查看: 21633|回复: 112
LDO IEEE论文合集
发表于 2007-6-14 18:17:01 | 显示全部楼层 |阅读模式
LDO IEEE论文合集
我手上有许多LDO的资料,大约几百兆,发不完,有需要的朋友请留个联系方式吧
A 150mA Low Noise, High PSRR Low-Dropout.pdf
A Capacitor-Free CMOS Low-Dropout Regulator.pdf
A Current-Mode DC-DC Buck Converter with High Stability Independent of Load and Supply Voltage.pdf
A frequency compensation scheme for LDO voltage regulators.pdf
A Linear LDO Regulator with Modified NMCF Frequency Compensation Independent of Off-chip Capacitor and ESR.pdfA Low Dropout, CMOS Regulator with High PSR over Wideband Frequencies.pdf
A Low Noise, High Power Supply Rejection Low Dropout Regulator for Wireless System-on-Chip Applications.pdf
A Low-dropout Regulator with Unconditional.pdf
A Low-Noise Low-Drift Transducer ADC.pdf
A low-voltage, low quiescent current, low drop-out regulator.pdf
a multi-mode ldo-based .pdf
A Power Efficient and Fast Transient Response Low Drop-Out Regulator in Standard CMOS Process.pdf
A robust frequency compensation scheme for ldo regulators.pdf
All CMOS Low Drop-Out Regulator with Large Supply Currents for System using Li-ion Battery.pdf
Analysis and design of monolithic,High PSR, Linear Regulators for soc applications.pdf
Analysis and Design of Voltage Controlled Current Source for LDO Frequency Compensation.pdf
Analysis of low-dropout regulator topologies for low-voltage regulation.pdf
ldo.part01.rar
1.81 MB, 下载次数: 635 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ldo.part02.rar
1.81 MB, 下载次数: 1060 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-14 19:15:04 | 显示全部楼层
谢谢!支持,鼓励。楼主挑好的上传吧!
发表于 2007-7-3 19:01:20 | 显示全部楼层
强烈支持楼主的做法
发表于 2007-7-3 22:22:53 | 显示全部楼层
476830347
搂住好样的
发表于 2007-7-10 14:09:52 | 显示全部楼层
楼主好同志啊
发给俺一份吧!!!
hawk3130@126.com
thanks
发表于 2007-7-12 15:53:12 | 显示全部楼层
楼主万岁,发给我一份谢谢
wangjianping4213@126.com
发表于 2007-7-17 08:43:17 | 显示全部楼层
Thanks for your sharing!!!
发表于 2007-7-17 08:45:17 | 显示全部楼层
so much material .Support!
发表于 2007-7-17 14:53:41 | 显示全部楼层
谢谢楼主。
yxu@winbond.com
发表于 2007-8-16 09:13:15 | 显示全部楼层
楼主呀,建议把东西上传到讯雷或者eMule之类的服务器上,然后告诉大家地方.
GMT+8, 2025-12-30 00:28 , Processed in 0.027462 second(s), 7 queries , Gzip On, Redis On.
