查看: 9406|回复: 46
Adaptive Techniques for Mixed Signal System on Chip
发表于 2007-6-2 00:41:27 | 显示全部楼层 |阅读模式
Adaptive Techniques for Mixed Signal System on Chip (The International Series in Engineering and Com
Book Description:
Adaptive Techniques for Mixed Signal Sytem on Chip discusses the concept of adaptation in the context of analog and mixed signal design along with different adaptive architectures used to control any system parameter. The first part of the book gives an overview of the different elements that are normally used in adaptive designs including tunable elements as well as voltage, current, and time references with an emphasis on the circuit design of specific blocks such as voltage-controlled transconductors, offset comparators, and a novel technique for accurate implementation of on chip resistors. While the first part of the book addresses adaptive freeduan.com techniques at the circuit and block levels, the second part discusses adaptive equalization architectures employed to minimize the impact of ISI (Intersymbol Interference) on the quality of received data in high-speed wire line transceivers. It presents the implementation of a 125Mbps transceiver operating over a variable length of Category 5 (CAT-5) Ethernet cable as an example of adaptive equalizers.
 楼主| 发表于 2007-6-2 00:47:15 | 显示全部楼层
Adaptive Techniques for Mixed Signal System on Chip.zip
2.79 MB, 下载次数: 377 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-2 23:39:25 | 显示全部楼层
不知道怎么样,下载来看看
发表于 2007-6-2 23:42:36 | 显示全部楼层
值得一看,不过意义不打
发表于 2007-6-3 11:06:30 | 显示全部楼层
下了再说
发表于 2007-6-3 19:14:23 | 显示全部楼层
kankan
发表于 2007-6-5 18:48:50 | 显示全部楼层
可以打开的
发表于 2007-6-5 18:51:57 | 显示全部楼层
很多模拟产品,不用trim就只好adptive 了。
设计时有这样一个概念就成。
发表于 2007-6-6 07:59:29 | 显示全部楼层
have a look
发表于 2007-10-30 16:52:11 | 显示全部楼层
好書! 感謝!
GMT+8, 2025-12-29 20:43 , Processed in 0.028942 second(s), 7 queries , Gzip On, Redis On.
