | 显示全部楼层
not this book
发表于 2017-7-10 17:50:23 | 显示全部楼层
thanksthanks
 楼主| 发表于 2017-7-10 19:18:43 | 显示全部楼层
回复 2# Chaumont
Thanks~
发表于 2017-7-10 21:19:13 | 显示全部楼层
kankan
发表于 2017-7-11 08:34:48 | 显示全部楼层
感謝!!!
发表于 2017-7-11 08:37:32 | 显示全部楼层
回复 3# david.yih
   没找到另外的版本啊
发表于 2017-7-11 18:13:54 | 显示全部楼层
kan e kan
发表于 2017-7-12 12:36:05 | 显示全部楼层
非常感謝~~~~
GMT+8, 2025-12-27 04:26 , Processed in 0.028993 second(s), 4 queries , Gzip On, Redis On.
