查看: 5975|回复: 8
[求助] 无法 attach tech library
发表于 2017-3-7 18:34:18 | 显示全部楼层 |阅读模式
悬赏50资产未解决
redhat 6.8
IC616 + MMSIM141
NCSU CDK 1.6
附加 tech lib 报错
*WARNING* ddGetOAObject: OA Exception is: 'Access to library is denied for read; need to acquire access first'
*WARNING* Attach failed!
用spectre仿真时
Error found by spectre during circuit read-in.
    ERROR (SFE-23): "input.scs" 12: The instance `N0' is referencing an undefined model or subcircuit, `ami06N'. Either include the file containing the definition of `ami06N', or define `ami06N' before running the simulation.
已经
chmod -R 777 /opt/Cadence
chmod -R 777 ~/ncsu-cdk-1.6.0.beta
所有者也都改了
请问怎么解决,或者怎么用命令行附加 tech lib 看看具体错误
 楼主| 发表于 2017-3-7 21:31:37 | 显示全部楼层
顶!!!
 楼主| 发表于 2017-3-7 22:12:20 | 显示全部楼层
大神们帮个忙,多谢
 楼主| 发表于 2017-3-8 07:39:02 | 显示全部楼层
没有 tech lib 很棘手啊!!再顶!
 楼主| 发表于 2017-3-8 12:02:35 | 显示全部楼层
再顶再顶再顶!!!!!
 楼主| 发表于 2017-3-8 15:57:41 | 显示全部楼层
求大神
发表于 2017-3-8 17:11:57 | 显示全部楼层
回复 6# intevidia
   在CIW菜单里面有个 tools-> technology file manager -> attach这个可以用做attach
发表于 2020-12-27 21:21:32 | 显示全部楼层
rfham 发表于 2017-3-8 17:11
回复 6# intevidia
多谢大佬!,这个可用于建库时候没attach tech file,之后又需要attach的情况。
发表于 2023-7-5 13:29:52 | 显示全部楼层
回复 6# intevidia
学习了
GMT+8, 2025-12-23 15:40 , Processed in 0.019589 second(s), 5 queries , Gzip On, Redis On.
