查看: 19170|回复: 46
[Req] Mentor Catapult 2017
发表于 2017-2-1 17:27:53 | 显示全部楼层 |阅读模式
If someone has access to Mentor, please uploads the final version. Win32 (x86) is needed.
Thanks so much!
发表于 2017-2-3 15:04:35 | 显示全部楼层
I need it too
发表于 2017-2-4 17:49:09 | 显示全部楼层
it is better to upload 64 bit version.
 楼主| 发表于 2017-2-7 16:14:57 | 显示全部楼层
回复 3# suiwinder
Then, who exactly?
发表于 2017-2-7 16:39:28 | 显示全部楼层
I have 2016.v8.3a...
发表于 2017-2-7 16:41:25 | 显示全部楼层
There is no new release for this year, only 10a release from last year.
You have to wait until March.
 楼主| 发表于 2017-2-7 17:12:00 | 显示全部楼层
回复 6# adialbu
Thanks my friend! So just one question. As I stated in the other thread (uploaded by yourself), how to solve the library problem. I mean, during the compilation process, an error appears, alluding "not being able to read the encrypted libraries". Do you know it's a bug or related to the license?
Thank you again!
发表于 2017-2-9 16:54:37 | 显示全部楼层
Do you try to recompile one of your previous designs, or try to run one of the examples in the new release?
 楼主| 发表于 2017-2-9 17:57:33 | 显示全部楼层
回复 8# adialbu
    Thank you!
In both situations (running my previous designs or compiling the provided examples by Catapult itself), after selecting the technology files (for example Design Compiler 065nm), below errors rise:
# Warning: Could not read Encrypted Liberty technology library file 'sample_065nm.clib' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Encrypted Liberty file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
# Warning: Could not read Liberty technology library file 'sample_065nm.lib' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Liberty file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
# Warning: Could not read Synopsys DB technology library file 'sample_065nm.db' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Synopsys DB file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
This error does not allow me to view the "Gantt chart" and have manipulations there. Also "Schematic" file is not being created. No matter I select Design compiler libraries or others. In all of them, above errors appear. I also checked the library paths. All of them are correct. Do you use Catapult? Do you have the same problem? I also installed it inside other computers too. The situation is the same.
 楼主| 发表于 2017-2-20 00:22:03 | 显示全部楼层
GMT+8, 2025-10-20 04:15 , Processed in 0.021015 second(s), 3 queries , Gzip On, Redis On.
