在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 12443|回复: 19
Cedence IC613 安裝問題
发表于 2010-6-26 04:10:02 | 显示全部楼层 |阅读模式
Any idea? Thanks.
To complete installing this release, you must specify the following media:
Base IC610 lnx86 P/N 356-70352-070 Disk 1
Errors during installation.
    Detailed error information is in the following file:
    /root/.iscape/iscape_logs/20100625_230212_run.txt
The following selected products were NOT installed:
    111:Cadence(R) Design Framework II
    12141_64bit:12141_64bit~06.13.001~lnx86
    12141:Cadence(R) Design Framework Integrator's Toolkit
    206:Virtuoso(R) Simulation Environment
    207:Waveform
    21060:Virtuoso(R) Schematic VHDL Interface
    21400:Virtuoso(R) Schematic Editor Verilog(R) Interface
    276:Virtuoso(R) Schematic Editor HSPICE Interface
    32100:Virtuoso(R) Analog Oasis Run-Time Option
    32101:Cadence(R) OASIS for RFDE
    32760:Virtuoso(R) Analog HSPICE Interface Option
    34570:Virtuoso(R) Analog VoltageStorm Option
    34580:34580~06.13.001~lnx86
    365_64bit:365_64bit~06.13.001~lnx86
    365racula(R) Graphical User Interface
    5100:Virtuoso(R) Layout Migrate
    681:Cadence(R) RC Network Reducer Option
    70000:Virtuoso(R) AMS Designer Environment
    70110_64bit:70110_64bit~06.13.001~lnx86
    70110racula(R) Design Rule Checker
    70120_64bit:70120_64bit~06.13.001~lnx86
    70120racula(R) Layout Vs. Schematic Verifier
    70130_64bit:70130_64bit~06.13.001~lnx86
    70130:Dracula(R) Parasitic Extractor
    70510_64bit:70510_64bit~06.13.001~lnx86
    70510:Dracula(R) Physical Verification Suite
    70520_64bit:70520_64bit~06.13.001~lnx86
    70520:Dracula(R) Physical Verification and Extraction Suite
    71110_64bit:71110_64bit~06.13.001~lnx86
    71110:Diva(R) Design Rule Checker
    71120_64bit:71120_64bit~06.13.001~lnx86
    71120:Diva(R) Layout Vs. Schematic Verifier
    71130:Diva(R) Parasitic Extractor
    71510:Diva(R) Physical Verification Suite
    71520:Diva(R) Physical Verification and Extraction Suite
    900:Cadence(R) SKILL Development Environment
    940:Virtuoso(R) EDIF 200 Reader
    945:Virtuoso(R) EDIF 200 Writer
    95100:Virtuoso(R) Schematic Editor L
    95115:Virtuoso(R) Schematic Editor XL
    95120:Virtuoso(R) Schematic Editor GXL
    95200:Virtuoso(R) Analog Design Environment L
    95210:Virtuoso(R) Analog Design Environment XL
    95220:Virtuoso(R) Analog Design Environment - GXL
    95255:Virtuoso(R) Visualization & Analysis XL
    95300_64bit:95300_64bit~06.13.001~lnx86
    95300:Virtuoso(R) Layout Suite L
    95310:Virtuoso(R) Layout Suite XL
    95320:Virtuoso(R) Layout Suite - GXL
    994ostScript Level 2 Hardcopy Output
The following components were NOT installed:
    All component files are relative to:
       /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1
      Error Installing Component:dracDIST64b_lnx86 61.03-s002lnx86, File:kits/dracDIST64b61.03-s002lnx86.t.Z
      Error Installing Component:dsskill_lnx86 07.02-s020lnx86, File:kits/dsskill07.02-s020lnx86.t.Z
      Error Installing Component:lbsJava 07.02-s008, File:kits/lbsJava07.02-s008.t.Z
      Error Installing Component:dracLPE64b_lnx86 61.03-s002lnx86, File:kits/dracLPE64b61.03-s002lnx86.t.Z
      Error Installing Component:skillPcellPlg_lnx86 61.03-s010lnx86, File:kits/skillPcellPlg61.03-s010lnx86.t.Z
      Error Installing Component:skooprefDocC 07.02-s002, File:kits/skooprefDocC07.02-s002.t.Z
      Error Installing Component:dfiiTagDoc 06.13-p042, File:kits/dfiiTagDoc06.13-p042.t.Z
      Error Installing Component:distProcDoc 06.13-p002, File:kits/distProcDoc06.13-p002.t.Z
      Error Installing Component:DFII_ncvlog_lnx86 06.11-s017lnx86, File:kits/DFII_ncvlog06.11-s017lnx86.t.Z
      Error Installing Component:composerReg_lnx86 61.03-s010lnx86, File:kits/composerReg61.03-s010lnx86.t.Z
      Error Installing Component:artLibFunc_lnx86 61.03-s010lnx86, File:kits/artLibFunc61.03-s010lnx86.t.Z
      Error Installing Component:divarefDoc 05.00-s025, File:kits/divarefDoc05.00-s025.t.Z
      Error Installing Componentptimizatn_lnx86 61.03-s010lnx86, File:kits/optimizatn61.03-s010lnx86.t.Z
      Error Installing Component:skdfrefDoc 07.02-s016, File:kits/skdfrefDoc07.02-s016.t.Z
      Error Installing Component:amsEnv_lnx86 61.03-s010lnx86, File:kits/amsEnv61.03-s010lnx86.t.Z
      Error Installing Component:loContext_lnx86 61.03-s010lnx86, File:kits/loContext61.03-s010lnx86.t.Z
      Error Installing Component:itkdbaseDoc 06.13-s001, File:kits/itkdbaseDoc06.13-s001.t.Z
      Error Installing Component:vlReader_lnx86 61.03-s010lnx86, File:kits/vlReader61.03-s010lnx86.t.Z
      Error Installing Component:spectrei_lnx86 61.03-s010lnx86, File:kits/spectrei61.03-s010lnx86.t.Z
      Error Installing Component:leToolbox64b_lnx86 61.03-s010lnx86, File:kits/leToolbox64b61.03-s010lnx86.t.Z
      Error Installing Component:cadencehelpWrp 01.10-p001, File:kits/cadencehelpWrp01.10-p001.t.Z
      Error Installing Component:hed64b_lnx86 07.02-s060lnx86, File:kits/hed64b07.02-s060lnx86.t.Z
      Error Installing Component:uiCore64b_lnx86 07.02-s059lnx86, File:kits/uiCore64b07.02-s059lnx86.t.Z
      Error Installing Component:dfIIbase_lnx86 61.03-s010lnx86, File:kits/dfIIbase61.03-s010lnx86.t.Z
      Error Installing Component:skillPcellPlg64b_lnx86 61.03-s010lnx86, File:kits/skillPcellPlg64b61.03-s010lnx86.t.Z
      Error Installing Component:lbs_lnx86 07.02-s008lnx86, File:kits/lbs07.02-s008lnx86.t.Z
      Error Installing ComponentceanrefDoc 06.13-s005, File:kits/oceanrefDoc06.13-s005.t.Z
      Error Installing Component:iccraftexe_lnx86 61.03-s010lnx86, File:kits/iccraftexe61.03-s010lnx86.t.Z
      Error Installing Component:analogWave_lnx86 61.03-s010lnx86, File:kits/analogWave61.03-s010lnx86.t.Z
      Error Installing Component:edifinuserDoc 06.13-p002, File:kits/edifinuserDoc06.13-p002.t.Z
      Error Installing Component:vsaContext64b_lnx86 61.03-s010lnx86, File:kits/vsaContext64b61.03-s010lnx86.t.Z
      Error Installing Component:deftDoc 06.13-p002, File:kits/deftDoc06.13-p002.t.Z
      Error Installing Component:samplesMix_lnx86 61.03-s010lnx86, File:kits/samplesMix61.03-s010lnx86.t.Z
      Error Installing Component:wavescanDoc 06.13-s001, File:kits/wavescanDoc06.13-s001.t.Z
      Error Installing Component:skdevrefDocC 07.02-s004, File:kits/skdevrefDocC07.02-s004.t.Z
      Error Installing Component:draciarefDoc 05.00-p005, File:kits/draciarefDoc05.00-p005.t.Z
      Error Installing Component:plotDoc 06.12-p005, File:kits/plotDoc06.12-p005.t.Z
      Error Installing Component:DFII_nccommon64b_lnx86 06.11-s017lnx86, File:kits/DFII_nccommon64b06.11-s017lnx86.t.Z
      Error Installing Component:abstract64b_lnx86 61.03-s010lnx86, File:kits/abstract64b61.03-s010lnx86.t.Z
      Error Installing Component:itk64b_lnx86 61.03-s010lnx86, File:kits/itk64b61.03-s010lnx86.t.Z
      Error Installing Component:ckSysConf_lnx86 02.00-p074lnx86, File:kits/ckSysConf02.00-p074lnx86.t.Z
      Error Installing Component:composerDocC 06.13-s003, File:kits/composerDocC06.13-s003.t.Z
      Error Installing Component:verinuserDoc 06.13-s003, File:kits/verinuserDoc06.13-s003.t.Z
      Error Installing Component:cdf_lnx86 61.03-s010lnx86, File:kits/cdf61.03-s010lnx86.t.Z
      Error Installing Component:conn2schDoc 06.13-p001, File:kits/conn2schDoc06.13-p001.t.Z
      Error Installing Component:mdlDoc 06.21-p003, File:kits/mdlDoc06.21-p003.t.Z
      Error Installing Component:cdf64b_lnx86 61.03-s010lnx86, File:kits/cdf64b61.03-s010lnx86.t.Z
      Error Installing Component:gcfrefDoc 01.42-p002, File:kits/gcfrefDoc01.42-p002.t.Z
      Error Installing Component:SftShrIndep 10.80-s004, File:kits/SftShrIndep10.80-s004.t.Z
      Error Installing Component:concice_lnx86 61.03-s010lnx86, File:kits/concice61.03-s010lnx86.t.Z
      Error Installing Component:ihdl_lnx86 61.03-s010lnx86, File:kits/ihdl61.03-s010lnx86.t.Z
      Error Installing Component:cdbaReg_lnx86 61.03-s010lnx86, File:kits/cdbaReg61.03-s010lnx86.t.Z
      Error Installing Component:verilogReg_lnx86 61.03-s010lnx86, File:kits/verilogReg61.03-s010lnx86.t.Z
      Error Installing Component:schematics_l_lnx86 61.03-s010lnx86, File:kits/schematics_l61.03-s010lnx86.t.Z
      Error Installing Component:hspice_lnx86 61.03-s010lnx86, File:kits/hspice61.03-s010lnx86.t.Z
      Error Installing Component:mixsimenv_lnx86 61.03-s010lnx86, File:kits/mixsimenv61.03-s010lnx86.t.Z
      Error Installing Component:drdDoc 06.13-p005, File:kits/drdDoc06.13-p005.t.Z
      Error Installing Component:sdfXlate_lnx86 61.03-s010lnx86, File:kits/sdfXlate61.03-s010lnx86.t.Z
      Error Installing Component:skipcrefDocC 07.02-s002, File:kits/skipcrefDocC07.02-s002.t.Z
      Error Installing Component:gdm_lnx86 07.02-s020lnx86, File:kits/gdm07.02-s020lnx86.t.Z
      Error Installing Component:cdsLibEditorDocC 02.40-s003, File:kits/cdsLibEditorDocC02.40-s003.t.Z
      Error Installing Component:hmanReg_lnx86 07.02-s060lnx86, File:kits/hmanReg07.02-s060lnx86.t.Z
      Error Installing Component:dracDIST_lnx86 61.03-s002lnx86, File:kits/dracDIST61.03-s002lnx86.t.Z
      Error Installing Component:viva_lnx86 61.03-s010lnx86, File:kits/viva61.03-s010lnx86.t.Z
      Error Installing Component:tlfUtil_lnx86 07.10-s009lnx86, File:kits/tlfUtil07.10-s009lnx86.t.Z
      Error Installing Component:aelrefDoc 06.13-p002, File:kits/aelrefDoc06.13-p002.t.Z
      Error Installing Component:virtuos_lnx86 07.02-s008lnx86, File:kits/virtuos07.02-s008lnx86.t.Z
      Error Installing Component:lvs64b_lnx86 61.03-s010lnx86, File:kits/lvs64b61.03-s010lnx86.t.Z
      Error Installing Component:leUtil_lnx86 61.03-s010lnx86, File:kits/leUtil61.03-s010lnx86.t.Z
      Error Installing Component:ddAccessG_lnx86 07.02-s034lnx86, File:kits/ddAccessG07.02-s034lnx86.t.Z
      Error Installing Component:coeffgenDoc 02.00-s012, File:kits/coeffgenDoc02.00-s012.t.Z
      Error Installing Component:analoglibDoc 06.13-s001, File:kits/analoglibDoc06.13-s001.t.Z
      Error Installing Component:cdsFileManager_lnx86 07.02-p001lnx86, File:kits/cdsFileManager07.02-p001lnx86.t.Z
      Error Installing Component:dcm_lnx86 61.03-s010lnx86, File:kits/dcm61.03-s010lnx86.t.Z
      Error Installing Component:confData 61.00-p010, File:kits/confData61.00-p010.t.Z
      Error Installing Component:alvs_lnx86 61.03-s010lnx86, File:kits/alvs61.03-s010lnx86.t.Z
      Error Installing Component:mps64b_lnx86 07.02-s008lnx86, File:kits/mps64b07.02-s008lnx86.t.Z
      Error Installing Component:dfIIplus64b_lnx86 61.03-s010lnx86, File:kits/dfIIplus64b61.03-s010lnx86.t.Z
      Error Installing Component:icfb_lnx86 61.03-s010lnx86, File:kits/icfb61.03-s010lnx86.t.Z
      Error Installing Component:iccdlrDoc 06.13-p002, File:kits/iccdlrDoc06.13-p002.t.Z
      Error Installing ComponentascanDoc 22.04-p005, File:kits/oascanDoc22.04-p005.t.Z
      Error Installing Component:vhdlReg_lnx86 61.03-s010lnx86, File:kits/vhdlReg61.03-s010lnx86.t.Z
      Error Installing Component:DFII_ncvhdl64b_lnx86 06.11-s017lnx86, File:kits/DFII_ncvhdl64b06.11-s017lnx86.t.Z
      Error Installing Component:uiReplay_lnx86 07.02-s059lnx86, File:kits/uiReplay07.02-s059lnx86.t.Z
      Error Installing Component:dracERC64b_lnx86 61.03-s002lnx86, File:kits/dracERC64b61.03-s002lnx86.t.Z
      Error Installing Component:skuirefDoc 06.13-d002, File:kits/skuirefDoc06.13-d002.t.Z
      Error Installing Component:skillDev64b_lnx86 07.02-s041lnx86, File:kits/skillDev64b07.02-s041lnx86.t.Z
      Error Installing Component:layerProc64b_lnx86 61.03-s010lnx86, File:kits/layerProc64b61.03-s010lnx86.t.Z
      Error Installing Component:hedElab_lnx86 07.02-s060lnx86, File:kits/hedElab07.02-s060lnx86.t.Z
      Error Installing Component:iccDoc 06.13-p010, File:kits/iccDoc06.13-p010.t.Z
      Error Installing Component:seDoc 06.13-s001, File:kits/seDoc06.13-s001.t.Z
      Error Installing Component:plot64b_lnx86 07.02-s003lnx86, File:kits/plot64b07.02-s003lnx86.t.Z
      Error Installing Component:ocean_lnx86 61.03-s010lnx86, File:kits/ocean61.03-s010lnx86.t.Z
      Error Installing Component:virtuosoReg_lnx86 61.03-s010lnx86, File:kits/virtuosoReg61.03-s010lnx86.t.Z
      Error Installing Component:drac2CORE64b_lnx86 61.03-s002lnx86, File:kits/drac2CORE64b61.03-s002lnx86.t.Z
      Error Installing Component:ivVerify64b_lnx86 61.03-s010lnx86, File:kits/ivVerify64b61.03-s010lnx86.t.Z
      Error Installing Component:rodDoc 06.13-p004, File:kits/rodDoc06.13-p004.t.Z
      Error Installing Component:conciceDoc 03.01-p007, File:kits/conciceDoc03.01-p007.t.Z
      Error Installing Component:vlm_lnx86 61.03-s010lnx86, File:kits/vlm61.03-s010lnx86.t.Z
      Error Installing Component:composerXLDoc 06.13-p009, File:kits/composerXLDoc06.13-p009.t.Z
      Error Installing Component:hed_lnx86 07.02-s060lnx86, File:kits/hed07.02-s060lnx86.t.Z
      Error Installing Component:cadencehelpJavaPI 01.10-p001, File:kits/cadencehelpJavaPI01.10-p001.t.Z
      Error Installing Component:virtuos64b_lnx86 07.02-s008lnx86, File:kits/virtuos64b07.02-s008lnx86.t.Z
      Error Installing Component:dcdfCore_lnx86 61.03-s010lnx86, File:kits/dcdfCore61.03-s010lnx86.t.Z
      Error Installing Component:ivVerify_lnx86 61.03-s010lnx86, File:kits/ivVerify61.03-s010lnx86.t.Z
      Error Installing Component:leToolbox_lnx86 61.03-s010lnx86, File:kits/leToolbox61.03-s010lnx86.t.Z
      Error Installing Component:mdlExpr_lnx86 06.21-d472lnx86, File:kits/mdlExpr06.21-d472lnx86.t.Z
      Error Installing Component:artHspice_lnx86 61.03-s010lnx86, File:kits/artHspice61.03-s010lnx86.t.Z
      Error Installing Component:finder_lnx86 07.02-s041lnx86, File:kits/finder07.02-s041lnx86.t.Z
      Error Installing Component:itk_lnx86 61.03-s010lnx86, File:kits/itk61.03-s010lnx86.t.Z
      Error Installing Component:DFII_nccommon_lnx86 06.11-s017lnx86, File:kits/DFII_nccommon06.11-s017lnx86.t.Z
      Error Installing Component:csssDoc 06.13-p003, File:kits/csssDoc06.13-p003.t.Z
      Error Installing Component:strokeEditor_lnx86 16.00-p002lnx86, File:kits/strokeEditor16.00-p002lnx86.t.Z
      Error Installing Component:mixedsigDoc 06.13-p002, File:kits/mixedsigDoc06.13-p002.t.Z
      Error Installing Component:adp_lnx86 61.03-s010lnx86, File:kits/adp61.03-s010lnx86.t.Z
      Error Installing Component:amsTutorialsDoc 06.13-p005, File:kits/amsTutorialsDoc06.13-p005.t.Z
      Error Installing Component:adle_lnx86 61.03-s010lnx86, File:kits/adle61.03-s010lnx86.t.Z
      Error Installing Component:cdboaDoc 06.13-p002, File:kits/cdboaDoc06.13-p002.t.Z
      Error Installing Component:xlUI_lnx86 61.03-s010lnx86, File:kits/xlUI61.03-s010lnx86.t.Z
      Error Installing Component:auCore64b_lnx86 61.03-s010lnx86, File:kits/auCore64b61.03-s010lnx86.t.Z
      Error Installing Component:icms_lnx86 61.03-s010lnx86, File:kits/icms61.03-s010lnx86.t.Z
      Error Installing Component:vlsgxlDoc 06.13-p002, File:kits/vlsgxlDoc06.13-p002.t.Z
      Error Installing Component:dfIIplus_lnx86 61.03-s010lnx86, File:kits/dfIIplus61.03-s010lnx86.t.Z
      Error Installing Component:skill_lnx86 07.02-s041lnx86, File:kits/skill07.02-s041lnx86.t.Z
      Error Installing Component:uiCore_lnx86 07.02-s059lnx86, File:kits/uiCore07.02-s059lnx86.t.Z
      Error Installing Component:samplesCds_lnx86 61.03-s010lnx86, File:kits/samplesCds61.03-s010lnx86.t.Z
      Error Installing Component:analogLib_lnx86 61.03-s010lnx86, File:kits/analogLib61.03-s010lnx86.t.Z
      Error Installing Component:DFII_ncvhdl_lnx86 06.11-s017lnx86, File:kits/DFII_ncvhdl06.11-s017lnx86.t.Z
      Error Installing Component:icTrans_lnx86 61.03-s010lnx86, File:kits/icTrans61.03-s010lnx86.t.Z
      Error Installing Component:absGen_lnx86 61.03-s010lnx86, File:kits/absGen61.03-s010lnx86.t.Z
      Error Installing Component:schCore_lnx86 61.03-s010lnx86, File:kits/schCore61.03-s010lnx86.t.Z
      Error Installing Component:pcellDoc 06.13-p004, File:kits/pcellDoc06.13-p004.t.Z
      Error Installing Component:dfIIicons_lnx86 61.03-s010lnx86, File:kits/dfIIicons61.03-s010lnx86.t.Z
      Error Installing Component:acdl_lnx86 61.03-s010lnx86, File:kits/acdl61.03-s010lnx86.t.Z
      Error Installing Component:cdsLibManager_lnx86 07.02-p001lnx86, File:kits/cdsLibManager07.02-p001lnx86.t.Z
      Error Installing Component:SftShrTools_lnx86 10.80-s007lnx86, File:kits/SftShrTools10.80-s007lnx86.t.Z
      Error Installing Component:amsenvugDoc 06.13-p043, File:kits/amsenvugDoc06.13-p043.t.Z
      Error Installing Component:vxlhelpDoc 06.13-p016, File:kits/vxlhelpDoc06.13-p016.t.Z
      Error Installing Component:autortDoc 06.13-s002, File:kits/autortDoc06.13-s002.t.Z
      Error Installing Component:cdsJobMonitorDoc 05.00-s010, File:kits/cdsJobMonitorDoc05.00-s010.t.Z
      Error Installing Component:sklanguserDocC 07.02-p006, File:kits/sklanguserDocC07.02-p006.t.Z
      Error Installing Component:iccausrDoc 06.13-p003, File:kits/iccausrDoc06.13-p003.t.Z
      Error Installing Component:cdnWrapperDev 06.01-s013, File:kits/cdnWrapperDev06.01-s013.t.Z
      Error Installing Component:lbs64b_lnx86 07.02-s008lnx86, File:kits/lbs64b07.02-s008lnx86.t.Z
      Error Installing Component:samplesAna_lnx86 61.03-s010lnx86, File:kits/samplesAna61.03-s010lnx86.t.Z
      Error Installing Component:wincfgDoc 06.13-s004, File:kits/wincfgDoc06.13-s004.t.Z
      Error Installing Component:hspicerefDoc 06.13-p001, File:kits/hspicerefDoc06.13-p001.t.Z
      Error Installing Component:ddAccess64bG_lnx86 07.02-s034lnx86, File:kits/ddAccess64bG07.02-s034lnx86.t.Z
      Error Installing Component:skillDev_lnx86 07.02-s041lnx86, File:kits/skillDev07.02-s041lnx86.t.Z
      Error Installing Component:cdsCommon_lnx86 07.02-s020lnx86, File:kits/cdsCommon07.02-s020lnx86.t.Z
      Error Installing Component:oss_lnx86 61.03-s010lnx86, File:kits/oss61.03-s010lnx86.t.Z
      Error Installing Component:monteStats_lnx86 61.03-s010lnx86, File:kits/monteStats61.03-s010lnx86.t.Z
      Error Installing Component:rodlibDoc 06.13-p002, File:kits/rodlibDoc06.13-p002.t.Z
      Error Installing Component:cdsCmonJava_lnx86 07.02-s001lnx86, File:kits/cdsCmonJava07.02-s001lnx86.t.Z
      Error Installing Component:seCore64b_lnx86 61.03-s010lnx86, File:kits/seCore64b61.03-s010lnx86.t.Z
      Error Installing Component:iconLib 02.00-s004, File:kits/iconLib02.00-s004.t.Z
      Error Installing Component:schtr_lnx86 61.03-s010lnx86, File:kits/schtr61.03-s010lnx86.t.Z
      Error Installing Component:techComp_lnx86 61.03-s010lnx86, File:kits/techComp61.03-s010lnx86.t.Z
      Error Installing Component:erc64b_lnx86 61.03-s010lnx86, File:kits/erc64b61.03-s010lnx86.t.Z
      Error Installing Component:coeffgen_lnx86 61.03-s010lnx86, File:kits/coeffgen61.03-s010lnx86.t.Z
      Error Installing Component:inQuery64b_lnx86 61.03-s010lnx86, File:kits/inQuery64b61.03-s010lnx86.t.Z
      Error Installing Component:vsaContext_lnx86 61.03-s010lnx86, File:kits/vsaContext61.03-s010lnx86.t.Z
      Error Installing Component:oainstallDoc 22.04-p010, File:kits/oainstallDoc22.04-p010.t.Z
      Error Installing Component:cdsXmotif64b_lnx86 21.30-s007lnx86, File:kits/cdsXmotif64b21.30-s007lnx86.t.Z
      Error Installing Component:cdsXmotif_lnx86 21.30-s007lnx86, File:kits/cdsXmotif21.30-s007lnx86.t.Z
      Error Installing Component:dfIIworkspaces_lnx86 61.03-s010lnx86, File:kits/dfIIworkspaces61.03-s010lnx86.t.Z
      Error Installing Component:libSablib_lnx86 61.03-s010lnx86, File:kits/libSablib61.03-s010lnx86.t.Z
      Error Installing Component:deft 01.01-p001, File:kits/deft01.01-p001.t.Z
      Error Installing Component:msSrr64b_lnx86 61.03-s010lnx86, File:kits/msSrr64b61.03-s010lnx86.t.Z
      Error Installing Component:adeGXLDoc 06.13-s001, File:kits/adeGXLDoc06.13-s001.t.Z
      Error Installing Component:licenseDoc 10.80-p005, File:kits/licenseDoc10.80-p005.t.Z
      Error Installing Component:schematics_xl64b_lnx86 61.03-s010lnx86, File:kits/schematics_xl64b61.03-s010lnx86.t.Z
      Error Installing Component:cdnOAWrapIndep 07.10-s001, File:kits/cdnOAWrapIndep07.10-s001.t.Z
      Error Installing Component:SuSECompat_lnx86 06.01-p002lnx86, File:kits/SuSECompat06.01-p002lnx86.t.Z
      Error Installing Component:icde_lnx86 61.03-s010lnx86, File:kits/icde61.03-s010lnx86.t.Z
      Error Installing Component:lefdef64b_lnx86 61.03-s010lnx86, File:kits/lefdef64b61.03-s010lnx86.t.Z
      Error Installing Component:fblocklibrefDoc 06.13-p001, File:kits/fblocklibrefDoc06.13-p001.t.Z
      Error Installing Component:cdnWrapper 06.01-s014, File:kits/cdnWrapper06.01-s014.t.Z
      Error Installing Component:lefdefrefDoc 05.70-p018, File:kits/lefdefrefDoc05.70-p018.t.Z
      Error Installing Component:abstractICDoc 06.13-s001, File:kits/abstractICDoc06.13-s001.t.Z
      Error Installing Component:verimix_lnx86 61.03-s010lnx86, File:kits/verimix61.03-s010lnx86.t.Z
      Error Installing Component:icTrans64b_lnx86 61.03-s010lnx86, File:kits/icTrans64b61.03-s010lnx86.t.Z
      Error Installing Component:plotVersa_lnx86 07.02-s003lnx86, File:kits/plotVersa07.02-s003lnx86.t.Z
      Error Installing Component:dsskill64b_lnx86 07.02-s020lnx86, File:kits/dsskill64b07.02-s020lnx86.t.Z
      Error Installing Component:migrateDoc 06.13-p009, File:kits/migrateDoc06.13-p009.t.Z
      Error Installing Component:cadenceHelpDoc 01.10-p029, File:kits/cadenceHelpDoc01.10-p029.t.Z
      Error Installing Component:cdsQT64b_lnx86 04.23-s013lnx86, File:kits/cdsQT64b04.23-s013lnx86.t.Z
      Error Installing Component:auCore_lnx86 61.03-s010lnx86, File:kits/auCore61.03-s010lnx86.t.Z
      Error Installing Component:mwrefDoc 05.00-p008, File:kits/mwrefDoc05.00-p008.t.Z
      Error Installing Component:caiuserDoc 07.02-s009, File:kits/caiuserDoc07.02-s009.t.Z
      Error Installing Component:sklangrefDocC 07.02-s004, File:kits/sklangrefDocC07.02-s004.t.Z
      Error Installing Component:cadencehelpSupport 01.10-p014, File:kits/cadencehelpSupport01.10-p014.t.Z
      Error Installing Component:hierEditorDocC 07.02-s006, File:kits/hierEditorDocC07.02-s006.t.Z
      Error Installing Component:gdm64b_lnx86 07.02-s020lnx86, File:kits/gdm64b07.02-s020lnx86.t.Z
      Error Installing Component:transrefOADoc 06.13-p004, File:kits/transrefOADoc06.13-p004.t.Z
      Error Installing Component:cdsFileManagerDoc 01.30-s005, File:kits/cdsFileManagerDoc01.30-s005.t.Z
      Error Installing Component:cmpVhdlIn_lnx86 61.03-s010lnx86, File:kits/cmpVhdlIn61.03-s010lnx86.t.Z
      Error Installing Component:conn2sch_lnx86 61.03-s010lnx86, File:kits/conn2sch61.03-s010lnx86.t.Z
      Error Installing Component:corners_lnx86 61.03-s010lnx86, File:kits/corners61.03-s010lnx86.t.Z
      Error Installing Component:cdsPerl_lnx86 61.03-s010lnx86, File:kits/cdsPerl61.03-s010lnx86.t.Z
      Error Installing Component:cdsJobMonitor_lnx86 07.02-p001lnx86, File:kits/cdsJobMonitor07.02-p001lnx86.t.Z
      Error Installing Component:constraintsDoc 06.13-s004, File:kits/constraintsDoc06.13-s004.t.Z
      Error Installing Component:iccraftexe64b_lnx86 61.03-s010lnx86, File:kits/iccraftexe64b61.03-s010lnx86.t.Z
      Error Installing Component:cdsJava_lnx86 15.05-s001lnx86, File:kits/cdsJava15.05-s001lnx86.t.Z
      Error Installing Component:iccrafttool_lnx86 61.03-s010lnx86, File:kits/iccrafttool61.03-s010lnx86.t.Z
      Error Installing Component:wave_lnx86 61.03-s010lnx86, File:kits/wave61.03-s010lnx86.t.Z
      Error Installing Component:drac3CORE64b_lnx86 61.03-s002lnx86, File:kits/drac3CORE64b61.03-s002lnx86.t.Z
      Error Installing Component:libBasic_lnx86 61.03-s010lnx86, File:kits/libBasic61.03-s010lnx86.t.Z
      Error Installing Component:vrfd_lnx86 61.03-s010lnx86, File:kits/vrfd61.03-s010lnx86.t.Z
      Error Installing Component:anaPlaceGXLDoc 06.13-p002, File:kits/anaPlaceGXLDoc06.13-p002.t.Z
      Error Installing Component:RFDSolver_lnx86 61.02-s052lnx86, File:kits/RFDSolver61.02-s052lnx86.t.Z
      Error Installing Component:vrfdDoc 06.13-p001, File:kits/vrfdDoc06.13-p001.t.Z
      Error Installing Component:dirsimmodelDoc 06.13-p001, File:kits/dirsimmodelDoc06.13-p001.t.Z
      Error Installing Component:icds_lnx86 61.03-s010lnx86, File:kits/icds61.03-s010lnx86.t.Z
      Error Installing Component:anasimDoc 06.13-s006, File:kits/anasimDoc06.13-s006.t.Z
      Error Installing Component:drlPsl_lnx86 61.03-s010lnx86, File:kits/drlPsl61.03-s010lnx86.t.Z
      Error Installing Component:spectreRFDoc 06.21-p012, File:kits/spectreRFDoc06.21-p012.t.Z
      Error Installing Component:drac2CORE_lnx86 61.03-s002lnx86, File:kits/drac2CORE61.03-s002lnx86.t.Z
      Error Installing Component:ultrasimDoc 06.21-p004, File:kits/ultrasimDoc06.21-p004.t.Z
      Error Installing Component:gccLibRHEL30_lnx86 04.12-p003lnx86, File:kits/gccLibRHEL3004.12-p003lnx86.t.Z
      Error Installing Component:schematics_xl_lnx86 61.03-s010lnx86, File:kits/schematics_xl61.03-s010lnx86.t.Z
      Error Installing Component:uiReplay64b_lnx86 07.02-s059lnx86, File:kits/uiReplay64b07.02-s059lnx86.t.Z
      Error Installing Component:keymapDoc 02.10-p026, File:kits/keymapDoc02.10-p026.t.Z
      Error Installing Component:plot_lnx86 07.02-s003lnx86, File:kits/plot07.02-s003lnx86.t.Z
      Error Installing Component:dfIItoolbars_lnx86 61.03-s010lnx86, File:kits/dfIItoolbars61.03-s010lnx86.t.Z
      Error Installing Component:wavescan_lnx86 61.03-s010lnx86, File:kits/wavescan61.03-s010lnx86.t.Z
      Error Installing Component:ahdlReg_lnx86 61.03-s010lnx86, File:kits/ahdlReg61.03-s010lnx86.t.Z
      Error Installing Component:schView_lnx86 61.03-s010lnx86, File:kits/schView61.03-s010lnx86.t.Z
      Error Installing Component:symphony_lnx86 07.02-p001lnx86, File:kits/symphony07.02-p001lnx86.t.Z
      Error Installing Component:loContext64b_lnx86 61.03-s010lnx86, File:kits/loContext64b61.03-s010lnx86.t.Z
      Error Installing Component:vlm64b_lnx86 61.03-s010lnx86, File:kits/vlm64b61.03-s010lnx86.t.Z
      Error Installing Component:adeXLDoc 06.13-s003, File:kits/adeXLDoc06.13-s003.t.Z
      Error Installing Component:leUtil64b_lnx86 61.03-s010lnx86, File:kits/leUtil64b61.03-s010lnx86.t.Z
      Error Installing Component:skhelpDocH 07.02-p010, File:kits/skhelpDocH07.02-p010.t.Z
      Error Installing Component:mpsJava 07.02-s008, File:kits/mpsJava07.02-s008.t.Z
      Error Installing Component:cadencehelp_lnx86 01.11-p015lnx86, File:kits/cadencehelp01.11-p015lnx86.t.Z
      Error Installing Component:dracERC_lnx86 61.03-s002lnx86, File:kits/dracERC61.03-s002lnx86.t.Z
      Error Installing Component:xlUI64b_lnx86 61.03-s010lnx86, File:kits/xlUI64b61.03-s010lnx86.t.Z
      Error Installing Component:oaRedist_lnx86 22.04-p042lnx86, File:kits/oaRedist22.04-p042lnx86.t.Z
      Error Installing Component:ossrefDocC 06.13-s002, File:kits/ossrefDocC06.13-s002.t.Z
      Error Installing Component:layout64b_lnx86 61.03-s010lnx86, File:kits/layout64b61.03-s010lnx86.t.Z
      Error Installing Component:oacdbDoc 06.13-p001, File:kits/oacdbDoc06.13-p001.t.Z
      Error Installing Component:ise_lnx86 61.03-s010lnx86, File:kits/ise61.03-s010lnx86.t.Z
      Error Installing Component:dracLPE_lnx86 61.03-s002lnx86, File:kits/dracLPE61.03-s002lnx86.t.Z
      Error Installing Component:dracLVS_lnx86 61.03-s002lnx86, File:kits/dracLVS61.03-s002lnx86.t.Z
      Error Installing Component:simProbe_lnx86 61.03-s010lnx86, File:kits/simProbe61.03-s010lnx86.t.Z
      Error Installing Component:cdnOAWrap_lnx86 07.10-s001lnx86, File:kits/cdnOAWrap07.10-s001lnx86.t.Z
      Error Installing Component:dracDRC64b_lnx86 61.03-s002lnx86, File:kits/dracDRC64b61.03-s002lnx86.t.Z
      Error Installing Component:dfIIdb64b_lnx86 61.03-s010lnx86, File:kits/dfIIdb64b61.03-s010lnx86.t.Z
      Error Installing Component:msfb_lnx86 61.03-s010lnx86, File:kits/msfb61.03-s010lnx86.t.Z
      Error Installing Component:layerProc_lnx86 61.03-s010lnx86, File:kits/layerProc61.03-s010lnx86.t.Z
      Error Installing Component:cdswpc_lnx86 07.02-s001lnx86, File:kits/cdswpc07.02-s001lnx86.t.Z
      Error Installing Component:samplesOSS_lnx86 61.03-s010lnx86, File:kits/samplesOSS61.03-s010lnx86.t.Z
      Error Installing Component:vsaCxtExtra_lnx86 10.04-p017lnx86, File:kits/vsaCxtExtra10.04-p017lnx86.t.Z
      Error Installing Component:draciatutDoc 05.00-p006, File:kits/draciatutDoc05.00-p006.t.Z
      Error Installing Component:mps_lnx86 07.02-s008lnx86, File:kits/mps07.02-s008lnx86.t.Z
      Error Installing Component:dfIIdb_lnx86 61.03-s010lnx86, File:kits/dfIIdb61.03-s010lnx86.t.Z
      Error Installing Component:abstract_lnx86 61.03-s010lnx86, File:kits/abstract61.03-s010lnx86.t.Z
      Error Installing Component:vceflowDoc 06.13-p002, File:kits/vceflowDoc06.13-p002.t.Z
Exception Information:
****************************************IN Terminal the followoing  message***********************************************************
at com.khanpur.installerng.CDInstallThread.installPComps(CDInstallThread.java:598)
        at com.khanpur.installerng.CDInstallThread.processMedia(CDInstallThread.java:512)
        at com.khanpur.installerng.CDInstallThread.run(CDInstallThread.java:301)
        at com.khanpur.installerng.CDInstallThread.checkKitSize(CDInstallThread.java:933)
        at com.khanpur.installerng.CDInstallThread.installPC(CDInstallThread.java:841)
Showing Contents of File: /Cadence2/IC613/iscape_logs/20100625_230212_install_log.txt
IScape Version: 03.60.s02
Source: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1
    Component To install:  leToolboxDoc 06.13-s001
    Component To install:  dracDIST64b_lnx86 61.03-s002lnx86
    Component To install:  inQuery_lnx86 61.03-s010lnx86
    Component To install:  dsskill_lnx86 07.02-s020lnx86
    Component To install:  lbsJava 07.02-s008
    Component To install:  dracLPE64b_lnx86 61.03-s002lnx86
    Component To install:  skillPcellPlg_lnx86 61.03-s010lnx86
    Component To install:  skooprefDocC 07.02-s002
    Component To install:  dfiiTagDoc 06.13-p042
    Component To install:  distProcDoc 06.13-p002
    Component To install:  DFII_ncvlog_lnx86 06.11-s017lnx86
    Component To install:  composerReg_lnx86 61.03-s010lnx86
    Component To install:  artLibFunc_lnx86 61.03-s010lnx86
    Component To install:  divarefDoc 05.00-s025
    Component To install:  optimizatn_lnx86 61.03-s010lnx86
    Component To install:  skdfrefDoc 07.02-s016
    Component To install:  amsEnv_lnx86 61.03-s010lnx86
    Component To install:  vsa_lnx86 10.04-p017lnx86
    Component To install:  loContext_lnx86 61.03-s010lnx86
    Component To install:  itkdbaseDoc 06.13-s001
    Component To install:  vlReader_lnx86 61.03-s010lnx86
    Component To install:  spectrei_lnx86 61.03-s010lnx86
    Component To install:  leToolbox64b_lnx86 61.03-s010lnx86
    Component To install:  cadencehelpWrp 01.10-p001
    Component To install:  hed64b_lnx86 07.02-s060lnx86
    Component To install:  uiCore64b_lnx86 07.02-s059lnx86
    Component To install:  dfIIbase_lnx86 61.03-s010lnx86
    Component To install:  skillPcellPlg64b_lnx86 61.03-s010lnx86
    Component To install:  lbs_lnx86 07.02-s008lnx86
    Component To install:  oceanrefDoc 06.13-s005
    Component To install:  iccraftexe_lnx86 61.03-s010lnx86
    Component To install:  analogWave_lnx86 61.03-s010lnx86
    Component To install:  edifinuserDoc 06.13-p002
    Component To install:  erc_lnx86 61.03-s010lnx86
    Component To install:  parasimDoc 06.13-p011
    Component To install:  vsaContext64b_lnx86 61.03-s010lnx86
    Component To install:  deftDoc 06.13-p002
    Component To install:  lfvhdComp_lnx86 02.85-a002lnx86
    Component To install:  samplesMix_lnx86 61.03-s010lnx86
    Component To install:  wavescanDoc 06.13-s001
    Component To install:  lvs_lnx86 61.03-s010lnx86
    Component To install:  skdevrefDocC 07.02-s004
    Component To install:  draciarefDoc 05.00-p005
    Component To install:  artSimEnv_lnx86 61.03-s010lnx86
    Component To install:  plotDoc 06.12-p005
    Component To install:  DFII_nccommon64b_lnx86 06.11-s017lnx86
    Component To install:  abstract64b_lnx86 61.03-s010lnx86
    Component To install:  itk64b_lnx86 61.03-s010lnx86
    Component To install:  ckSysConf_lnx86 02.00-p074lnx86
    Component To install:  cdsCommon64b_lnx86 07.02-s020lnx86
    Component To install:  IC613IX510_lnx86 06.13-p007lnx86
    Component To install:  composerDocC 06.13-s003
    Component To install:  verinuserDoc 06.13-s003
    Component To install:  cdf_lnx86 61.03-s010lnx86
    Component To install:  conn2schDoc 06.13-p001
    Component To install:  mdlDoc 06.21-p003
    Component To install:  cdf64b_lnx86 61.03-s010lnx86
    Component To install:  gcfrefDoc 01.42-p002
    Component To install:  SftShrIndep 10.80-s004
    Component To install:  concice_lnx86 61.03-s010lnx86
    Component To install:  ihdl_lnx86 61.03-s010lnx86
    Component To install:  cdbaReg_lnx86 61.03-s010lnx86
    Component To install:  verilogReg_lnx86 61.03-s010lnx86
    Component To install:  schematics_l_lnx86 61.03-s010lnx86
    Component To install:  vhdlinuserDoc 06.13-p003
    Component To install:  hspice_lnx86 61.03-s010lnx86
    Component To install:  mixsimenv_lnx86 61.03-s010lnx86
    Component To install:  drdDoc 06.13-p005
    Component To install:  sdfXlate_lnx86 61.03-s010lnx86
    Component To install:  skipcrefDocC 07.02-s002
    Component To install:  gdm_lnx86 07.02-s020lnx86
    Component To install:  cdfuserDoc 06.13-p001
    Component To install:  cdsLibEditorDocC 02.40-s003
    Component To install:  hmanReg_lnx86 07.02-s060lnx86
    Component To install:  dracDIST_lnx86 61.03-s002lnx86
    Component To install:  viva_lnx86 61.03-s010lnx86
    Component To install:  tlfUtil_lnx86 07.10-s009lnx86
    Component To install:  aelrefDoc 06.13-p002
    Component To install:  virtuos_lnx86 07.02-s008lnx86
    Component To install:  lvs64b_lnx86 61.03-s010lnx86
    Component To install:  leUtil_lnx86 61.03-s010lnx86
    Component To install:  edif_lnx86 61.03-s010lnx86
    Component To install:  ddAccessG_lnx86 07.02-s034lnx86
    Component To install:  msSrr_lnx86 61.03-s010lnx86
    Component To install:  coeffgenDoc 02.00-s012
    Component To install:  oa2lefdefmapDoc 02.20-p003
    Component To install:  ct_tlfDocR 04.50-p004
    Component To install:  pearl_lnx86 05.10-s101lnx86
    Component To install:  analoglibDoc 06.13-s001
    Component To install:  cdsFileManager_lnx86 07.02-p001lnx86
    Component To install:  verilogI_lnx86 61.03-s010lnx86
    Component To install:  dcm_lnx86 61.03-s010lnx86
    Component To install:  SEVcdnWrap 10.00-p001
    Component To install:  dracularefDoc 05.00-p042
    Component To install:  confData 61.00-p010
    Component To install:  alvs_lnx86 61.03-s010lnx86
    Component To install:  vleDocC 06.13-s012
    Component To install:  mps64b_lnx86 07.02-s008lnx86
    Component To install:  cir_lnx86 06.01-p001lnx86
    Component To install:  dfIIplus64b_lnx86 61.03-s010lnx86
    Component To install:  lefdef_lnx86 61.03-s010lnx86
    Component To install:  dracPRE_lnx86 61.03-s002lnx86
    Component To install:  icfb_lnx86 61.03-s010lnx86
    Component To install:  iccdlrDoc 06.13-p002
    Component To install:  oascanDoc 22.04-p005
    Component To install:  modelwriter_lnx86 61.03-s010lnx86
    Component To install:  vhdlReg_lnx86 61.03-s010lnx86
    Component To install:  cir64b_lnx86 06.01-p001lnx86
    Component To install:  DFII_ncvhdl64b_lnx86 06.11-s017lnx86
    Component To install:  uiReplay_lnx86 07.02-s059lnx86
    Component To install:  skartistrefDoc 06.13-s002
    Component To install:  dracERC64b_lnx86 61.03-s002lnx86
    Component To install:  skuirefDoc 06.13-d002
    Component To install:  skillDev64b_lnx86 07.02-s041lnx86
    Component To install:  layerProc64b_lnx86 61.03-s010lnx86
    Component To install:  hedElab_lnx86 07.02-s060lnx86
    Component To install:  iccDoc 06.13-p010
    Component To install:  seDoc 06.13-s001
    Component To install:  plot64b_lnx86 07.02-s003lnx86
    Component To install:  ocean_lnx86 61.03-s010lnx86
    Component To install:  cdsQT_lnx86 04.23-s013lnx86
    Component To install:  virtuosoReg_lnx86 61.03-s010lnx86
    Component To install:  drac2CORE64b_lnx86 61.03-s002lnx86
    Component To install:  ivVerify64b_lnx86 61.03-s010lnx86
    Component To install:  rodDoc 06.13-p004
    Component To install:  conciceDoc 03.01-p007
    Component To install:  vlm_lnx86 61.03-s010lnx86
    Component To install:  composerXLDoc 06.13-p009
    Component To install:  fprefDoc 06.13-p010
    Component To install:  hed_lnx86 07.02-s060lnx86
    Component To install:  cadencehelpJavaPI 01.10-p001
    Component To install:  dfIIuiPlus_lnx86 61.03-s010lnx86
    Component To install:  virtuos64b_lnx86 07.02-s008lnx86
    Component To install:  dcdfCore_lnx86 61.03-s010lnx86
    Component To install:  ivVerify_lnx86 61.03-s010lnx86
    Component To install:  leToolbox_lnx86 61.03-s010lnx86
    Component To install:  mdlExpr_lnx86 06.21-d472lnx86
    Component To install:  artHspice_lnx86 61.03-s010lnx86
    Component To install:  finder_lnx86 07.02-s041lnx86
    Component To install:  itk_lnx86 61.03-s010lnx86
    Component To install:  DFII_nccommon_lnx86 06.11-s017lnx86
    Component To install:  csssDoc 06.13-p003
    Component To install:  hedElab64b_lnx86 07.02-s060lnx86
    Component To install:  strokeEditor_lnx86 16.00-p002lnx86
    Component To install:  DFII_ncvlog64b_lnx86 06.11-s017lnx86
    Component To install:  installDoc 03.30-p001
    Component To install:  mixedsigDoc 06.13-p002
    Component To install:  adp_lnx86 61.03-s010lnx86
    Component To install:  amsTutorialsDoc 06.13-p005
    Component To install:  adle_lnx86 61.03-s010lnx86
    Component To install:  cdboaDoc 06.13-p002
    Component To install:  dracDRC_lnx86 61.03-s002lnx86
    Component To install:  ct_algDocR 05.00-p005
    Component To install:  xlUI_lnx86 61.03-s010lnx86
    Component To install:  auCore64b_lnx86 61.03-s010lnx86
    Component To install:  icms_lnx86 61.03-s010lnx86
    Component To install:  vlsgxlDoc 06.13-p002
    Component To install:  dfIIplus_lnx86 61.03-s010lnx86
    Component To install:  skill_lnx86 07.02-s041lnx86
    Component To install:  uiCore_lnx86 07.02-s059lnx86
    Component To install:  samplesCds_lnx86 61.03-s010lnx86
    Component To install:  analogLib_lnx86 61.03-s010lnx86
    Component To install:  DFII_ncvhdl_lnx86 06.11-s017lnx86
    Component To install:  icTrans_lnx86 61.03-s010lnx86
    Component To install:  absGen_lnx86 61.03-s010lnx86
    Component To install:  drac3CORE_lnx86 61.03-s002lnx86
    Component To install:  schCore_lnx86 61.03-s010lnx86
    Component To install:  pcellDoc 06.13-p004
    Component To install:  dfIIicons_lnx86 61.03-s010lnx86
    Component To install:  acdl_lnx86 61.03-s010lnx86
    Component To install:  cdsLibManager_lnx86 07.02-p001lnx86
    Component To install:  draculauserDoc 05.00-p017
    Component To install:  SftShrTools_lnx86 10.80-s007lnx86
    Component To install:  amsenvugDoc 06.13-p043
    Component To install:  vxlhelpDoc 06.13-p016
    Component To install:  autortDoc 06.13-s002
    Component To install:  adexl_lnx86 61.03-s010lnx86
    Component To install:  cdsJobMonitorDoc 05.00-s010
    Component To install:  sklanguserDocC 07.02-p006
    Component To install:  iccausrDoc 06.13-p003
    Component To install:  cdnWrapperDev 06.01-s013
    Component To install:  lbs64b_lnx86 07.02-s008lnx86
    Component To install:  samplesAna_lnx86 61.03-s010lnx86
    Component To install:  wincfgDoc 06.13-s004
    Component To install:  hspicerefDoc 06.13-p001
    Component To install:  ddAccess64bG_lnx86 07.02-s034lnx86
    Component To install:  skillDev_lnx86 07.02-s041lnx86
    Component To install:  cdsCommon_lnx86 07.02-s020lnx86
    Component To install:  vavoDoc 10.40-p001
    Component To install:  oss_lnx86 61.03-s010lnx86
    Component To install:  monteStats_lnx86 61.03-s010lnx86
    Component To install:  rodlibDoc 06.13-p002
    Component To install:  cdsCmonJava_lnx86 07.02-s001lnx86
    Component To install:  seCore64b_lnx86 61.03-s010lnx86
    Component To install:  iconLib 02.00-s004
    Component To install:  schtr_lnx86 61.03-s010lnx86
    Component To install:  techComp_lnx86 61.03-s010lnx86
    Component To install:  erc64b_lnx86 61.03-s010lnx86
    Component To install:  coeffgen_lnx86 61.03-s010lnx86
    Component To install:  inQuery64b_lnx86 61.03-s010lnx86
    Component To install:  vsaContext_lnx86 61.03-s010lnx86
    Component To install:  browser_lnx86 07.02-s041lnx86
    Component To install:  oainstallDoc 22.04-p010
    Component To install:  cdsXmotif64b_lnx86 21.30-s007lnx86
    Component To install:  cdsXmotif_lnx86 21.30-s007lnx86
    Component To install:  dfIIworkspaces_lnx86 61.03-s010lnx86
    Component To install:  libSablib_lnx86 61.03-s010lnx86
    Component To install:  deft 01.01-p001
    Component To install:  msSrr64b_lnx86 61.03-s010lnx86
    Component To install:  adeGXLDoc 06.13-s001
    Component To install:  dracLVS64b_lnx86 61.03-s002lnx86
    Component To install:  seCore_lnx86 61.03-s010lnx86
    Component To install:  libManagerDocC 06.12-s011
    Component To install:  licenseDoc 10.80-p005
    Component To install:  schematics_xl64b_lnx86 61.03-s010lnx86
    Component To install:  cdnOAWrapIndep 07.10-s001
    Component To install:  SuSECompat_lnx86 06.01-p002lnx86
    Component To install:  icde_lnx86 61.03-s010lnx86
    Component To install:  lefdef64b_lnx86 61.03-s010lnx86
    Component To install:  fblocklibrefDoc 06.13-p001
    Component To install:  cdnWrapper 06.01-s014
    Component To install:  lefdefrefDoc 05.70-p018
    Component To install:  abstractICDoc 06.13-s001
    Component To install:  cdsXml 01.10-p001
    Component To install:  verimix_lnx86 61.03-s010lnx86
    Component To install:  icTrans64b_lnx86 61.03-s010lnx86
    Component To install:  plotVersa_lnx86 07.02-s003lnx86
    Component To install:  dsskill64b_lnx86 07.02-s020lnx86
    Component To install:  migrateDoc 06.13-p009
    Component To install:  cadenceHelpDoc 01.10-p029
    Component To install:  cdsQT64b_lnx86 04.23-s013lnx86
    Component To install:  auCore_lnx86 61.03-s010lnx86
    Component To install:  skill64b_lnx86 07.02-s041lnx86
    Component To install:  mwrefDoc 05.00-p008
    Component To install:  caiuserDoc 07.02-s009
    Component To install:  sklangrefDocC 07.02-s004
    Component To install:  cadencehelpSupport 01.10-p014
    Component To install:  hierEditorDocC 07.02-s006
    Component To install:  layout_lnx86 61.03-s010lnx86
    Component To install:  gdm64b_lnx86 07.02-s020lnx86
    Component To install:  transrefOADoc 06.13-p004
    Component To install:  compvhdluserDoc 06.13-p001
    Component To install:  cdsFileManagerDoc 01.30-s005
    Component To install:  cmpVhdlIn_lnx86 61.03-s010lnx86
    Component To install:  conn2sch_lnx86 61.03-s010lnx86
    Component To install:  gcf_lnx86 01.02-s101lnx86
    Component To install:  corners_lnx86 61.03-s010lnx86
    Component To install:  cdsPerl_lnx86 61.03-s010lnx86
    Component To install:  cdsJobMonitor_lnx86 07.02-p001lnx86
    Component To install:  techfileDocC 06.13-s003
    Component To install:  constraintsDoc 06.13-s004
    Component To install:  iccraftexe64b_lnx86 61.03-s010lnx86
    Component To install:  cdsJava_lnx86 15.05-s001lnx86
    Component To install:  iccrafttool_lnx86 61.03-s010lnx86
    Component To install:  wave_lnx86 61.03-s010lnx86
    Component To install:  drac3CORE64b_lnx86 61.03-s002lnx86
    Component To install:  libBasic_lnx86 61.03-s010lnx86
    Component To install:  vrfd_lnx86 61.03-s010lnx86
    Component To install:  anaPlaceGXLDoc 06.13-p002
    Component To install:  dfoaAdoptDoc 06.13-s001
    Component To install:  RFDSolver_lnx86 61.02-s052lnx86
    Component To install:  vrfdDoc 06.13-p001
    Component To install:  dirsimmodelDoc 06.13-p001
    Component To install:  icds_lnx86 61.03-s010lnx86
    Component To install:  anasimDoc 06.13-s006
    Component To install:  drlPsl_lnx86 61.03-s010lnx86
    Component To install:  spectreRFDoc 06.21-p012
    Component To install:  drac2CORE_lnx86 61.03-s002lnx86
    Component To install:  cdsTcl_lnx86 08.06-p001lnx86
    Component To install:  ultrasimDoc 06.21-p004
    Component To install:  gccLibRHEL30_lnx86 04.12-p003lnx86
    Component To install:  schematics_xl_lnx86 61.03-s010lnx86
    Component To install:  sklayoutrefDoc 06.13-s006
    Component To install:  uiReplay64b_lnx86 07.02-s059lnx86
    Component To install:  keymapDoc 02.10-p026
    Component To install:  plot_lnx86 07.02-s003lnx86
    Component To install:  cdsTk_lnx86 08.06-p001lnx86
    Component To install:  dfIItoolbars_lnx86 61.03-s010lnx86
    Component To install:  wavescan_lnx86 61.03-s010lnx86
    Component To install:  ahdlReg_lnx86 61.03-s010lnx86
    Component To install:  schView_lnx86 61.03-s010lnx86
    Component To install:  symphony_lnx86 07.02-p001lnx86
    Component To install:  loContext64b_lnx86 61.03-s010lnx86
    Component To install:  vlm64b_lnx86 61.03-s010lnx86
    Component To install:  adeXLDoc 06.13-s003
    Component To install:  leUtil64b_lnx86 61.03-s010lnx86
    Component To install:  skhelpDocH 07.02-p010
    Component To install:  mpsJava 07.02-s008
    Component To install:  cadencehelp_lnx86 01.11-p015lnx86
    Component To install:  dracERC_lnx86 61.03-s002lnx86
    Component To install:  xlUI64b_lnx86 61.03-s010lnx86
    Component To install:  oaRedist_lnx86 22.04-p042lnx86
    Component To install:  verilogASamples_lnx86 61.03-s010lnx86
    Component To install:  ossrefDocC 06.13-s002
    Component To install:  layout64b_lnx86 61.03-s010lnx86
    Component To install:  oacdbDoc 06.13-p001
    Component To install:  ise_lnx86 61.03-s010lnx86
    Component To install:  dracLPE_lnx86 61.03-s002lnx86
    Component To install:  vcphelpDoc 06.13-p005
    Component To install:  dracLVS_lnx86 61.03-s002lnx86
    Component To install:  simProbe_lnx86 61.03-s010lnx86
    Component To install:  compverDocC 06.13-s002
    Component To install:  cdnOAWrap_lnx86 07.10-s001lnx86
    Component To install:  dracDRC64b_lnx86 61.03-s002lnx86
    Component To install:  dfIIdb64b_lnx86 61.03-s010lnx86
    Component To install:  msfb_lnx86 61.03-s010lnx86
    Component To install:  layerProc_lnx86 61.03-s010lnx86
    Component To install:  cdswpc_lnx86 07.02-s001lnx86
    Component To install:  samplesOSS_lnx86 61.03-s010lnx86
    Component To install:  vsaCxtExtra_lnx86 10.04-p017lnx86
    Component To install:  draciatutDoc 05.00-p006
    Component To install:  mps_lnx86 07.02-s008lnx86
    Component To install:  slfiles_lnx86 IC-613_06.13.510_lnx86
    Component To install:  dfIIdb_lnx86 61.03-s010lnx86
    Component To install:  abstract_lnx86 61.03-s010lnx86
    Component To install:  vceflowDoc 06.13-p002
    Component To install:  dracPRE64b_lnx86 61.03-s002lnx86
Combined size of components (compressed) to install:2718501323 Bytes
Disk space required for installation (Uncompressed size of compoennts):4547654687 Bytes
Exporting environment...Instantiating media at:/media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1 InstallComponent: IC-613_06.13.510_lnx86
    Installing component (CDROM): slfiles_lnx86 IC-613_06.13.510_lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/IC-613_06.13.510_lnx86.zip
   To:/Cadence2/IC613
    Installed Component: slfiles_lnx86 IC-613_06.13.510_lnx86
    Installing component (CDROM): leToolboxDoc 06.13-s001
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/leToolboxDoc06.13-s001.t.Z
   To:/Cadence2/IC613
    Installed Component: leToolboxDoc 06.13-s001
    Installing component (CDROM): inQuery_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/inQuery61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: inQuery_lnx86 61.03-s010lnx86
    Installing component (CDROM): vsa_lnx86 10.04-p017lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/vsa10.04-p017lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: vsa_lnx86 10.04-p017lnx86
    Installing component (CDROM): erc_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/erc61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: erc_lnx86 61.03-s010lnx86
    Installing component (CDROM): parasimDoc 06.13-p011
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/parasimDoc06.13-p011.t.Z
   To:/Cadence2/IC613
    Installed Component: parasimDoc 06.13-p011
    Installing component (CDROM): lvs_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/lvs61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: lvs_lnx86 61.03-s010lnx86
    Installing component (CDROM): artSimEnv_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/artSimEnv61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: artSimEnv_lnx86 61.03-s010lnx86
    Installing component (CDROM): cdsCommon64b_lnx86 07.02-s020lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/cdsCommon64b07.02-s020lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: cdsCommon64b_lnx86 07.02-s020lnx86
    Installing component (CDROM): IC613IX510_lnx86 06.13-p007lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/IC613IX51006.13-p007lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: IC613IX510_lnx86 06.13-p007lnx86
    Installing component (CDROM): vhdlinuserDoc 06.13-p003
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/vhdlinuserDoc06.13-p003.t.Z
   To:/Cadence2/IC613
    Installed Component: vhdlinuserDoc 06.13-p003
    Installing component (CDROM): cdfuserDoc 06.13-p001
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/cdfuserDoc06.13-p001.t.Z
   To:/Cadence2/IC613
    Installed Component: cdfuserDoc 06.13-p001
    Installing component (CDROM): edif_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/edif61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: edif_lnx86 61.03-s010lnx86
    Installing component (CDROM): msSrr_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/msSrr61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: msSrr_lnx86 61.03-s010lnx86
    Installing component (CDROM): ct_tlfDocR 04.50-p004
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/ct_tlfDocR04.50-p004.t.Z
   To:/Cadence2/IC613
    Installed Component: ct_tlfDocR 04.50-p004
    Installing component (CDROM): verilogI_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/verilogI61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: verilogI_lnx86 61.03-s010lnx86
    Installing component (CDROM): dracularefDoc 05.00-p042
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dracularefDoc05.00-p042.t.Z
   To:/Cadence2/IC613
    Installed Component: dracularefDoc 05.00-p042
    Installing component (CDROM): vleDocC 06.13-s012
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/vleDocC06.13-s012.t.Z
   To:/Cadence2/IC613
    Installed Component: vleDocC 06.13-s012
    Installing component (CDROM): lefdef_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/lefdef61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: lefdef_lnx86 61.03-s010lnx86
    Installing component (CDROM): dracPRE_lnx86 61.03-s002lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dracPRE61.03-s002lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: dracPRE_lnx86 61.03-s002lnx86
    Installing component (CDROM): modelwriter_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/modelwriter61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: modelwriter_lnx86 61.03-s010lnx86
    Installing component (CDROM): skartistrefDoc 06.13-s002
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/skartistrefDoc06.13-s002.t.Z
   To:/Cadence2/IC613
    Installed Component: skartistrefDoc 06.13-s002
    Installing component (CDROM): cdsQT_lnx86 04.23-s013lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/cdsQT04.23-s013lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: cdsQT_lnx86 04.23-s013lnx86
    Installing component (CDROM): fprefDoc 06.13-p010
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/fprefDoc06.13-p010.t.Z
   To:/Cadence2/IC613
    Installed Component: fprefDoc 06.13-p010
    Installing component (CDROM): dfIIuiPlus_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dfIIuiPlus61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: dfIIuiPlus_lnx86 61.03-s010lnx86
    Installing component (CDROM): hedElab64b_lnx86 07.02-s060lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/hedElab64b07.02-s060lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: hedElab64b_lnx86 07.02-s060lnx86
    Installing component (CDROM): DFII_ncvlog64b_lnx86 06.11-s017lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/DFII_ncvlog64b06.11-s017lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: DFII_ncvlog64b_lnx86 06.11-s017lnx86
    Installing component (CDROM): dracDRC_lnx86 61.03-s002lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dracDRC61.03-s002lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: dracDRC_lnx86 61.03-s002lnx86
    Installing component (CDROM): drac3CORE_lnx86 61.03-s002lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/drac3CORE61.03-s002lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: drac3CORE_lnx86 61.03-s002lnx86
    Installing component (CDROM): draculauserDoc 05.00-p017
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/draculauserDoc05.00-p017.t.Z
   To:/Cadence2/IC613
    Installed Component: draculauserDoc 05.00-p017
    Installing component (CDROM): adexl_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/adexl61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: adexl_lnx86 61.03-s010lnx86
    Installing component (CDROM): vavoDoc 10.40-p001
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/vavoDoc10.40-p001.t.Z
   To:/Cadence2/IC613
    Installed Component: vavoDoc 10.40-p001
    Installing component (CDROM): browser_lnx86 07.02-s041lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/browser07.02-s041lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: browser_lnx86 07.02-s041lnx86
    Installing component (CDROM): dracLVS64b_lnx86 61.03-s002lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dracLVS64b61.03-s002lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: dracLVS64b_lnx86 61.03-s002lnx86
    Installing component (CDROM): seCore_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/seCore61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: seCore_lnx86 61.03-s010lnx86
    Installing component (CDROM): libManagerDocC 06.12-s011
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/libManagerDocC06.12-s011.t.Z
   To:/Cadence2/IC613
    Installed Component: libManagerDocC 06.12-s011
    Installing component (CDROM): skill64b_lnx86 07.02-s041lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/skill64b07.02-s041lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: skill64b_lnx86 07.02-s041lnx86
    Installing component (CDROM): layout_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/layout61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: layout_lnx86 61.03-s010lnx86
    Installing component (CDROM): compvhdluserDoc 06.13-p001
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/compvhdluserDoc06.13-p001.t.Z
   To:/Cadence2/IC613
    Installed Component: compvhdluserDoc 06.13-p001
    Installing component (CDROM): techfileDocC 06.13-s003
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/techfileDocC06.13-s003.t.Z
   To:/Cadence2/IC613
    Installed Component: techfileDocC 06.13-s003
    Installing component (CDROM): dfoaAdoptDoc 06.13-s001
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dfoaAdoptDoc06.13-s001.t.Z
   To:/Cadence2/IC613
    Installed Component: dfoaAdoptDoc 06.13-s001
    Installing component (CDROM): sklayoutrefDoc 06.13-s006
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/sklayoutrefDoc06.13-s006.t.Z
   To:/Cadence2/IC613
    Installed Component: sklayoutrefDoc 06.13-s006
    Installing component (CDROM): verilogASamples_lnx86 61.03-s010lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/verilogASamples61.03-s010lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: verilogASamples_lnx86 61.03-s010lnx86
    Installing component (CDROM): vcphelpDoc 06.13-p005
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/vcphelpDoc06.13-p005.t.Z
   To:/Cadence2/IC613
    Installed Component: vcphelpDoc 06.13-p005
    Installing component (CDROM): compverDocC 06.13-s002
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/compverDocC06.13-s002.t.Z
   To:/Cadence2/IC613
    Installed Component: compverDocC 06.13-s002
    Installing component (CDROM): dracPRE64b_lnx86 61.03-s002lnx86
    From: /media/cdrecorder6/IC06.13.510-613_lnx86.Hotfix/CDROM1/kits/dracPRE64b61.03-s002lnx86.t.Z
   To:/Cadence2/IC613
    Installed Component: dracPRE64b_lnx86 61.03-s002lnx86
    Installing component (CDROM): oa2lefdefmapDoc 02.20-p003
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom1/IMAGES.DIR/FS.69
   To:/Cadence2/IC613
    Installed Component: oa2lefdefmapDoc 02.20-p003
    Installing component (CDROM): installDoc 03.30-p001
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom1/IMAGES.DIR/FS.61
   To:/Cadence2/IC613
    Installed Component: installDoc 03.30-p001
    Installing component (CDROM): lfvhdComp_lnx86 02.85-a002lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom2/IMAGES.DIR/FS.63
   To:/Cadence2/IC613
    Installed Component: lfvhdComp_lnx86 02.85-a002lnx86
    Installing component (CDROM): SEVcdnWrap 10.00-p001
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom2/IMAGES.DIR/FS.91
   To:/Cadence2/IC613
    Installed Component: SEVcdnWrap 10.00-p001
    Installing component (CDROM): cir_lnx86 06.01-p001lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom2/IMAGES.DIR/FS.50
   To:/Cadence2/IC613
    Installed Component: cir_lnx86 06.01-p001lnx86
    Installing component (CDROM): cir64b_lnx86 06.01-p001lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom2/IMAGES.DIR/FS.108
   To:/Cadence2/IC613
    Installed Component: cir64b_lnx86 06.01-p001lnx86
    Installing component (CDROM): pearl_lnx86 05.10-s101lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.62
   To:/Cadence2/IC613
    Installed Component: pearl_lnx86 05.10-s101lnx86
    Installing component (CDROM): ct_algDocR 05.00-p005
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.49
   To:/Cadence2/IC613
    Installed Component: ct_algDocR 05.00-p005
    Installing component (CDROM): cdsXml 01.10-p001
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.47
   To:/Cadence2/IC613
    Installed Component: cdsXml 01.10-p001
    Installing component (CDROM): gcf_lnx86 01.02-s101lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.54
   To:/Cadence2/IC613
    Installed Component: gcf_lnx86 01.02-s101lnx86
    Installing component (CDROM): cdsTcl_lnx86 08.06-p001lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.45
   To:/Cadence2/IC613
    Installed Component: cdsTcl_lnx86 08.06-p001lnx86
    Installing component (CDROM): cdsTk_lnx86 08.06-p001lnx86
    From: /media/PATRIOT/IC610_lnx86.Base/cdrom4/IMAGES.DIR/FS.46
   To:/Cadence2/IC613
    Installed Component: cdsTk_lnx86 08.06-p001lnx86
    Time taken for installation: 00:04:06 hh:mm:ss
None of the selected products were successfully installed.
    207:Waveform
    365:Dracula(R) Graphical User Interface
    70110:Dracula(R) Design Rule Checker
    70120:Dracula(R) Layout Vs. Schematic Verifier
      Error Installing Component:optimizatn_lnx86 61.03-s010lnx86, File:kits/optimizatn61.03-s010lnx86.t.Z
      Error Installing Component:oceanrefDoc 06.13-s005, File:kits/oceanrefDoc06.13-s005.t.Z
      Error Installing Component:oascanDoc 22.04-p005, File:kits/oascanDoc22.04-p005.t.Z
发表于 2010-7-22 16:13:40 | 显示全部楼层
什么咚咚?
发表于 2010-7-22 22:00:50 | 显示全部楼层
日志里没写因为什么错啊??
发表于 2010-7-22 22:02:54 | 显示全部楼层
装613 要 610的安装盘??
发表于 2010-7-23 15:43:01 | 显示全部楼层
装613 要 610的安装盘??
aceafee 发表于 2010-7-22 22:02
If you do the fresh install by using IC613_Hotfix, you need IC610_Base in order to complete the installation.
You do not need IC610_Base if you are using IC613_Update.
Thanks.
发表于 2012-3-17 13:49:49 | 显示全部楼层
回复 1# pengjeff
    Seems like license problem
发表于 2012-7-31 19:11:08 | 显示全部楼层
安装时没有MediaID。txt
发表于 2012-7-31 19:14:19 | 显示全部楼层
MediaID="Base_IC610_lnx86"
MediaDisplayName="Base IC610 lnx86 P/N 356-70352-070"
MediaNumber="1"
MediaNumber="2"
发表于 2012-8-1 01:36:11 | 显示全部楼层
Specify Base IC 6.1 and this should work.
发表于 2012-10-24 16:53:37 | 显示全部楼层
very goodthanks agian
GMT+8, 2025-7-31 09:00 , Processed in 0.031088 second(s), 9 queries , Gzip On, Redis On.
