查看: 2159|回复: 0
[招聘] Senior engineer for IC design & verification (DE/DV)engineering
发表于 2016-4-19 17:41:07 | 显示全部楼层 |阅读模式
Senior engineer for IC design engineering (Sr. DE)
Requirements:
The candidate is preferred to be MSEE with minimum of 3 years, or BSEE with
minimum of 5 years
experience in digital ASIC/SOC design engineering.
The candidate should have good understanding on ASIC/SOC design flow and must be proficient in two or more of the following skill sets:
It is a must that the candidate has one or more of the following experience/knowledge, such as X86/ARM/8051 architecture, AMBA(AXI/AHB/APB) bus, USB(3.0/2.0/1.1; SSIC/HSIC/host/device/OTG) system, NAND Flash host controller/BCH/double-data-rate interface,
Universal Flash Storage, PCI-E/PCI bus, low power design, clock generation and control, SD/eMMC host controller, SATA/SAS, Legacy IPs (SPI/SMBUS/ACPI/LPC/GPIO), General connectivity IPs (I2S/I2C/UART), Ethernet, JTAG
, etc.
The candidate is expected to exhibit good verbal and written communication skills in both Chinese and English, imaginative thinking and sophisticated analytical techniques, self-driven for quality and timely result, capability
to solve complex problems and makes some modifications to standard methods and decision-making on important technical areas.
Responsibility:
The successful candidate will work with team members and apply his/her design techniques to work on different phases of complex logic design for ASIC/SOC project. The role will include working on the following tasks from time to time: specification, top level SOC design tasks, HDL coding, etc.
Senior engineer for IC design verification (Sr. DV)
Requirements:
minimum of 5 years
experience in digital ASIC/SOC design verification.
The candidate should have good understanding on ASIC/SOC design flow and should have:
1.
Good knowledge of design verification methodology, such as
UVM or OVM
2.
Many experiences with simulation model creation and the testbench build
3.
Strong RTL coding with Verilog and familiar with front-end design flow
4.
Strong C/C++ software development experiences
5.
Be familiar with scripting language, such as Perl, C shell, Makefile.
It is a plus if the candidate has one or more of the following experience/knowledge, such as X86/ARM/8051 architecture, AMBA(AXI/AHB/APB) bus, USB(3.0/2.0/1.1; SSIC/HSIC/host/device/OTG) system, NAND Flash host controller/BCH/double-data-rate interface, Universal Flash Storage, PCI-E/PCI bus, low power design, clock generation and control, SD/eMMC host controller, SATA/SAS, Legacy IPs (SPI/SMBUS/ACPI/LPC/GPIO), General connectivity IPs (I2S/I2C/UART), Ethernet, JTAG, etc.
Hands-on lab experience is another plus, able to understand and/or use the use scopes, logic analyzers, has knowledge or skill of board-level lab debugging.
Responsibility:
The successful candidate will apply current functional verification techniques to perform and improve pre-silicon verification quality and product Time to Market for ASIC/SOC design.
He/She should be able to work independently on various DV tasks and providing technical guidance to the DV team. The candidate would involve technically in the porting/creation of the DV environment for the new design, block and chip level test plan creation and implementation, coverage analysis, and regression cleanup.
有意者将简历 以“姓名-应聘职位-EETOP”的形式发送到 Nina.Zhang@amd.com的邮箱。
我们会尽快与您联系!
GMT+8, 2025-12-29 02:08 , Processed in 0.024740 second(s), 6 queries , Gzip On, Redis On.
