查看: 2133|回复: 5
[招聘] 【Synopsys武汉】招Sr, CAE(模拟/数字设计)
发表于 2016-11-3 09:49:28 | 显示全部楼层 |阅读模式
Hi All,
Synopsys武汉热Sr CAE,具体JD如下,欢迎有意向的朋友发送简历到qyzhong@synopsys.com
Provide technical support to customers for integration of Synopsys’ Mixed Signal IP into ASICs.  This includes:
  • Debugging of customers’ simulation or silicon issues.
  • Reviewing customers’ integration of our IP.
    • Logical and Physical integration.
  • Answering technical questions about our IPs’ operation and features.
  • Train field engineers in IP operation and demonstration.
  • Interface with R&D and Product Engineering teams to provide timely communication to and from customers.
Qualifications:
  • BS +5 years of prior work-experience, or MS +3 years of prior work-experience.
Must-Have Skills:
  • All front-end skills:
    • RTL design & verification in Verilog, Synthesis, Static-Timing Analysis, DFT, CDC.
  • Scripting in Perl/TCL/Python etc..
  • Time management skills to balance multiple high-priority tasks and projects.
  • Excellent oral and written communication skills.
  • Willingness to learn new skills and perform tasks that often go outside of the area of current expertise.
Skills that will put you at an advantage:
  • Domain-knowledge : High-speed serial communication standards like USB2.0, HSIC, USB3.0, USB3.1, Type-C, Alternate mode etc.., with full understanding of functional partitioning between protocol layers.
  • Back-end skills.
    • DRC, LVS, ERC, PERC, understanding of double patterning.
  • Analog design/simulation.
    • HSPICE, XA-RA.
  • Understanding of transmission-line fundamentals, and signal-integrity concepts.
  • Lab experience.
    • Familiarity with ATE concepts and test program flow.
    • Familiarity with bench-level and compliance testing.
 楼主| 发表于 2016-11-21 10:16:43 | 显示全部楼层
update
发表于 2016-11-22 08:32:58 | 显示全部楼层
做过一两年FPGA,主要应用是控制方面,没有做过相关设计可以吗?
 楼主| 发表于 2016-11-28 16:33:09 | 显示全部楼层
回复 3# aftertree
    欢迎发送简历到qyzhong@synopsy.com
 楼主| 发表于 2016-12-8 10:45:10 | 显示全部楼层
update
 楼主| 发表于 2016-12-21 11:22:50 | 显示全部楼层
GMT+8, 2025-12-26 05:12 , Processed in 0.015868 second(s), 4 queries , Gzip On, Redis On.
