查看: 2159|回复: 0
[求助] nios eclipse :cygpath: can't convert empty path
发表于 2016-7-21 17:54:20 | 显示全部楼层 |阅读模式
**** Build of configuration Default for project mynios_ch395 ****
make all
系统找不到指定的路径。
系统找不到指定的路径。
Info: Building ../mynios_ch395_bsp/
make --no-print-directory -C ../mynios_ch395_bsp/
process_begin: CreateProcess(NULL, pwd, ...) failed.
make[1]: *** No rule to make target `/system.h', needed by `all'.  Stop.
make: *** [../mynios_ch395_bsp/-recurs-make-lib] Error 2
**** Build Finished ****
不知道怎么解。。。。
我安装了MINGW,指定了环境变量,还是不行
GMT+8, 2025-9-15 07:05 , Processed in 0.017717 second(s), 5 queries , Gzip On, Redis On.
