楼主: kliujie123
[求助] xilinx pcie gen3 endpoint dma 仿真求助.
发表于 2018-1-24 05:00:41 | 显示全部楼层
回复 10# billwaston
encountered the same problem, could masters shine some light, many thanks
发表于 2018-1-27 10:21:17 | 显示全部楼层
Check if root post has enabled EP's "Bus Master Enable" bit in the configuration register space.
solarjet
GMT+8, 2025-12-27 01:25 , Processed in 0.016646 second(s), 6 queries , Gzip On, Redis On.
