查看: 1839|回复: 0
[求助] 关于用verilog语言编写检测开关的问题
发表于 2016-12-17 23:07:01 | 显示全部楼层 |阅读模式
如果现在一共有18个拨动开关,用什么样的办法检测被关闭的两个开关是哪?只要求测出最左和最右两端的开关。我自己的思路部分代码如下:
  1. input[17:0] rang;
  2. wire[17:0] rang_1;
  3. assign rang_1 ={rang[0], rang[1], rang[2],rang[3],rang[4],rang[5],rang[6],rang[7], rang[8],rang[9], rang[10],rang[11],rang[12],rang[13],rang[14],rang[15],rang[16],rang[17]};
  4. always @(posedge clk or negedge clr_n)
  5. if(!clr_n)
  6. left_temp <=5'd0;
  7. else
  8. casex(rang)
  9. 18'b1xxxxxxxxxxxxxxxxx:left_temp <= 5'd1;
  10. 18'b01xxxxxxxxxxxxxxxx:left_temp <= 5'd2;
  11. 18'b001xxxxxxxxxxxxxxx:left_temp <= 5'd3;
  12. 18'b0001xxxxxxxxxxxxxx:left_temp <= 5'd4;
  13. 18'b00001xxxxxxxxxxxxx:left_temp <= 5'd5;
  14. 18'b000001xxxxxxxxxxxx:left_temp <= 5'd6;
  15. 18'b0000001xxxxxxxxxxx:left_temp <= 5'd7;
  16. 18'b00000001xxxxxxxxxx:left_temp <= 5'd8;
  17. 18'b000000001xxxxxxxxx:left_temp <= 5'd9;
  18. 18'b0000000001xxxxxxxx:left_temp <= 5'd10;
  19. 18'b00000000001xxxxxxx:left_temp <= 5'd11;
  20. 18'b000000000001xxxxxx:left_temp <= 5'd12;
  21. 18'b0000000000001xxxxx:left_temp <= 5'd13;
  22. 18'b00000000000001xxxx:left_temp <= 5'd14;
  23. 18'b000000000000001xxx:left_temp <= 5'd15;
  24. 18'b0000000000000001xx:left_temp <= 5'd16;
  25. 18'b00000000000000001x:left_temp <= 5'd17;
  26. 18'b000000000000000001:left_temp <= 5'd18;
  27. default: left_temp <= 5'd0;
  28. endcase
  29. always @(posedge clk or negedge clr_n)
  30. if(!clr_n)
  31. right_temp <=5'd13;
  32. else
  33. casex(rang)
  34. 18'bxxxxxxxxxxxxxxxxx1:right_temp <= 5'd18;
  35. 18'bxxxxxxxxxxxxxxxx10:right_temp <= 5'd17;
  36. 18'bxxxxxxxxxxxxxxx100:right_temp <= 5'd16;
  37. 18'bxxxxxxxxxxxxxx1000:right_temp <= 5'd15;
  38. 18'bxxxxxxxxxxxxx10000:right_temp <= 5'd14;
  39. 18'bxxxxxxxxxxxx100000:right_temp <= 5'd13;
  40. 18'bxxxxxxxxxxx1000000:right_temp <= 5'd12;
  41. 18'bxxxxxxxxxx10000000:right_temp <= 5'd11;
  42. 18'bxxxxxxxxx100000000:right_temp <= 5'd10;
  43. 18'bxxxxxxxx1000000000:right_temp <= 5'd9;
  44. 18'bxxxxxxx10000000000:right_temp <= 5'd8;
  45. 18'bxxxxxx100000000000:right_temp <= 5'd7;
  46. 18'bxxxxx1000000000000:right_temp <= 5'd6;
  47. 18'bxxxx10000000000000:right_temp <= 5'd5;
  48. 18'bxxx100000000000000:right_temp <= 5'd4;
  49. 18'bxx1000000000000000:right_temp <= 5'd3;
  50. 18'bx10000000000000000:right_temp <= 5'd2;
  51. 18'b100000000000000000:right_temp <= 5'd1;
  52. default: right_temp <= 5'd19;
  53. endcase
    复制代码
GMT+8, 2025-12-28 18:44 , Processed in 0.014300 second(s), 4 queries , Gzip On, Redis On.
