楼主: min4max
Cadence全套新版IC工具套件(2015年底版本),包括IC617以及其他工具套件
发表于 2016-3-9 12:50:15 | 显示全部楼层
感谢楼主!
发表于 2016-3-10 00:04:58 | 显示全部楼层
楼主神人,膜拜,多谢。
发表于 2016-3-10 03:39:38 | 显示全部楼层
我太崇拜你了, 你是神一样的存在。 可以接受奉献吗? ^_^
发表于 2016-3-15 08:59:56 | 显示全部楼层
回复 1# min4max
   请问大神Calibre2015总是提示授权不足,上传为启动virtuoso时显示的log//  Calibre Skill Interface * (v2015.2_36.27) *
//                 Copyright Mentor Graphics Corporation 2005
//                             All Rights Reserved.
//         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Calibre layout-server initialized successfully at socket 9189, host lenovo.
*WARNING* (DB-220704): The Pcell super master: MentorObserverLib/oa_v22_50_001/layout is not a SKILL super master.
                       The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
Starting Calibre server...
Calibre server connected, Client version = 1.21.1 Server version = 1.21.1
//  Calibre v2015.2_36.27    Wed Jul 1 10:06:07 PDT 2015
//        Copyright Mentor Graphics Corporation 1996-2015
//  Mentor Graphics software executing under x86-64 Linux
Calibre server launched successfully
//  Calibre RealTime embedded client initialized successfully at localhost:9189
//  Calibre RealTime: Initialization complete
Loading le.cxt
Loading st3000/libInit.il ...
Loading st3000/loadCxt.ile ... done!
Loading context 'st3000' from library 'st3000' ... done!
Loading context 'pdkUtils' from library 'st3000' ... done!
*WARNING* You cannot redefine stipple "X" for display "display".
          It is a system reserved stipple name.
          Please rename stipple X to another name for display "display" in display.drf.
          and reassign the stipple of all packets which use stipple X to the new named stipple for display "display".
*WARNING* You cannot redefine stipple "X" for display "psb".
          Please rename stipple X to another name for display "psb" in display.drf.
          and reassign the stipple of all packets which use stipple X to the new named stipple for display "psb".
Loading st3000/display.drf ... done!
Loading st3000/libInitCktPro.il ... done!
Loaded st3000/libInit.il successfully!
Loading drdEdit.cxt
Loading leToolbox.cxt
Loading treeAssistant.cxt
Loading soi.cxt
Load shared object file /opt/Cadence/ASSURA414/tools.lnx86/assura/lib/64bit/libavview.so
*WARNING* dlopen: /opt/Cadence/ASSURA414/tools.lnx86/assura/lib/64bit/libavview.so: /opt/Cadence/ASSURA414/tools.lnx86/assura/lib/64bit/libavview.so: undefined symbol: _XmStrings
*WARNING* Failed to open shared object file /opt/Cadence/ASSURA414/tools.lnx86/assura/lib/64bit/libavview.so
*WARNING* (LE-104272): Assura has not been installed in this hierarchy.
Loading lo.cxt
Loading mpt.cxt
Loading vb.cxt
Loading see.cxt
Loading oi.cxt
Loading asst.cxt
Loading mtv.cxt
Loading lce.cxt
//  Calibre Interactive - DRC  v2015.2_36.27    Wed Jul 1 10:06:07 PDT 2015
//  Running on Linux lenovo 3.10.0-123.el7.x86_64 #1 SMP Mon May 5 11:16:57 EDT 2014 x86_64
//  64 bit virtual addressing enabled
//  Starting time: Mon Mar 14 21:02:28 2016
//  ERROR: The following products could not be licensed sufficiently:
//  ERROR: - Calibre Interactive
124.txt
3.59 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2016-3-15 09:30:17 | 显示全部楼层
太感谢了!!!
发表于 2016-3-15 10:21:31 | 显示全部楼层
膜拜大神
发表于 2016-3-15 18:39:51 | 显示全部楼层
楼主强啊,真乃神人啊, 谢谢分享。
发表于 2016-3-15 21:16:28 | 显示全部楼层
非常好的资料,谢谢分享
发表于 2016-3-15 22:16:49 | 显示全部楼层
楼主神人!
发表于 2016-3-16 10:01:48 | 显示全部楼层
you are my god!! I will always following you.
GMT+8, 2025-10-26 00:10 , Processed in 0.018791 second(s), 3 queries , Gzip On, Redis On.
