查看: 2873|回复: 5
[资料] MOSFET's Monte Carlo analysis in OrCad Cadence
发表于 2016-1-11 21:13:30 | 显示全部楼层 |阅读模式
how to change the Library file of MOSFET so as to do the monte carlo analysis in case of Cadencei tried DEV=5%
it shows DEV is not the model paremeter
发表于 2016-1-12 17:07:32 | 显示全部楼层
you can get it in the manual.
vary PAR_NAME dist=<type> {std=<value> | N=<value>} {percent=yes|no}
回复 1# nsrknt
 楼主| 发表于 2016-1-13 22:04:59 | 显示全部楼层
thanks a lot
can i change four, five parameters of the MOSFET.
i saw this type of analysis in case of resistor but can't find it in case of MOS can u please provide me the link from where i can study/learn this
thanks
发表于 2016-1-14 20:14:54 | 显示全部楼层
thanks!!
发表于 2018-7-8 17:21:14 | 显示全部楼层
OrCAD ??!
发表于 2018-7-10 10:04:00 | 显示全部楼层
gooood  joooob
GMT+8, 2025-12-17 04:32 , Processed in 0.023455 second(s), 6 queries , Gzip On, Redis On.
