查看: 2237|回复: 1
[求助] SUNG异步fifo style2 求解释
发表于 2017-1-7 13:30:55 | 显示全部楼层 |阅读模式
The aempty_n signal might also stay high longer and go low at any moment, even perhaps coincident with the
next read clock edge. If it goes low well before the set-up time of the first synchronize flip-flop, the result is like
scenario (4) above. If it goes low well after the set-up time, the synchronizer will stretch rempty by one more read
clock period.
不知道有没有人看过这篇文章,这一段是在最后问题回答那一段,这里的说法是aempty_n会在任何时刻拉低,空应该是由读引起的,更读时钟同步,为什么会在任何时刻拉低?
发表于 2017-1-9 15:43:24 | 显示全部楼层
nice,收藏了,很好
GMT+8, 2025-12-28 15:05 , Processed in 0.011408 second(s), 3 queries , Gzip On, Redis On.
