命令行是:vcs test.src top.v -l comp.log -cm_glitch 1
结果出现以下提示,不认-cm,请各位帮忙看下是什么原因引起。simv文件能产生,也能运行,也有结果。
Warning-[VCM-INSOPTMIS] Coverage instrumentation option missing
Design is not compiled with 'any -cm' option. No compile-time
instrumentation is done for any metric of code coverage in the design.
The sub-options given with 'any -cm_*' switch will not work. Either include
the '-cm line/tgl/fsm/cond/line/path/assert' option or remove sub-options. |
