查看: 2167|回复: 0
silvaco光刻问题···求助
发表于 2017-3-7 21:49:20 | 显示全部楼层 |阅读模式
go athena
set lay_left=-0.5
set lay_right=0.5
illumination g.line
illum.filter clear.fil circle sigma=0.38
projection na=.54
pupil.filter clear.fil circle
layout lay.clear x.lo=-2 z.lo=-3 x.hi=$lay_left z.hi=3
layout  x.lo=$lay_right z.lo=-3 x.hi=2 z.hi=3
image clear win.x.lo=-1 win.z.lo=-0.5 win.x.hi=1 win.z.hi=0.5 dx=0.05 one.d
structure outfile=mask.str intensity mask
tonyplot mask.str
line x loc=-2  spac=0.05
line x loc=0  spac=0.05
line x loc=2  spac=0.05
line y loc=0  spac=0.05
line y loc=2  spac=0.2
init silicon orient=100 c.boron=1e15 two.d
deposit nitride thick=0.035 div=5
deposit name.resist=AZ1350J thick=.8 divisions=30
rate.dev name.resist=AZ1350J i.line c.dill=0.018
structure outfile=preoptolith.str
tonyplot preoptolith.str
expose  dose=240.0 num.refl=10
bake time=30 temp=100
develop kim time=60 steps=6 substeps=24
structure outfile=optolith.str
tonyplot optolith.str
运行上述程序到标红处就运行不了,显示
The structure has been deleted. The program cannot continue.
是怎莫回事,求助!
GMT+8, 2025-9-14 08:59 , Processed in 0.013684 second(s), 6 queries , Gzip On, Redis On.
