查看: 2270|回复: 0
[求助] power net errors
发表于 2017-1-17 07:24:05 | 显示全部楼层 |阅读模式
at the power rail generation step, I got this, after the synthesize_fp_rail command,
please help:
synthesize_fp_rail  -nets {VDD VSS} -voltage_supply 1 -synthesize_power_plan -power_budget 80
Warning: No power/ground pads are specified and no virtual pads are defined. (PNA-138)
Number of pad instances: 0
Error: All the P/G pads do not have power ports, or all the power ports are not connected to power or ground net logically. (PNA-006)
Creating PNS Replay file ./pna_output/pns_replay.tcl
Power network synthesis failed.
Error: No synthesized power network. (PNA-067)
GMT+8, 2025-9-15 07:49 , Processed in 0.013034 second(s), 4 queries , Gzip On, Redis On.
