查看: 19784|回复: 17
[求助] verdi安装不成功 运行license出问题
发表于 2017-4-12 21:47:14 | 显示全部楼层 |阅读模式
悬赏500资产未解决
按坛子里提供的安装说明,都试过了,仍报license问题。
ubuntu@ubuntu:/opt/EDA_Tools/springsoft/lic$ lmgrd -c novas.dat
19:34:48 (lmgrd)   Please Note:
19:34:48 (lmgrd)
19:34:48 (lmgrd)   This log is intended for debug purposes only.
19:34:48 (lmgrd)   In order to capture accurate license
19:34:48 (lmgrd)   usage data into an organized repository,
19:34:48 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
19:34:48 (lmgrd)   software license administration  solution,
19:34:48 (lmgrd)   FLEXnet Manager, to  readily gain visibility
19:34:48 (lmgrd)   into license usage data and to create
19:34:48 (lmgrd)   insightful reports on critical information like
19:34:48 (lmgrd)   license availability and usage. FLEXnet Manager
19:34:48 (lmgrd)   can be fully automated to run these reports on
19:34:48 (lmgrd)   schedule and can be used to track license
19:34:48 (lmgrd)   servers and usage across a heterogeneous
19:34:48 (lmgrd)   network of servers including Windows NT, Linux
19:34:48 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
19:34:48 (lmgrd)   www.acresso.com for more details on how to
19:34:48 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
19:34:48 (lmgrd)   for your enterprise.
19:34:48 (lmgrd)
19:34:48 (lmgrd) -----------------------------------------------
19:34:48 (lmgrd)
19:34:48 (lmgrd)
19:34:48 (lmgrd) FLEXnet Licensing (v11.6.0.0 build 60117 amd64_re3) started on ubuntu (linux) (4/12/2017)
19:34:48 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
19:34:48 (lmgrd) US Patents 5,390,297 and 5,671,412.
19:34:48 (lmgrd) World Wide Web:  http://www.acresso.com
19:34:48 (lmgrd) License file(s): novas.dat
19:34:48 (lmgrd) lmgrd tcp-port 27004
19:34:48 (lmgrd) Starting vendor daemons ...
19:34:48 (lmgrd) Started snslmgrd (internet tcp_port 56560 pid 2511)
19:34:48 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 amd64_re3
19:34:49 (snslmgrd) EXPIRED: DataExpansion
19:34:49 (snslmgrd) EXPIRED: DataExpansionCoverage
19:34:49 (snslmgrd) EXPIRED: DataExpansionSim
19:34:49 (snslmgrd) EXPIRED: DataReplay
19:34:49 (snslmgrd) EXPIRED: DataReplaySim
19:34:49 (snslmgrd) EXPIRED: Debussy
19:34:49 (snslmgrd) EXPIRED: Debussy_shared
19:34:49 (snslmgrd) EXPIRED: EssentialSignalAnalysis
19:34:49 (snslmgrd) EXPIRED: Extraction
19:34:49 (snslmgrd) EXPIRED: FLE_main
19:34:49 (snslmgrd) EXPIRED: FL_cosim_run
19:34:49 (snslmgrd) EXPIRED: FL_ice_run
19:34:49 (snslmgrd) EXPIRED: FL_multichip_partition
19:34:49 (snslmgrd) EXPIRED: FL_recalc
19:34:49 (snslmgrd) EXPIRED: Gaia
19:34:49 (snslmgrd) EXPIRED: Gate2LayoutCorrelation
19:34:49 (snslmgrd) EXPIRED: Gate2RTLCorrelation
19:34:49 (snslmgrd) EXPIRED: Gsim_dump_advance
19:34:49 (snslmgrd) EXPIRED: Gsim_dump_basic
19:34:49 (snslmgrd) EXPIRED: Gsim_framework_advance
19:34:49 (snslmgrd) EXPIRED: Gsim_framework_basic
19:34:49 (snslmgrd) EXPIRED: Gsim_snapshot
19:34:49 (snslmgrd) EXPIRED: Gsim_wave
19:34:49 (snslmgrd) EXPIRED: GuidedTraceAnalysis
19:34:49 (snslmgrd) EXPIRED: HDL2SC_mixed
19:34:49 (snslmgrd) EXPIRED: HDL2SC_verilog
19:34:49 (snslmgrd) EXPIRED: HDL2SC_vhdl
19:34:49 (snslmgrd) EXPIRED: Laker_AMS
19:34:49 (snslmgrd) EXPIRED: Laker_L1
19:34:49 (snslmgrd) EXPIRED: Laker_L2
19:34:49 (snslmgrd) EXPIRED: Laker_L3
19:34:49 (snslmgrd) EXPIRED: Laker_T1
19:34:49 (snslmgrd) EXPIRED: Laker_T1_LE
19:34:49 (snslmgrd) EXPIRED: Laker_Viewer
19:34:49 (snslmgrd) EXPIRED: Laker_iDRC
19:34:49 (snslmgrd) EXPIRED: Laker_iLVS
19:34:49 (snslmgrd) EXPIRED: Reusner
19:34:49 (snslmgrd) EXPIRED: RtlGateCorrelation
19:34:49 (snslmgrd) EXPIRED: SKDB_Import
19:34:49 (snslmgrd) EXPIRED: SilVE
19:34:49 (snslmgrd) EXPIRED: Siloti
19:34:49 (snslmgrd) EXPIRED: Siloti_fe
19:34:49 (snslmgrd) EXPIRED: Siloti_o2
19:34:49 (snslmgrd) EXPIRED: SimVE
19:34:49 (snslmgrd) EXPIRED: TLM_Synthesis
19:34:49 (snslmgrd) EXPIRED: TestDesignCorrelation
19:34:49 (snslmgrd) EXPIRED: TestVE
19:34:49 (snslmgrd) EXPIRED: TimingAnalysis
19:34:49 (snslmgrd) EXPIRED: Verdi
19:34:49 (snslmgrd) EXPIRED: WhatIfAnalysis
19:34:49 (snslmgrd) EXPIRED: hdlin
19:34:49 (snslmgrd) EXPIRED: hdlin_mixed
19:34:49 (snslmgrd) EXPIRED: hdlin_verilog
19:34:49 (snslmgrd) EXPIRED: hdlin_vhdl
19:34:49 (snslmgrd) EXPIRED: nAnalyzer
19:34:49 (snslmgrd) EXPIRED: nBench
19:34:49 (snslmgrd) EXPIRED: nClock
19:34:49 (snslmgrd) EXPIRED: nCompare
19:34:49 (snslmgrd) EXPIRED: nECO
19:34:49 (snslmgrd) EXPIRED: nMonitor
19:34:49 (snslmgrd) EXPIRED: nProp
19:34:49 (snslmgrd) EXPIRED: nSchema
19:34:49 (snslmgrd) EXPIRED: nSchemaOnly
19:34:49 (snslmgrd) EXPIRED: nState
19:34:49 (snslmgrd) EXPIRED: nTiming
19:34:49 (snslmgrd) EXPIRED: nTrace
19:34:49 (snslmgrd) EXPIRED: nTree
19:34:49 (snslmgrd) EXPIRED: nWave
19:34:49 (snslmgrd) EXPIRED: nlcc
19:34:49 (snslmgrd) EXPIRED: tSchema
19:34:49 (snslmgrd) EXPIRED: turboSchema
19:34:49 (snslmgrd) EXPIRED: turboState
19:34:49 (snslmgrd) EXPIRED: turboTracer
19:34:49 (snslmgrd) EXPIRED: turboWave
19:34:49 (snslmgrd) License server system started on ubuntu
19:34:49 (snslmgrd) No features to serve, exiting
19:34:49 (snslmgrd) EXITING DUE TO SIGNAL 36 Exit reason 4
19:34:49 (lmgrd) snslmgrd exited with status 36 (No features to serve)
19:34:49 (lmgrd) snslmgrd daemon found no features.  Please correct
19:34:49 (lmgrd) license file and re-start daemons.
19:34:49 (lmgrd)
19:34:49 (lmgrd) This may be due to the fact that you are using
19:34:49 (lmgrd) a different license file from the one you expect.
19:34:49 (lmgrd) Check to make sure that:
19:34:49 (lmgrd) novas.dat
19:34:49 (lmgrd) is the license file you want to use.
19:34:49 (lmgrd)
运行Verdi后检测不到license
@ubuntu:~/Desktop$ verdi
logDir = /home/liu/Desktop/verdiLog
Verdi Release Verdi3_2013.07 (Linux x86_64/64bit) 07/05/2013
(C) 2009 - 2013 by Synopsys, Inc.
www.synopsys.com
This computer program constitutes or contains trade secrets and confidential
information of Synopsys, Inc. or its licensors. This computer program is
protected by copyright law and international treaties.
rcfile = /opt/EDA_Tools/springsoft/Verdi/Verdi3-2013.07/etc/novas.rc
guiConfFile = /home/liu/novas.conf
Could not checkout Verdi license. Use Verdi -licdebug for more information.
求大神帮忙
虚拟机版本是Ubuntu14.04 Verdi版本是2013.07
 楼主| 发表于 2017-4-13 10:11:35 | 显示全部楼层
自己顶一下  求大神们解答!!!
发表于 2017-4-19 04:24:51 | 显示全部楼层
Seems that your license is expired.
Make sure you choose the right one.
 楼主| 发表于 2017-4-24 16:47:10 | 显示全部楼层
回复 3# xjw8626022
   you are right!!! i changed the license's date,and then it worked!!!
发表于 2019-6-28 11:44:39 | 显示全部楼层
yuanhong96 发表于 2017-4-24 16:47
回复 3# xjw8626022
打扰一下,怎么修改日期?随便设置?
发表于 2020-7-9 13:37:28 | 显示全部楼层
大家最后怎么解决的?
我也遇到了这个问题,拷贝的别人正常的虚拟机之后在我这里还是打不开
发表于 2021-1-31 17:30:09 | 显示全部楼层
发飙的蝼蚁 发表于 2020-7-9 13:37
大家最后怎么解决的?
我也遇到了这个问题,拷贝的别人正常的虚拟机之后在我这里还是打不开 ...
大哥请问你解决了这个问题吗,我其他的软件都没问题,就verdi启动报错,跟这一样
发表于 2021-2-3 21:09:41 | 显示全部楼层
抱歉,当时没有解决这个问题
发表于 2021-2-21 22:15:24 | 显示全部楼层
应该是verdi的license过期了 需要更换license
发表于 2021-2-24 19:08:02 | 显示全部楼层
重新gen一个license吧,这个license貌似做一次只能质保一年。可以考虑换成verdi2014或以后的版本,然后跟synopsys的license统一了,目前按论坛里提供的破解方案可以用到2030年
GMT+8, 2025-12-26 05:14 , Processed in 0.024468 second(s), 7 queries , Gzip On, Redis On.
