查看: 4855|回复: 1
ADS 2015破解安装求助
发表于 2016-10-23 02:38:15 | 显示全部楼层 |阅读模式
按步骤破解了ADS2015,原理图仿真出现了以下的错误!
Error detected by hpeesofsim during circuit set up `SP1'.    An appropriate license for linear features is not available.  This
    feature must be licensed before it can be used.
        FlexLM error message:
        Linear Simulator
        The desired vendor daemon is down
        Possible Causes:
        1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
        2. agileesofd vendor daemon has crashed or has been terminated.
        3. lmgrd process was shut down manually or via LMTools with -x lmdown option
        4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
        5. The logfile was unable to be removed.
        Troubleshooting Tips:
        1. Check the license server's debug log file and try lmreread.
        2. Reboot your system to restart the license service.
        3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
        4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
        5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
        6. Close all processes that are reading the logfile.
发表于 2016-10-23 13:56:29 | 显示全部楼层
2015好像有问题,用别的版本吧,2013比较靠谱
GMT+8, 2025-12-25 12:27 , Processed in 0.013798 second(s), 5 queries , Gzip On, Redis On.
