查看: 1114|回复: 0
[招聘] 【Cadence上海】招聘高级产品验证工程师/产品工程师-数字后端
发表于 2017-5-25 16:04:25 | 显示全部楼层 |阅读模式
投递方式:
If you have interest , PLS send your update CV to job_china@cadence.com(简历投递格式:姓名+学校+申请职位+工作地点)
接受2017年优秀应届硕士、博士生。
1.   Lead Product Validation Engineer(R20775)
Position Description:
1. Identify timing sign-off challenges in complex SOC designs and the correlation issues between preRoute & postroute in advacned process nodes.
2. Proactively provide extraction & timing development suggestions to R&D.
3. Build up parasitics & timing analysis expertise and deliver support to field team and customers whenever needed.
4. Required to acquire expertise and ownership over existing product components as well as develop brand new product features.
Position Requirements:
1. Bachelor with 5 years related experience or Master with at least 3 years related experience in design house, FAB or EDA company.
2. Rich experience in IC design flow (front-end or back-end).
3. Experience in advanced nodes designs or knowledge in timing closure is a strong plus.
4. Good Unix System knowledge and script skill of TCL/TK/CSH/PERL.
5. Excellent capability of self-learning, problem solving skills.
6. Being proactive and self-motivated.
7. Strong leadership.
8. Good written English and oral English is a strong plus.
2.   Lead Product Validation Engineer(R21441)
1. Identify timing sign-off challenges in complex SOC designs and the correlation issues between preRoute & postroute in advanced process nodes.
2. Proactively provide STA development suggestions to R&D.
3. Build up extraction & STA expertise and deliver support to field team and customers whenever needed.
7. strong leadership.
3.   Lead Product Validation Engineer(R21441)
The engineer will work on Innovus QOR validation. Monitor flow QOR in weekly
basis, debug QOR issues deeply across whole implementation flow from placement to CTS and to post route optimization. Also need to debug synthesis flow depending on project demand. Also the engineer need to write scripts to improve efficiency.
1. Master degree or bachelor degree with 2~3 years working experience.
2. Solid background knowledge in digital backend design.
3. Be familiar with Linux system, and scripting skills with TCL or PERL or Shell.
4. Patient, and good responsibility.
5. Good communication in English and Chinese.
4.   Product Validation Engineer II(R20893,R21336)
This engineer will work in Encounter block implementation product validation team. The responsibilities include:
1. Assist in Cadence EDI development and validation Validate and maintain comprehensive unit and flow test cases for Encounter Digital Implementation System.
2. Develop test suites of the new features of EDI functions.
1. MS of EE/CS.
2. Digital IC design knowledge is necessary, statistic timing analysis knowledge is a strong plus.
3. Unix System knowledge, vi/TCL/TK/CSH/Perl will be plus.
4. Good communication in English and Chinese, good confidence and self-motivation.
5.   Product Validation Engineer II(R21383)
This PV engineer mainly works for advanced STA (Static Timing Analysis) and
DelayCal features validation:
1. Qualify delay calculation and timing analysis result in Innovus system.
2. Maintain comprehensive regression suites for monitoring STA & delayCal stabilities.
3. Upgrading regression cases to use advanced design node data and check the impact.
2. Solid background knowledge in digital backend design, knowledge in STA or delayCal is a strong plus.
6.   Product Validation Engineer II(R21442, R21408)
1. Assist in Cadence hierarchical and DB areas developement and validation.
2. Validate and maintain comprehensive hierarchical/Database unit and flow test cases for Encounter Digital Impelementation System.
3. Develope testsuites of the new features of hierarchical and Database functional/flow solution.
1. MS in EE or related majors.
7.   Product Engineer II(R21420)
1. Design and develop cutting edge technologies of Encounter/Innovus, to address future and immediate customer requirements
2. Collaborate with R&D and production validation team to deliver high quality software release
3. Provide technical support and trainings for Cadence AP business
4. Communicate with global cross-function team to create technical solutions and involve in customer engagement
1. CS/EE MS with 1+ years IC physical design experience.
2. Be familiar with IC back-end design flow, including place, route, clock tree synthesis and timing optimization.
3. Strong analysis/debug capability for technical issues.
4. Good team spirit and be able to work under pressure.
5. Good communication skill in English
8.   Lead Product Engineer
Job Description:
1. Design and develop cutting edge technologies of Encounter/Innovus, to address future and immediate customer requirements.
3. Provide technical support and trainings for Cadence AP business.
4. Communicate with global cross-function team to create technical solutions and involve in customer engagement.
1. CS/EE MS with 3+ years or PhD with 1+ years IC physical design experience.
5. Good communication skill in English.
9.   Principal Product Engineer(R21100)
Job Description:
1. Design and develop power planning and power routing features in Innovus, to address future and immediate customer requirements.
2. Collaborate with R&D for the technical specification of new enhancements. Work with production validation team to deliver high quality software release.
1. CS/EE MS with 5+ years or PhD with 3+ years IC physical design experience.
2. Power planning, routing or DRC fixing experience in design tape-out.
3. Be familiar with IC back-end design flow. Knowledge of LEF/DEF and advanced process node DRC rule is a plus.
4. Strong analysis/debug capability for technical issues.
5. Good team spirit and be able to work under pressure.
6. Good communication skill in English.
GMT+8, 2025-10-31 12:22 , Processed in 0.013756 second(s), 4 queries , Gzip On, Redis On.
