查看: 2891|回复: 1
[求助] CentOS6.4 安装之后vcsmx_2014.03运行报license问题
发表于 2016-4-12 16:06:17 | 显示全部楼层 |阅读模式
我在centos6.4上安装了vcsmx_2014.03,采用 -full64 方式运行,运行之后报license的错误。
请问vcsmx_2014.03必须和哪一个版本的SCL配合使用,我从EETOP上下载了SCL_v11.5,不知道怎么安装,所以仍然用的
SCL_10.9版本的。请求高手指点!跪谢!
[lili@A10155854 work]$ ./test.csh
                         Chronologic VCS (TM)
         Version I-2014.03_Full64 -- Tue Apr 12 16:03:30 2016
               Copyright (c) 1991-2014 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Cannot find license file.
Make sure that you have a license file and that your
LM_LICENSE_FILE is pointing to the right location.
CPU time: .055 seconds to compile
发表于 2017-3-3 01:16:53 | 显示全部楼层
Reply 1 # yangke166
Mselfneedit
GMT+8, 2025-12-26 15:59 , Processed in 0.015820 second(s), 5 queries , Gzip On, Redis On.
