查看: 2671|回复: 0
[求助] mstsc远程登录导致破解软件无法通过授权
发表于 2017-2-24 11:54:00 | 显示全部楼层 |阅读模式
我在win7上装了一个破解的仿真软件,是用flexra的授权文件(绑定网卡地址),根据破解说明安装后,在本机可以读取license文件正常启动。但是我如果从局域网内的另外一台机器通过mstsc远程登录到这台电脑上,这个软件就无法启动,读取license的时候报错,我查看了log文件:10:50:55 (lmgrd) pid 2420
10:50:55 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:50:55 (lmgrd) Done rereading
10:50:55 (lmgrd) FlexNet Licensing (v11.11.1.2 build 134011 x64_n6) started on localhost (IBM PC) (2/24/2017)
10:50:55 (lmgrd) Copyright (c) 1988-2013 Flexera Software LLC. All Rights Reserved.
10:50:55 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
10:50:55 (lmgrd) License file(s): D:\keysight\lisense\mbp2014_crack.lic
10:50:55 (lmgrd) lmgrd tcp-port 27000
10:50:55 (lmgrd) Starting vendor daemons ...
10:50:56 (lmgrd) Started agileesofd (pid 3636)
10:50:56 (agileesofd) FlexNet Licensing version v11.11.1.2 build 134011 x64_n6
10:50:56 (agileesofd) Server started on localhost for:
b_mbp_inclusive
10:50:56 (agileesofd) pjc_b_mbp_inclusive
10:50:56 (agileesofd) EXTERNAL FILTERS are OFF
10:50:56 (lmgrd) agileesofd using TCP-port 49290
10:50:56 (agileesofd)          EESOF 2014.01 (1/28/2014)
10:55:39 (agileesofd) TCP_NODELAY NOT enabled
11:59:45 (agileesofd) Lost connection to lmgrd, heartbeat timeout expired, exiting.
11:59:45 (agileesofd) EXITING DUE TO SIGNAL 28 Exit reason 5
11:59:55 (lmgrd) agileesofd exited with status 28 (Communications error)
11:59:55 (lmgrd) Since this is an unknown status, license server
11:59:55 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
11:59:55 (lmgrd) REStarted agileesofd (pid 3424)
11:59:55 (agileesofd) FlexNet Licensing version v11.11.1.2 build 134011 x64_n6
11:59:55 (agileesofd) Server started on localhost for:
b_mbp_inclusive
11:59:55 (agileesofd) pjc_b_mbp_inclusive
11:59:55 (agileesofd) EXTERNAL FILTERS are OFF
11:59:55 (lmgrd) agileesofd using TCP-port 52965
11:59:55 (agileesofd)          EESOF 2014.01 (1/28/2014)
12:00:33 (agileesofd) TCP_NODELAY NOT enabled
另外但是很奇怪的是,如果我远程登录之前在本地启动了这个软件,再远程登录过去,这个软件还是可以使用,不会退出,但是这时候如果退出了就和上面一样进不去了。是不是有什么端口冲突了啊
GMT+8, 2025-12-26 21:34 , Processed in 0.011308 second(s), 3 queries , Gzip On, Redis On.
