查看: 9300|回复: 11
[求助] Calibre做lvs出现的问题,求助!!!!!
发表于 2016-5-26 18:51:06 | 显示全部楼层 |阅读模式
CELL COMPARISON RESULTS ( TOP LEVEL )
                   #           #     NOT COMPARED     #
  Error:    Different numbers of ports (see below).
  Error:    Power net missing in layout. Ground net missing in layout.
LAYOUT CELL NAME:         fsm_3always
SOURCE CELL NAME:         fsm_3always
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              0        11    *
Nets:             162       163    *
Instances:        337       325    *    MN (4 pins)
                   338       324    *    MP (4 pins)
Total Inst:       675       649
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              0        10    *
Nets:              85        85
Instances:         11         8    *    MN (4 pins)
                     9         6    *    MP (4 pins)
                     0         3    *    INV (2 pins)
                     0         1    *    SPDW_2_1_1 (5 pins)
                     0         2    *    SPDW_2_2 (5 pins)
                     0         2    *    SPUP_2_1 (4 pins)
                     0         2    *    SPUP_2_2_1 (6 pins)
                     1         0    *    SPMN_2_1_1 (6 pins)
                     2         0    *    SPMN_2_2 (6 pins)
                     2         0    *    SPMP_2_1 (5 pins)
                     2         0    *    SPMP_2_2_1 (7 pins)
                     3         3         _invb (6 pins)
                    38        38         _invv (4 pins)
                     8         8         _invx2v (4 pins)
                     1         1         _invx4v (4 pins)
                     3         3         _nand2v (5 pins)
                     1         1         _nand3v (6 pins)
                     3         3         _nand4v (7 pins)
                     2         2         _nor2v (5 pins)
                     1         1         _nor4v (7 pins)
                    20        20         _sdw2v (4 pins)
                    17        17         _smp2v (4 pins)
Total Inst:       124       121
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
o Statistics:
   1 passthrough source net was deleted.
   453 layout mos transistors were reduced to 80.
     373 mos transistors were deleted by parallel reduction.
   414 source mos transistors were reduced to 67.
     347 mos transistors were deleted by parallel reduction.
 楼主| 发表于 2016-5-26 18:52:21 | 显示全部楼层
请教各位大神,怎么我的layout里一个port也没有
发表于 2016-5-26 20:33:48 | 显示全部楼层
没打label造成的?我也不是很清楚
发表于 2016-5-26 21:10:30 | 显示全部楼层
楼上正解,就是没有label造成的
 楼主| 发表于 2016-5-26 23:11:43 | 显示全部楼层
打了label,是用pin那层金属打的
发表于 2016-5-27 15:33:37 | 显示全部楼层
回复 1# ljxcanye
    打terminal就可以,打text也可以,我想问你,你如果在ICC中去debug,是怎么定位到哪个port有问题的?我在report中并没有看到提示是哪个port出问题
发表于 2016-5-27 15:43:41 | 显示全部楼层
port为0,一定是你label没打好--- 仔细研读下DR吧
发表于 2016-5-27 16:55:58 | 显示全部楼层
查下你的lvs rule 是不是 text map 的层次错了,看下gds里的text是不是和 rule里层次一致
发表于 2016-5-27 17:18:13 | 显示全部楼层
用text那层打
发表于 2016-5-27 17:51:03 | 显示全部楼层
回复 7# kopzinc
请问,如果在ICC中去debug,是怎么定位到哪个port有问题的?我在report中并没有看到提示是哪个port出问题
GMT+8, 2025-12-21 22:12 , Processed in 0.021704 second(s), 5 queries , Gzip On, Redis On.
