您需要 登录 才可以下载或查看,没有账号?注册  Autodesk EAGLE Premium 8.0.1 Multilingual (x64)
 PCB design made easy. Make anything with EAGLE PCB design software. Powerful, easy-to-use tools for every engineer. Speed through complex board layouts with modern PCB routing tools. Quickly reuse subcircuits that remain synchronized between schematic and PCB. Escape your ball grid arrays (BGA) in seconds, not hours.
 What's New in Autodesk EAGLE 8:
 PCB layout software for every engineer
 Bring your electronic inventions to life with a complete set of PCB layout and schematic editing tools in EAGLE software.
 Modular design blocks (New!)
 Reuse existing blocks of circuitry in a snap.
 Multisheet schematics
 Keep designs of any size organized and in order.
 Electrical rule checking
 Have confidence in your schematic design.
 Real-time design synchronization
 Stay in-sync between schematic and PCB layout.
 Easy-to-use schematic editor
 Transform your ideas into reality with intuitive schematic capture.
 New routing engine (New!)
 Design beautiful PCB layouts fast.
 BGA fanout (New!)
 Escape from your BGA in seconds.
 Simplified selection and editing (New!)
 Select, group, and edit your design, your way.
 Assembly variants
 Make one design and assemble many with variants.
 High-speed design
 Design with the latest technologies, including DDR4, PCI Express, or USB-C.
 Design rule checking
 Ensure your boards are ready to build.
 Powerful PCB layout
 Bring your design to life with intuitive PCB layout tools.
 3D models
 Unite your PCB and enclosure together.
 Complete components
 The one-stop shop for reviewing your component needs.
 Manufacturable parts
 Reduce worries about parts availability.
 Accessible library content
 Thousands of ready-to-use part libraries.
 One-click make
 Generate your CAM outputs with a single click.
 One-click MCAD
 Fast track your designs to your mechanical tool.
 User Language Programs (ULPs)
 Improve your design tool process.
 EAGLE Premium
 Includes 999 schematic sheets, 16 signal layers, and unlimited board areas.
 System Requirements:
 - Microsoft® Windows® 7 or newer is required.
 - EAGLE 64-bit requires a 64-bit operating system.
