查看: 4304|回复: 5
如何在虚拟机的linux系统中安装firebird数据库[silvaco][utmost]
发表于 2016-3-15 17:49:21 | 显示全部楼层 |阅读模式
在虚拟机中安装了RHEL7.1,然后安装了silvaco AMS全套软件。
其中模型萃取软件UTMOST IV要求在本地服务器上安装firebird数据库。
之前在windows下可以完成安装和配置,但是在虚拟机Linux下按照manual提示运行安装命令后会报错。
错误提示如下:
网上查了一下,似乎是firebird数据库会限制安装硬盘不可以是网络服务器,貌似是虚拟机的磁盘映射之类的。对linux系统不熟悉,不太清楚这个问题应该如何解决,求助!
 楼主| 发表于 2016-3-15 17:55:05 | 显示全部楼层
图片呢。。。错误如下:
[root@localhost home]# firebird -install
Running s_install version: 2.0.3.R  please wait...
Currently 9260708 KB free in /tmp (>= 8000)
Preparing to install the Firebird Database Server.
This procedure will modify or create the following system files:
        /etc/rc.d/init.d/firebird
Backups will be created in /var/tmp/s_install.bak
before any files are modified.
Run '/home/XXXX/EDA/Silvaco_TCAD/etc/s_install -rm-bak' or
'/var/tmp/s_install.bak/remove' to remove backup files.
Do you wish to proceed? [y|n] y
No fstab entry for /home/XXXX/EDA/Silvaco_TCAD/var/srdb
Try setting NFS_FILE_SERVER.
ERROR: Cannot determine fileserver for /home/XXXX/EDA/Silvaco_TCAD/var/srdb assuming local machine
Errors encounted while determining database location.
Abort installation? [y|n]
 楼主| 发表于 2016-3-16 20:20:29 | 显示全部楼层
呃,这么惨
 楼主| 发表于 2016-3-25 16:36:37 | 显示全部楼层
人肉置顶
发表于 2017-7-12 21:41:42 | 显示全部楼层
我也想知道啊
发表于 2017-8-29 21:02:05 | 显示全部楼层
thanks!
GMT+8, 2025-11-19 03:07 , Processed in 0.017938 second(s), 3 queries , Gzip On, Redis On.
