查看: 3557|回复: 5
[讨论] 大家讨论一下如何评估一个工艺
发表于 2016-4-20 20:00:08 | 显示全部楼层 |阅读模式
如题,我能想到的有digital core的最小线宽,mos管的耐压、ft、匹配,电阻的方块电阻与匹配精度,电容的类型、单位面积电容与匹配精度,rf可能需要用来制作电感的高层金属,power方面我听说过rdson,希望大家补充,多谢
发表于 2016-4-20 20:11:24 | 显示全部楼层
JEDEC JP001A
发表于 2016-4-20 21:16:10 | 显示全部楼层
For mmrf cmos tech, it's notable if it provides
1. High Q inductor on top of the thicker copper metal
2. High density MIM cap
3. Cost effective MOM cap
4. Precision poly resisters
5. Deep Nwell isolation
6. Multiple Vth device for performance optimazation
7. Wide tuning range Varactors
发表于 2016-4-20 21:17:29 | 显示全部楼层
cost per mm^2
发表于 2016-4-21 11:03:56 | 显示全部楼层
BOSS Only care Cost even the 工艺水準 is very bad,
結果就是害工程師辛苦的要命.
 楼主| 发表于 2016-4-21 21:47:45 | 显示全部楼层
GMT+8, 2025-12-23 20:16 , Processed in 0.019613 second(s), 5 queries , Gzip On, Redis On.
