查看: 10234|回复: 15
[求助] 分频器 噪声仿真 PSS+pnoise Fatal Error 求助
发表于 2016-12-23 20:17:33 | 显示全部楼层 |阅读模式
小弟最近研究CMOS锁相频率合成器,现在搭出了电路大致框架,瞬态仿真也能够锁定,但是在对Divider进行pss+pnoise仿真的时候,遇到一些问题,仿真器一直提示fatal error.    我的分频器是200分频,用的CML+TSPC+多模分频器MMD(里面有反馈)
特来请教各位大牛前辈关于分频器噪声仿真的问题。还望能不吝赐教,任何帮助都将万分感激。
pss的设置
pss的设置
提示的问题
提示的问题
`pss': time = (50 ps -> 20.05 ns)
    pss: time = 550.1 ps     (2.5 %), step = 66.01 fs     (330 u%)
    pss: time = 1.55 ns      (7.5 %), step = 66.05 fs     (330 u%)
    pss: time = 2.55 ns     (12.5 %), step = 66.02 fs     (330 u%)
    pss: time = 3.55 ns     (17.5 %), step = 1.381 ps     (6.9 m%)
    pss: time = 4.55 ns     (22.5 %), step = 864.1 fs    (4.32 m%)
    pss: time = 5.55 ns     (27.5 %), step = 66.05 fs     (330 u%)
    pss: time = 6.55 ns     (32.5 %), step = 66.02 fs     (330 u%)
    pss: time = 7.55 ns     (37.5 %), step = 77.45 fs     (387 u%)
    pss: time = 8.55 ns     (42.5 %), step = 863.9 fs    (4.32 m%)
    pss: time = 9.55 ns     (47.5 %), step = 66.05 fs     (330 u%)
    pss: time = 10.55 ns    (52.5 %), step = 866.3 fs    (4.33 m%)
    pss: time = 11.55 ns    (57.5 %), step = 1.379 ps     (6.9 m%)
Fatal error found by spectre at time = 11.8003 ns during periodic steady state analysis `pss'.
    FATAL (CMI-2002): Insufficient memory available. Try using the 64-bit executable or another machine with better memory configuration. Alternatively, use the 'ulimit' or 'unlimit' command to adjust the memory limitations. For more information on optimizing memory usage when using SpectreRF, see spectre -h rfmemory or the "Tips for Reducing Memory Usage with SpectreRF (rfmemory)" section in the "Virtuoso Spectre Circuit Simulator Reference" manual.
Conv norm = 105e+03, max dV(I0.I6.I1.PM10.d_i) = 1.19962 V, took 78.26 s.
Analysis `pss' was terminated prematurely due to an error.
 楼主| 发表于 2016-12-31 13:26:54 | 显示全部楼层
怀疑这个问题是级联的2/3分频器直接的反馈造成的,不知道对不对哇
发表于 2017-1-13 14:13:00 | 显示全部楼层
错误反馈了写的很清楚啊,内存溢出了,服务器内存不够大
这对PSS仿真太正常了,PSS仿真还经常不收敛,
 楼主| 发表于 2017-1-13 19:27:19 | 显示全部楼层
回复 3# gloryduke
   嗯嗯,忧伤。
发表于 2017-6-28 20:27:23 | 显示全部楼层
请问楼主这个问题解决了吗?我还想请教的是推荐方法里面的unlimit命令该怎么设置,还有他后面推荐的方法该怎么查询?
发表于 2017-6-28 20:31:54 | 显示全部楼层
回复 3# gloryduke 你好,请问这个问题除了换内存较大的机器和换用HB算法之外还有其他什么解决办法没?
发表于 2021-5-13 12:56:36 | 显示全部楼层
这对PSS仿真太正常了,PSS仿真还经常不收敛, ...
请问这个一般怎么解决啊,非常感谢!
发表于 2021-9-7 12:01:05 | 显示全部楼层
是否已解决,我仿真pss一直不收敛,请教下怎么做
发表于 2021-11-21 16:18:01 | 显示全部楼层
同问。pss不收敛,服务器内存不够用。
发表于 2022-11-28 20:23:58 | 显示全部楼层
同问这个报错如何解决,pss仿真中已经求出稳态解了,但是pnoise仿真中还是出现了内存溢出的报错。
想问一下ulimit和unlimit这两个指令怎么用?Alternatively, use the 'ulimit' or 'unlimit' command to adjust the memory limitations.
GMT+8, 2025-9-21 17:33 , Processed in 0.017355 second(s), 4 queries , Gzip On, Redis On.
