查看: 5998|回复: 5
[求助] 版图drc 问题,这段错误是什么意思?
发表于 2017-3-6 23:16:05 | 显示全部楼层 |阅读模式
SP.10. Enclosure of a SP region beyond a P-Well pick-up P+AA region is >= 0.02um
if the distance between P+AA and N-Well >=0.43m
SP.11. Enclosure of a SP region beyond a P-Well pick-up P+AA region is >= 0.18um
if the distance between P+AA and N-Well < 0.43m
c. To obey this rule and SP.3 simultaneously,
P+ pick-up AA to SN active AA minimum spacing must be increased to 0.44um
d. To obey this rule and SP.5 simultaneously,
P+ pick-up AA to SN pick-up AA minimum spacing must be increased to 0.36um
发表于 2017-3-7 15:02:06 | 显示全部楼层
这个是检查在NWELL内外关于P Implant注入的一些rule
 楼主| 发表于 2017-3-10 21:57:08 | 显示全部楼层
回复 2# richardguo
   感觉这里的pick-up比较让人难以理解!
 楼主| 发表于 2017-3-11 15:11:59 | 显示全部楼层
做DRC有个错误:“DNW must be surrounded by NW”, 那DNW和NW重合的情况算不算"DNW is surrounded by NW"?
发表于 2022-4-21 09:53:30 | 显示全部楼层
kkltlb 发表于 2017-3-11 15:11
做DRC有个错误:“DNW must be surrounded by NW”, 那DNW和NW重合的情况算不算"DNW is surrounded by NW"? ...
你好,我是个新手,想问一个问题,我画版图的时候也遇到这个问题,但是在DNW外面加了NW还是报这个错误是为什么呢
发表于 2023-11-13 21:37:23 | 显示全部楼层
要往上爬的阿宇 发表于 2022-4-21 09:53
你好,我是个新手,想问一个问题,我画版图的时候也遇到这个问题,但是在DNW外面加了NW还是报这个错误是 ...
你好,请问你解决问题了吗?我在加了一层NWELL之后,DRC是错误没了  ,但是出现了下面这种连接错误。请问您遇到这种问题了吗
GMT+8, 2025-12-19 03:43 , Processed in 0.028192 second(s), 4 queries , Gzip On, Redis On.
