查看: 4668|回复: 2
[求助] ERROR(VACOMP-1008)error
发表于 2017-1-3 03:51:43 | 显示全部楼层 |阅读模式
在IC616 + MMSIM141 的条件下,普通 spectre仿真可以顺利完成,在ADE的setup--high-performance里设置了 simulation performance mode 为aps (或者 turbo),
然后报错,ERROR(VACOMP-1008).cannot compile ahdlcmi module。
ahdlcmi.out的内容,还是一头雾水,不知道问题在哪里。
我觉得问题应该就是出在aps或者turbo上,请问有人遇到过类似问题吗?
先谢谢了啊
bsource_cb93ba_cmi_c.c: In function 'bsource_cb93ba_pAnalTranLoad':
bsource_cb93ba_cmi_c.c:856: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast
/usr/local/eda/cadence/installs/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1933: note: expected 'void *' but argument is of type 'long int'
bsource_cb93ba_cmi_c.c: In function 'bsource_cb93ba_pNoiseBindSrcs':
bsource_cb93ba_cmi_c.c:882: warning: passing argument 3 of 'aslDevNoiseBindStartModel' discards qualifiers from pointer target type
/usr/local/eda/cadence/installs/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1045: note: expected 'char *' but argument is of type 'devModelID'
bsource_cb93ba_cmi_c.c: In function 'bsource_cb93ba_pNoiseNameSrcs':
bsource_cb93ba_cmi_c.c:885: warning: passing argument 3 of 'aslDevNoiseNameModel' discards qualifiers from pointer target type
/usr/local/eda/cadence/installs/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1053: note: expected 'char *' but argument is of type 'devModelID'
bsource_cb93ba_cmi_c.c: In function 'bsource_cb93ba_pSaveRestart':
bsource_cb93ba_cmi_c.c:891: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
/usr/local/eda/cadence/installs/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1162: note: expected 'struct ahdlAnalogVar *' but argument is of type 'char *'
bsource_cb93ba_cmi_c.c: In function 'bsource_cb93ba_pSaveRestartInst':
bsource_cb93ba_cmi_c.c:894: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
rm -f -rf bsource_cb93ba_cmi_c.c
/usr/local/eda/cadence/installs/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O3 -m64 -fPIC -o obj/optimize/5.0/bsource_cb93ba_libahdlcmi.so ./obj/optimize/5.0/bsource_cb93ba_func.o ./obj/optimize/5.0/bsource_cb93ba_DcFuncDerLoad.o ./obj/optimize/5.0/bsource_cb93ba_DcFuncLoad.o ./obj/optimize/5.0/bsource_cb93ba_TranFuncDerLoad.o ./obj/optimize/5.0/bsource_cb93ba_TranFuncLoad.o ./obj/optimize/5.0/bsource_cb93ba_HbFuncLoad.o ./obj/optimize/5.0/bsource_cb93ba_OpPointCalc.o ./obj/optimize/5.0/bsource_cb93ba_cmi_c.o  -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
ld: BFD (GNU Binutils) 2.20 internal error, aborting at ../../binutils-2.20/bfd/reloc.c line 446 in bfd_get_reloc_size
ld: Please report this bug.
collect2: ld returned 1 exit status
gnumake: *** [obj/optimize/5.0/bsource_cb93ba_libahdlcmi.so] Error 1
发表于 2021-5-14 22:42:42 | 显示全部楼层
请问如何解决的呢?
发表于 2021-8-5 00:47:34 | 显示全部楼层
遇到同样问题,1请问解决了吗
GMT+8, 2025-12-29 16:13 , Processed in 0.013898 second(s), 3 queries , Gzip On, Redis On.
