查看: 3177|回复: 7
多谢各位大侠,帮忙分析以下模拟电路的功能。
发表于 2005-8-25 12:28:19 | 显示全部楼层 |阅读模式
发表于 2005-8-25 13:07:16 | 显示全部楼层
Sallen-Key 2nd low-pass filter
H(s)=C1/(1+s/(W*Q)+s*s/(W*W))
W=1/sqrt(R1*C1*R2*C2)
Q=W/(1/(R1*C1)+1/(R2*C1)+(1-G)/(R2*C2))
G is the gain of opamp
发表于 2005-8-25 13:25:26 | 显示全部楼层
also you can calculate the transfer function by yourself, very easy.
To design this lpf, you must pay attention to W(bandwidth) Q(Q factor) and sensitivity(related to variation of R and C).
For example, the sensitivity of R1 to Q is:
S(R1,Q)=1/(1+R1/R2+R1*C1/(R2*C2)*(1-G))
if G=1, R1=R2, S(R1,Q)=0.5, it means R1's variation has little affect on Q
if G=2.9, R1=R2 C1=C2, S(R1,Q)=10,it means 10% variation of R1 will cause 10%*10=100% variation of Q.
 楼主| 发表于 2005-9-6 11:55:48 | 显示全部楼层
很感谢, flushrat的回复。
因为我是学程序设计的,现在对模电很感兴趣,
自己看点以前学校的书,然后看看一些典型电路,
可是学的有些糊涂,特别是有些电路中电容的作用
到底是做啥的,完全不知道该怎么去分析。
希望能推荐本好书学习学习!
发表于 2005-9-6 21:41:46 | 显示全部楼层
真牛
发表于 2005-9-15 17:32:03 | 显示全部楼层
透彻,做模拟的就是要有这种细致,钻研的精神才行。
发表于 2005-9-16 12:25:12 | 显示全部楼层
牛牛牛
 楼主| 发表于 2005-9-22 09:52:41 | 显示全部楼层
http://www.daycounter.com/Filters/SallenKeyLP/Sallen-Key-LP-Filter-Design-Equations.phtml
http://www.ecircuitcenter.com/Circuits/opsalkey1/opsalkey1.htm
很详细的电路说明,不错的模电网站!
GMT+8, 2025-12-20 21:40 , Processed in 0.017947 second(s), 5 queries , Gzip On, Redis On.
