查看: 2496|回复: 2
VCS 编译时出现问题(求解!急,在线等)
发表于 2016-3-24 14:42:28 | 显示全部楼层 |阅读模式
使用指令 vcs slave_test.v -y ./rtl +libext+.v  进行编译,结果如下:
                            Chronologic VCS (TM)
            Version C-2009.06 -- Thu Mar 24 14:26:55 2016
               Copyright (c) 1991-2008 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file 'slave_test.v'
Parsing library directory file './rtl/SPI_S.v'
Parsing library directory file './rtl/Reset_Synchronizer.v'
Parsing library directory file './rtl/spi_slave.v'
Parsing library directory file './rtl/sync_detect.v'
Parsing library directory file './rtl/reset_DRDY.v'
Parsing library directory file './rtl/reset_sck.v'
Top Level Modules:
       slave_test
TimeScale is 10 ns / 1 ps
Starting vcs inline pass...
1 module and 0 UDP read.
recompiling module slave_test because:
        Some compilation options have been changed.
if [ -x ../simv ]; then chmod -x ../simv; fi
g++  -o ../simv -melf_i386 -m32  5NrI_d.o 5NrIB_d.o V6Uy_1_d.o rmapats_mop.o rmapats.o SIM_l.o   /home/EDA/tools/VCS2009/linux/lib/libvirsim.a /home/EDA/tools/VCS2009/linux/lib/librterrorinf.so /home/EDA/tools/VCS2009/linux/lib/libsnpsmalloc.so     /home/EDA/tools/VCS2009/linux/lib/libvcsnew.so     /home/EDA/tools/VCS2009/linux/lib/vcs_save_restore_new.o /home/EDA/tools/VCS2009/linux/lib/ctype-stubs_32.a -ldl  -lc -lm -lpthread -ldl
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
make: *** [product_timestamp] Error 1
Make exited with status 2
CPU time: .129 seconds to compile + .005 seconds to elab + .017 seconds to link
发表于 2016-3-24 15:56:17 | 显示全部楼层
回复 1# 1027199631
   沒裝GCC,或是沒設環境變量GCC
发表于 2016-3-24 16:01:53 | 显示全部楼层
大概你需要安装32bit 的 glibc-devel 包
GMT+8, 2025-12-24 00:45 , Processed in 0.014289 second(s), 4 queries , Gzip On, Redis On.
