查看: 2573|回复: 3
[求助] 关于verilog testbench中将多个结果写到txt文件会覆盖的问题
发表于 2016-4-25 16:36:18 | 显示全部楼层 |阅读模式
大家好!写了一段testbench,想把每次得到的结果输出到同一个文件中,但是发现最后的值覆盖了前面的几个,代码如下:
  1. always @(rxd or txd)
  2. begin
  3. write_out_file = $fopen("write_out_file.txt","w");
  4. #1200;
  5. if(txd===rxd)
  6. begin
  7. $fdisplay(write_out_file,"\n **** time=%t ****",$time);
  8. $fdisplay(write_out_file,"OK! txd=%d,rxd=%d",txd,rxd);
  9. end
  10. else
  11. begin
  12. $fdisplay(write_out_file,"\n **** time=%t ****",$time);
  13. $fdisplay(write_out_file,"ERROR! txd != rxd" );
  14. $fdisplay(write_out_file,"ERROR! txd=%d, rxd=%d",txd,rxd);
  15. end
  16. $fclose(write_out_file);
  17. end
    复制代码
想不到解决办法,求助啊,谢谢大家!
发表于 2016-4-25 17:45:12 | 显示全部楼层
跑完一个case后,mv write_out_file.txt write_out_file_xxx.txt 再去跑下一个。不然连续跑肯定是覆盖
发表于 2016-4-26 09:16:45 | 显示全部楼层
回复 1# xcxfly
   $fopen里面不是有选项么,"w"/"r"/"a",你看看有啥区别。
 楼主| 发表于 2016-4-26 14:00:53 | 显示全部楼层
回复 3# harry_hust
   好的,谢谢你~
GMT+8, 2025-12-27 15:35 , Processed in 0.016035 second(s), 5 queries , Gzip On, Redis On.
