查看: 1611|回复: 0
[求助] check_mv_design 报出来的 Error
发表于 2016-12-11 20:25:37 | 显示全部楼层 |阅读模式
两个power domain的design; power plan 做完之后, check_mv_design 检查; 报port 'mm' [supply net ‘VDDC’', power state 'OFF'] is less always-on than the load pin 'xx/yy/z' [supply net 'VDD_CORE', power state 'ON'] .   请教高手,这是什么原因导致的呢
GMT+8, 2025-8-22 18:14 , Processed in 2.494218 second(s), 4 queries , Gzip On, Redis On.
