查看: 2994|回复: 0
[求助] 数模混合仿真的出现的问题
发表于 2016-5-16 15:36:54 | 显示全部楼层 |阅读模式
我在进行Cadence数模混仿的时候总报错,我将报错的后几行写下,希望哪位高手帮忙指点一下,
****Netlisting of cell-mix,view-config successful.
End netlisting Dec31 09:33:13 2009
End MS Netlisting Dec31 09:33:13 2009
           ...successful.
compose simulator input file...
*Error*fprintf/sprintf:format spec.incompatible with date-nil
我再双击这个错误就会出现
SYNTAX ERROR found at line 2 column 2 of file *ciwInport*
*Error*lineread/read:syntax error encuontered in input
不知道这是哪有问题,我的混仿步骤如下:首先,对Schematic原理图生成Config文件,然后在Config文件下仿真,Tools--Analog Environment--setup--Simulator/Directory/Host--选仿真器SpectreVerilog--Model Libraries加载库--Simuli---Analog--设置仿真参数--Analyses设置仿真时间,最后在Mixed-Signal--Interface Elements--Instance--点击图中数字模块设置高低电平-output-d2a_(default):2n,d2a_tr(default):3n,d2a_vh(...from instance):1.3,d2a_vl(...from instance):0.8,---input--a2d_tx(default):1m,a2d_v0(...from instance):0.8,a2d_v1(....from instance):1.3
仿真就出现上述错误,急切请高手帮忙啊~拜托
GMT+8, 2025-12-14 13:17 , Processed in 0.016929 second(s), 6 queries , Gzip On, Redis On.
