查看: 8217|回复: 13
IC616 installation error on CentOS6.8
发表于 2016-7-27 16:50:13 | 显示全部楼层 |阅读模式
I download Base, Hotfix, IScape, MMSIM from http://bbs.eetop.cn/thread-593172-1-1.html I have CentOS 6.8. While installing any package, the installation stops saying,
To complete installing this release, you must specify the following media:
IC 06.16.005 RHEL 5(lnx86) Base Release Disk
I tried solution given http://bbs.eetop.cn/thread-258482-1-1.html but not able to get the file MediaID.txt
I desperately need help. thanks a lot in advance.
发表于 2016-7-28 12:48:33 | 显示全部楼层
先安装base,然后安装hotfix,在安装hotfix的最后阶段,指定base的安装盘。
 楼主| 发表于 2016-7-28 15:48:04 | 显示全部楼层
Thank you Very much for your Reply. I did that But Still Same problem
Is it Necessary that the OS has to be 32bit for IC06.16.005_lnx86.Base? Mine is CentOs 64-bit.
发表于 2016-7-28 20:56:19 | 显示全部楼层
回复 3# sunil4u
安装路径不要有空格,检查iscape的路径
 楼主| 发表于 2016-7-29 02:23:40 | 显示全部楼层
Dear, Thanks for reply. Here is the source path and installation path which I use,
Source : /mnt/E/Cadence/Base/IC06.16.005_lnx86.Base/CDROM1
/home/sunil4u/EDA/Cadence/IC6.1
I use similar path for Hotfix and I am able to start installation till 95%, but after that installation ask IC 06.16.005 RHEL 5(lnx86) Base Release Disk 1
And I provide above source path, but it keep asking and not doing anything
I really need your help. Thanks a lot
发表于 2016-7-29 02:48:25 | 显示全部楼层
Try Ubuntu if Centos issue can't be solved, http://bbs.eetop.cn/thread-606269-1-1.html
I successfully installed IC616 on Ubuntu 16.04 LTS.Regards.
sdsy1212.
发表于 2016-7-29 08:11:09 | 显示全部楼层
回复 5# sunil4u
    I mean provide your iscape.sh path.
 楼主| 发表于 2016-7-29 20:43:17 | 显示全部楼层
here it is, /home/sunil4u/EDA/Cadence/ISCAPE/iscape/bin/iscape.sh
 楼主| 发表于 2016-7-29 21:32:06 | 显示全部楼层
[url=]Screenshot from 2016-07-29 18- ...[/url]
 楼主| 发表于 2016-7-29 21:34:25 | 显示全部楼层
Thank you very much all of you. Finally I am able to install IC616 on Ubuntu, but not MMSIM14. Can someone post license file for IC616.005 ?
GMT+8, 2025-12-30 05:44 , Processed in 0.029101 second(s), 6 queries , Gzip On, Redis On.
