查看: 2162|回复: 0
[求助] 新手求助NgdBuild 924错误
发表于 2016-11-3 14:12:19 | 显示全部楼层 |阅读模式
各位大神,小弟从网上下了一个verilog实现的74245模块,源码如下:
module TTL245( a , b , oe , dir );
    input oe,dir;
    inout[ 7 : 0 ] a , b;
    assign a = ( { oe , dir } == 2'b00 ) ? b:8'bz;
    assign b = ( { oe , dir } == 2'b01 ) ? a:8'bz;
endmodule
然后定义了2组信号:
inout [7 : 0] port0_clk;
inout [7 : 0] codec0_clk;
然后调用74245模块:
TTL245 data( .a( port0_clk),.b(codec0_clk),.oe(oe),.dir(d));
综合能通过,但是translate时,出现警告及错误:
Warning :NgdBuild :437 - TRI primitive 'port0_clk_1_IOBUF' has it's input pin connected to it's own output pin;
ERROR:NgBuild : 924 -bidirect pad net 'port0_clk<0>' is driving non-buffer primitives:pin i on block port0_clk_0_IOBUF/OBUFT with type OBUFT.
请各位大神指点下。谢谢!
GMT+8, 2025-12-28 12:53 , Processed in 0.011282 second(s), 4 queries , Gzip On, Redis On.
