查看: 3828|回复: 3
[求助] edk外设问题(ddr2)
发表于 2016-1-28 13:56:28 | 显示全部楼层 |阅读模式
我在ISE中建立了一个工程,其中用到了mig IP核,将整个工程作为一个外设挂在EDK下,其中综合时会报错The I/O component   has an illegal IOSTANDARD value.  The IOB component is configured to use single-ended signaling and can not use differential IOSTANDARD value DIFF_SSTL18_II_DCI. Two ways to rectify this issue are: 1) Change the IOSTANDARD value to a single-ended standard. 2) Correct the I/O connectivity by instantiating a differential I/O buffer.
ddr2_dqs和ddr2_dqs_n的所有信号都会报此错误。该工程在ISE中综合时并没有任何问题。其中设计这两个信号的地方为
module ddr2_phy_dqs_iob
IOBUFDS u_iobuf_dqs
         .O   (dqs_ibuf),
         .IO  (ddr_dqs),
         .IOB (ddr_dqs_n),
         .I   (dqs_out),
         .T   (dqs_oe_n_r)
它的上一层文件中
genvar dqs_i;
  generate
    for(dqs_i = 0; dqs_i < DQS_WIDTH; dqs_i = dqs_i+1) begin: gen_dqs
      ddr2_phy_dqs_iob #
         .DDR_TYPE              (DDR_TYPE),
         .HIGH_PERFORMANCE_MODE (HIGH_PERFORMANCE_MODE),
         .IODELAY_GRP           (IODELAY_GRP)
        u_iob_dqs
           .clk0           (clk0),
           .clkdiv0        (clkdiv0),
           .rst0           (rst0),
           .dlyinc_dqs     (dlyinc_dqs[dqs_i]),
           .dlyce_dqs      (dlyce_dqs[dqs_i]),
           .dlyrst_dqs     (dlyrst_dqs),
           .dlyinc_gate    (dlyinc_gate[dqs_i]),
           .dlyce_gate     (dlyce_gate[dqs_i]),
           .dlyrst_gate    (dlyrst_gate[dqs_i]),
           .dqs_oe_n       (dqs_oe_n),
           .dqs_rst_n      (dqs_rst_n),
           .en_dqs         (en_dqs[dqs_i]),
           .ddr_dqs        (ddr_dqs[dqs_i]),
           .ddr_dqs_n      (ddr_dqs_n[dqs_i]),
           .dq_ce          (dq_ce[dqs_i]),
           .delayed_dqs    (delayed_dqs[dqs_i])
    end
  endgenerate
再上层文件是对其实例化ddr_dqs->ddr2_dqs
ddr2_dqs_n->ddr2_dqs_n
我的ucf中对信号的约束为
NET  "ddr2_dqs[*]"                              IOSTANDARD = DIFF_SSTL18_II_DCI;
NET  "ddr2_dqs_n[*]"                            IOSTANDARD = DIFF_SSTL18_II_DCI;
发表于 2016-1-28 16:16:52 | 显示全部楼层
看着像是ip生成时候配置的与现在应用的不一样,哪里选择了单端,然后又用差分了。
个人理解,不对请纠正!
发表于 2016-1-28 16:52:00 | 显示全部楼层
感謝樓主無私分享-------
发表于 2016-5-16 16:40:57 | 显示全部楼层
学习啦
GMT+8, 2025-12-26 15:03 , Processed in 0.020686 second(s), 7 queries , Gzip On, Redis On.
