查看: 2077|回复: 2
[求助] ICC进行check_library,以下missing是否可以忽略?判断依据是什么?
发表于 2016-2-24 22:35:15 | 显示全部楼层 |阅读模式
icc_shell> check_library
#BEGIN_XCHECK_LIBRARY
Logic Library:    ..2_max
Physical Library:../mw_lib/..2
check_library options:
Version:                                D-2010.03-ICC-SP5
Check date and time:    Wed Feb 24 21:26:23 2016
          List of logic library and file names
Logic library name           Logic library file name
..2_max            ../db/..2_max.db
#BEGIN_XCHECK_LOGICCELLS
Number of cells missing in logic library:       3 (out of 350)
Information: List of cells missing in logic library (LIBCHK-210)
Cell name                  Cell type             Physical library
vddcon                     Core                 ..2
vsscon                     Core                  ..2
rowend                     Core                 ..2
Information: List of physical only cells (LIBCHK-119)
feedth                     Filler                ..2
feedth2                    Filler                ..2
feedth4                    Filler                ..2
feedth8                    Filler               ..2
feedth16                   Filler               ..2
#END_XCHECK_LOGICCELLS
#BEGIN_XCHECK_PHYSICALCELLS
Number of cells missing in physical library:    0 (out of 358)
#END_XCHECK_PHYSICALCELLS
#BEGIN_XCHECK_PINS
Number of cells with missing or mismatched pins in libraries:   0
#END_XCHECK_PINS
Logic vs. physical library check summary:
Information: Logic library is INCONSISTENT with physical library (LIBCHK-220)
#END_XCHECK_LIBRARY
1
发表于 2016-2-25 09:42:00 | 显示全部楼层
如果确认是physical only的单元,是可以忽略的。
 楼主| 发表于 2016-2-25 14:48:01 | 显示全部楼层
回复 2# chrisyl
如何确定呢?我的logic library为..2_max.db和..2_min.db
MW reference library为..2的Milkyway library是否设置正确呢?还是要加io单元库?(设计中有输入输出端口)
vddcon                     Core                 ..2
vsscon                     Core                  ..2
rowend                     Core                 ..2
GMT+8, 2025-10-29 10:54 , Processed in 0.011666 second(s), 3 queries , Gzip On, Redis On.
