查看: 3539|回复: 4
ic616安装好,不能正常跑ocean脚本
发表于 2016-9-22 09:03:10 | 显示全部楼层 |阅读模式
 楼主| 发表于 2016-9-22 09:04:58 | 显示全部楼层
oad "/home/fangzhen/llq/STR20161012/RXTRAN/ocean/1000/tt27.ocn"
Loading oasis.cxt
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading relXpert.cxt
Loading awv.cxt
ERROR (ADE-3023): Unable to locate spectre executable in the specified path. Ensure that
        the executable is present in the path or to set the correct path, use
        the setShellEnvVar() in Command Interpreter Window (CIW).
WARNING (OCN-6040): The specified directory does not exist, or the directory does not contain valid PSF results.
        Ensure that the path to the directory is correct and the directory has a logFile and PSF result files.
t
 楼主| 发表于 2016-9-22 09:12:59 | 显示全部楼层
顶一个,上面的问题是什么,哪位大神帮忙解答一下,ocean的路径设置的没有错。已经重装几次ic616了,都是同样的问题。
发表于 2016-9-22 11:50:40 | 显示全部楼层
回复 2# 晚风袭人
    MMSIM没安装或MMSIM的环境变量没设
 楼主| 发表于 2016-9-23 18:28:22 | 显示全部楼层
回复 4# pickpunk
   已经好了,安装了mmsim的。也不行,我觉得不只是是mmism的问题,我装了,mmsim和ius、EDI才能正常的运行起来
GMT+8, 2025-12-24 00:32 , Processed in 0.021570 second(s), 6 queries , Gzip On, Redis On.
