查看: 49546|回复: 137
[资料] 14篇latch比较器结构及其改进结构paper
发表于 2016-8-3 18:40:06 | 显示全部楼层 |阅读模式
1、ASSCC_2008_A Low-Noise Self-Calibrating Dynamic Comparator for High-Speed ADCs2、Design and Analysis of Novel Dynamic Latched Comparator with Reduced Kickback Noise for High-speed ADCs
3、HIGH-SPEED AND LOW-POWER DYNAMIC LATCH COMPARATOR
4、IEEE_2010_high resolution low power 0.6um CMOS 40MHz dynamic latch comparator
5、IEEE_2014_Analysis and Design of a Low-Voltage Low-Power Double-Tail Comparator
6、IEEE_2015_Design of efficient Double Tail Comparator for Low Power
7、ISSCC_2007_A Double-Tail Latch_Type Voltage Sense Amplifier with 18ps Setup+Hold Time
8、ISSCC_2008_A 1.9μW 4.4fJ Conversion-step 10b 1MSs Charge Redistribution ADC
9、ISSCC_2012_A 7-to-10b 0-to-4MSs Flexible SAR ADC with 6.5-to-16fJ conversion-step
10、JSSC_1993_A current controlled latch sense amplifier and a static power saving input buffer for low power architectures
11、JSSC_2011_A 26uW 8bit 10MSs Asynchronous SAR ADC for Low Energy Radios
12、JSSC_2015_A 0.003mm2 10b 240 MSs 0.7mW SAR ADC in 28nm CMOS Witth Digital Error Correction and Correlated-Reversed Switching
13、New Improved High Speed Low Power Double Tail Comparator Design for 2.5GHz Input Signal
14、Rourkela_2011_DESIGN OF A NOVEL HIGH SPEED DYNAMIC COMPARATOR WITH LOW POWER DISSIPATION FOR HIGH SPEED ADCs
结构.part01.rar (2 MB , 下载次数: 432 )
结构.part02.rar (2 MB , 下载次数: 336 )
结构.part03.rar (2 MB , 下载次数: 315 )
结构.part04.rar (2 MB , 下载次数: 308 )
结构.part05.rar (2 MB , 下载次数: 305 )
结构.part06.rar (2 MB , 下载次数: 313 )
结构.part07.rar (2 MB , 下载次数: 308 )
结构.part08.rar (2 MB , 下载次数: 309 )
结构.part09.rar (699.6 KB , 下载次数: 313 )
发表于 2016-8-5 13:48:40 | 显示全部楼层
回复 1# banzhiyan1993
楼主是否可以打成一个包,谢谢!
 楼主| 发表于 2016-8-5 14:54:20 | 显示全部楼层
回复 2# Kevin_Yang
不好意思,之前的压缩工具是固定的几种大小,我又重新压缩了一下。
结构.part1.rar (10 MB , 下载次数: 1892 )
结构.part2.rar (6.68 MB , 下载次数: 1237 )
发表于 2016-8-5 17:16:58 | 显示全部楼层
回复 3# banzhiyan1993
谢谢!
发表于 2016-8-7 18:38:10 | 显示全部楼层
非常好的资料!!!
发表于 2016-8-9 14:57:05 | 显示全部楼层
Good job!
发表于 2016-8-16 20:50:23 | 显示全部楼层
thank you!
发表于 2016-12-2 19:21:48 | 显示全部楼层
非常好的资料
发表于 2016-12-2 20:05:16 | 显示全部楼层
xuexixia
发表于 2016-12-20 09:53:50 | 显示全部楼层
thanks for sharing
GMT+8, 2025-10-7 15:08 , Processed in 0.017523 second(s), 4 queries , Gzip On, Redis On.
