查看: 3827|回复: 5
PCB词汇
发表于 2007-6-14 02:02:48 | 显示全部楼层 |阅读模式
printed circuit 印制电路
printed wiring 印制线路
printed board 印制板
printed circuit board 印制板电路
printed wiring board 印制线路板
printed component 印制元件
printed contact 印制接点
printed board assembly 印制板装配
board 板
rigid printed board 刚性印制板
flexible printed circuit 挠性印制电路
flexible printed wiring 挠性印制线路
flush printed board 齐平印制板
metal core printed board 金属芯印制板
metal base printed board 金属基印制板
mulit-wiring printed board 多重布线印制板
molded circuit board 模塑电路板
discrete wiring board 散线印制板
micro wire board 微线印制板
buile-up printed board 积层印制板
surface laminar circuit 表面层合电路板
B2it printed board 埋入凸块连印制板
chip on board 载芯片板
buried resistance board 埋电阻板
mother board 母板
daughter board 子板
backplane 背板
bare board 裸板
copper-invar-copper board 键盘板夹心板
dynamic flex board 动态挠性板
static flex board 静态挠性板
break-away planel 可断拼板
cable 电缆
flexible flat cable (FFC) 挠性扁平电缆
membrane switch 薄膜开关
hybrid circuit 混合电路
thick film 厚膜
thick film circuit 厚膜电路
thin film 薄膜
thin film hybrid circuit 薄膜混合电路
interconnection 互连
conductor trace line 导线
flush conductor 齐平导线
transmission line 传输线
crossover 跨交
edge-board contact 板边插头
stiffener 增强板
substrate 基底
real estate 基板面
conductor side 导线面
component side 元件面
solder side 焊接面
printing 印制
grid 网格
pattern 图形
conductive pattern 导电图形
non-conductive pattern 非导电图形
legend 字符
mark 标志
base material 基材
laminate 层压板
metal-clad bade material 覆金属箔基材
copper-clad laminate (CCL) 覆铜箔层压板
composite laminate 复合层压板
thin laminate 薄层压板
basis material 基体材料
prepreg 预浸材料
bonding sheet 粘结片
preimpregnated bonding sheer 预浸粘结片
epoxy glass substrate 环氧玻璃基板
mass lamination panel 预制内层覆箔板
core material 内层芯板
bonding layer 粘结层
film adhesive 粘结膜
unsupported adhesive film 无支撑胶粘剂膜
cover layer (cover lay) 覆盖层
stiffener material 增强板材
copper-clad surface 铜箔面
foil removal surface 去铜箔面
unclad laminate surface 层压板面
base film surface 基膜面
adhesive faec 胶粘剂面
plate finish 原始光洁面
matt finish 粗面
length wise direction 纵向
cross wise direction 模向
cut to size panel 剪切板
ultra thin laminate 超薄型层压板
A-stage resin A阶树脂
B-stage resin B阶树脂
C-stage resin C阶树脂
epoxy resin 环氧树脂
phenolic resin 酚醛树脂
polyester resin 聚酯树脂
polyimide resin 聚酰亚胺树脂
bismaleimide-triazine resin 双马来酰亚胺三嗪树脂
acrylic resin 丙烯酸树脂
melamine formaldehyde resin 三聚氰胺甲醛树脂
polyfunctional epoxy resin 多官能环氧树脂
brominated epoxy resin 溴化环氧树脂
epoxy novolac 环氧酚醛
fluroresin 氟树脂
silicone resin 硅树脂
silane 硅烷 polymer 聚合物
amorphous polymer 无定形聚合物
crystalline polamer 结晶现象
dimorphism 双晶现象
copolymer 共聚物
synthetic 合成树脂
thermosetting resin 热固性树脂
thermoplastic resin 热塑性树脂
photosensitive resin 感光性树脂
epoxy value 环氧值
dicyandiamide 双氰胺
binder 粘结剂
adesive 胶粘剂
curing agent 固化剂
flame retardant 阻燃剂
opaquer 遮光剂
plasticizers 增塑剂
unsatuiated polyester 不饱和聚酯
polyester 聚酯薄膜
polyimide film (PI) 聚酰亚胺薄膜
polytetrafluoetylene (PTFE) 聚四氟乙烯
reinforcing material 增强材料
glass fiber 玻璃纤维
E-glass fibre E玻璃纤维
D-glass fibre D玻璃纤维
S-glass fibre S玻璃纤维
glass fabric 玻璃布
non-woven fabric 非织布
glass mats 玻璃纤维垫
yarn 纱线
filament 单丝
strand 绞股
weft yarn 纬纱
warp yarn 经纱
denier 但尼尔
warp-wise 经向
thread count 织物经纬密度
weave structure 织物组织
plain structure 平纹组织
grey fabric 坏布
woven scrim 稀松织物
bow of weave 弓纬
end missing 断经
mis-picks 缺纬
bias 纬斜
crease 折痕
waviness 云织
fish eye 鱼眼
feather length 毛圈长
mark 厚薄段
split 裂缝
twist of yarn 捻度
size content 浸润剂含量
size residue 浸润剂残留量
finish level 处理剂含量
size 浸润剂
couplint agent 偶联剂
finished fabric 处理织物
polyarmide fiber 聚酰胺纤维
aromatic polyamide paper 聚芳酰胺纤维纸
breaking length 断裂长
height of capillary rise 吸水高度
wet strength retention 湿强度保留率
whitenness 白度 ceramics 陶瓷
conductive foil 导电箔
copper foil 铜箔
rolled copper foil 压延铜箔
annealed copper foil 退火铜箔
thin copper foil 薄铜箔
adhesive coated foil 涂胶铜箔
resin coated copper foil 涂胶脂铜箔
composite metallic material 复合金属箔
carrier foil 载体箔
invar 殷瓦
foil profile 箔(剖面)轮廓
shiny side  光面
matte side  粗糙面
treated side  处理面
stain proofing  防锈处理
double treated foil  双面处理铜箔
shematic diagram 原理图
logic diagram 逻辑图
printed wire layout 印制线路布设
master drawing 布设总图
computer aided drawing 计算机辅助制图
computer controlled display 计算机控制显示
placement 布局
routing 布线
layout 布图设计
rerouting 重布
simulation 模拟
logic simulation 逻辑模拟
circit simulation 电路模拟
timing simulation 时序模拟
modularization 模块化
layout effeciency 布线完成率
MDF databse 机器描述格式数据库
design database 设计数据库
design origin 设计原点
optimization (design) 优化(设计)
predominant axis 供设计优化坐标轴
table origin 表格原点
mirroring 镜像
drive file 驱动文件
intermediate file 中间文件
manufacturing documentation 制造文件
queue support database 队列支撑数据库
component positioning 元件安置
graphics dispaly 图形显示
scaling factor 比例因子
scan filling 扫描填充
rectangle filling 矩形填充
region filling 填充域
physical design 实体设计
logic design 逻辑设计
logic circuit 逻辑电路
hierarchical design 层次设计
top-down design 自顶向下设计
bottom-up design 自底向上设计
net 线网
digitzing 数字化
design rule checking 设计规则检查
router (CAD) 走(布)线器
net list 网络表
subnet 子线网
objective function 目标函数
post design processing (PDP) 设计后处理
interactive drawing design 交互式制图设计
cost metrix 费用矩阵
engineering drawing 工程图
block diagram 方块框图
moze 迷宫
component density 元件密度
traveling salesman problem 回售货员问题
degrees freedom 自由度
out going degree 入度
incoming degree 出度
manhatton distance 曼哈顿距离
euclidean distance 欧几里德距离
network 网络
array 阵列
segment 段
logic 逻辑
logic design automation 逻辑设计自动化
separated time 分线
separated layer 分层
definite sequence 定顺序
conduction (track) 导线(通道)
conductor width 导线(体)宽度
conductor spacing 导线距离
conductor layer 导线层
conductor line/space 导线宽度/间距
conductor layer No.1 第一导线层
round pad 圆形盘
square pad 方形盘
diamond pad 菱形盘
oblong pad 长方形焊盘
bullet pad 子弹形盘
teardrop pad 泪滴盘
snowman pad 雪人盘
V-shaped pad V形盘
annular pad 环形盘
non-circular pad 非圆形盘
isolation pad 隔离盘
monfunctional pad 非功能连接盘
offset land 偏置连接盘
back-bard land 腹(背)裸盘
anchoring spaur 盘址
land pattern 连接盘图形
land grid array 连接盘网格阵列
annular ring 孔环
component hole 元件孔
mounting hole 安装孔
supported hole 支撑孔
unsupported hole 非支撑孔
via 导通孔
plated through hole (PTH) 镀通孔
access hole 余隙孔
blind via (hole) 盲孔
buried via hole 埋孔
buried blind via 埋,盲孔
any layer inner via hole 任意层内部导通孔
all drilled hole 全部钻孔
toaling hole 定位孔
landless hole 无连接盘孔
interstitial hole 中间孔
landless via hole 无连接盘导通孔
pilot hole 引导孔
terminal clearomee hole 端接全隙孔
dimensioned hole 准尺寸孔
via-in-pad 在连接盘中导通孔
hole location 孔位
hole density 孔密度
hole pattern 孔图
drill drawing 钻孔图
assembly drawing 装配图
datum referan 参考基准
发表于 2007-6-21 05:44:04 | 显示全部楼层
非常高兴!
发表于 2008-1-11 17:52:10 | 显示全部楼层
谢谢分享
发表于 2008-2-10 09:25:57 | 显示全部楼层
that's good enough
头像被屏蔽
发表于 2008-3-4 10:01:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2008-4-7 19:09:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-10-19 17:22 , Processed in 0.022012 second(s), 6 queries , Gzip On, Redis On.
